This help contains the following topics:
This feature collects statistics about application traffic and application-related threat events (including IPS and anti-virus events) within a specific time span on a device. The statistics results are displayed in graphs, enabling you to quickly identify key periods of traffic and threat events, especially those with peak and trough traffic and those when threat events frequently occur and high-risk events occur. Then, you can adjust the bandwidth control policies and security protection policies accordingly, which benefits bandwidth resource allocation and internal network security protection.
To configure multiple statistics collection conditions (such as the applications and the source IP address) and view the trends of corresponding traffic and threats, click Stats conditions.
To export the statistics matching the specified statistics collection conditions as a PDF file to your local PC, click Export report. You can obtain the traffic usage and detected threat events of the device in the export file.
The Traffic page displays the application-based traffic trend.
Perform this task to generate the traffic trend report and export the report.
Click Stats conditions.
Configure the statistics collection conditions.
Table-1 Statistics collection condition configuration items for the traffic trend report
Item | Description |
Application | Select applications for statistics collection. Options are:
Traffic direction | Select a direction of traffic for statistics collection. Options are:
Time range | Select a time range from the list. Options are:
Query object | Enter an IP address of a host for statistics collection. |
Click Start.
To export the traffic trend report, click Export report.
The Threats page displays the application-based threat trend.
Perform this task to generate the threat trend report and export the report.
Table-2 Statistics collection condition configuration items for the threat trend report
Click Start.
To export the threat trend report, click Export report.
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
