Asset scan
This help contains the following topics:
Introduction
Asset scan scans the assets with the specified IP addresses or in the specified IP address ranges to obtain the operating system, MAC address, vendor information of the assets and detect security risks such as open ports and weak passwords. The administrator can then perform system hardening based on the information to eliminating possible potential attacks.
Asset scan supports scanning the specified IPv4 addresses, IPv6 addresses, TCP ports, and UDP ports.
The following table shows security risk types and the recommended protection measures:
Table-1 Risk types and protection measures
Risk type
Protection measure
Open port
Use a security policy to deny packets that access the open ports.
Weak password
Modify the weak passwords of users.
vSystem support information
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Configure asset scan
  1. Click the Monitor tab.
  2. In the navigation pane, select Asset Management > Asset Scan.
  3. In the Address range box, specify individual IPv4 or IPv6 addresses, IPv4 or IPv6 address ranges, or IPv4 or IPv6 subnets.
  4. Select or enter the TCP ports.
  5. Select or enter the UDP ports.
  6. To enable automatic scanning, select Auto scanning. The device will scan assets at regular intervals. By default, the scanning interval is 12 hours. The following types of intervals are available:
    • Week—Scans assets every week on the specified day and time.
    • Day—Scans assets every day at the specified time.
    • Hour—Scans assets every specified hours.
  7. To enable weak password scanning, select Enable weak password scanning. Then, click Configure to configure the weak password scanning range and scanning mode.
  8. To immediately start scanning assets, click Scan. After the scanning is completed, you can click Refresh in the Scanning results area to view the asset scanning results.
