IPv4 multicast routing
This help contains the following topics:
Introduction
Only when IPv4 multicast routing is enabled, other Layer 3 multicast features (such as IGMP and PIM) can take effect.
The following tables are involved in IPv4 multicast routing and forwarding:
vSystem support information
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Configure IPv4 multicast routing
Complete the following tasks before you configure this feature:
  1. Select Network > IP Multicast > IPv4 Multicast Routing.
  2. Select the public network or a specific VPN instance.
    Figure-1 Enabling IPv4 multicast routing
  3. Click Enable.
