This help contains the following topics:
The Dynamic Host Configuration Protocol (DHCP) provides a framework to assign network configuration information to network devices.
DHCP uses the client-server model. A DHCP network typically contains a DHCP server and multiple DHCP clients. If DHCP clients and the DHCP server are on different subnets, the DHCP clients can obtain configuration parameters from the DHCP server through a DHCP relay agent.
Use a DHCP server to assign IP addresses for the following networks:
A large-sized network that requires centralized management.
A network without sufficient IP address space. If the number of hosts is larger than the number of assignable IP addresses, not all hosts can have an IP address at the same time.
A network with only a few hosts requiring fixed IP addresses.
A DHCP server stores the following information in an address pool: IP addresses, lease duration, network information, domain name suffix, DNS server addresses, WINS server addresses, NetBIOS node types, and DHCP option information. The DHCP server selects an IP address and configuration parameters from the address pool and allocates them to a requesting DHCP client.
Before assigning the IP address to the client, the DHCP server performs IP address conflict detection.
The following address assignment mechanisms are available:
You can specify the lease duration for statically and dynamically allocated addresses.
The DHCP server observes the following principles to select an address pool for a client:
If there is an address pool where an IP address is statically bound to the MAC address or ID of the client, the DHCP server selects this address pool and assigns the statically bound IP address and other configuration parameters to the client.
If the above condition is not met, the DHCP server selects an address pool depending on the client location.
The DHCP server selects an IP address for a client in the following sequence:
IP address statically bound to the client's MAC address or ID.
IP address that was ever assigned to the client.
IP address designated by the Option 50 field in the DHCP-DISCOVER message sent by the client.
Option 50 is the Requested IP Address option. The client uses this option to specify the wanted IP address in a DHCP-DISCOVER message. The content of Option 50 is user defined.
First assignable IP address found based on the dynamic allocation rule.
IP address that was a conflict or passed its lease duration. If no IP address is assignable, the server does not respond.
DHCP uses the options field to carry information for dynamic address allocation and provide additional configuration information for clients.
Use the
Add new DHCP options.
Define vendor-specific option contents. For example, you can pad vendor-specific information into Option 43.
Configure functions that are not supported on other DHCP Web pages. For example, you can use Option 4 to specify the IP address 1.1.1.1 as the time server address for DHCP clients.
Extend existing DHCP options to meet user requirements. For example, a maximum of eight DNS server addresses can be configured on the Web page. If you need to configure more DNS servers, you can use the DHCP options for extension.
Table-1 lists common DHCP options.
Option number | Option name | Recommended option padding type |
3 | Router Option | IP address |
6 | Domain Name Server Option | IP address |
15 | Domain Name | ASCII string |
43 | Vendor Specific Information | Hexadecimal string |
44 | NetBIOS over TCP/IP Name Server Option | IP address |
46 | NetBIOS over TCP/IP Node Type Option | Hexadecimal string |
66 | TFTP server name | ASCII string |
67 | Bootfile name | ASCII string |
Before assigning an IP address, the DHCP server pings that IP address.
If the server receives a response within the specified period, it selects and pings another IP address.
If it receives no response, the server continues to ping the IP address until the maximum number of ping packets are sent. If still no response is received, the server assigns the IP address to the requesting client.
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Figure-1 DHCP configuration flow chart
Complete the following tasks before you configure this feature:
Assign IP addresses to interfaces on the
Configure routes on the
Create security zones on the
Add interfaces to security zones. You can add interfaces to a security zone on the
Configure security policies to permit the target traffic on the
To implement the DHCP server function, perform the following tasks:
Enable DHCP service.
Configure the interface to operate in DHCP server mode.
Configure a DHCP address pool. You can perform the following configuration tasks for the address pool:
Navigate to the
Figure-2 DHCP Service page
To enable the DHCP server mode on an interface, click the
Figure-3 Configure the DHCP operating mode of an interface
Navigate to the
Figure-4 DHCP Address Pools page
Choose one of the following options as needed:
To edit the address allocation settings of an existing address pool, select the address pool on the box above the
To create an address pool and configure its address allocation settings, click
Figure-5 Create a DHCP address pool
Click the
Figure-6 Configure address allocation settings
Table-2 Address allocation configuration items
Navigate to the
Click the
Figure-7 Configure address pool options
Table-3 Address pool option configuration items
Click
To view information about allocated IP addresses, click the
Figure-8 View allocated IP addresses
