This help contains the following topics:
Internet Group Management Protocol (IGMP) establishes and maintains the multicast group memberships between a Layer 3 multicast device and the hosts on the directly connected subnet.
IGMP has the following versions:
IGMPv3 introduced two source filtering modes (Include and Exclude). These modes allow a host to receive or reject multicast data from the specified multicast sources.
IGMPv3 introduces IGMP group-and-source queries and IGMP reports carrying group records.
After IGMP is enabled on an interface, the interface can establish and maintain multicast group memberships.
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Complete the following tasks before you configure this feature:
Assign IP addresses to interfaces on the
Configure routes on the
Create security zones on the
Add interfaces to security zones. You can add interfaces to a security zone on the
Configure security policies to permit the target traffic on the
Select
Select the public network or a specific VPN instance.
Click
Figure-1 Clicking
Figure-2 Selecting interfaces
Click
