This help contains the following topics:
A local user is a set of user attributes stored in the local user database on the device for network access. A local user is uniquely identified by its username.
To implement local authentication, authorization, and accounting, create local users and configure user attributes on the device.
User groups simplify local user configuration and management. A user group contains a group of local users and has a set of local user attributes. You can configure local user attributes for a user group to implement centralized user attributes management for the local users in the group. Local user attributes that are manageable by using user groups are authorization attributes.
Each new created local user belongs to the system defined user group named
To enhance password security for users, you can configure the password control feature.
You can define the minimum length of user passwords. The system rejects any password that is shorter than the configured minimum length. By default, the minimum password length is 10 characters.
A password can be a combination of characters from the following types:
Uppercase letters A to Z.
Lowercase letters a to z.
Digits 0 to 9.
Special characters. See Table-1.
Character name | Symbol | Character name | Symbol |
Ampersand sign | & | Apostrophe | ' |
Asterisk | * | At sign | @ |
Back quote | ` | Back slash | \ |
Blank space | N/A | Caret | ^ |
Colon | : | Comma | , |
Dollar sign | $ | Dot | . |
Equal sign | = | Exclamation point | ! |
Left angle bracket | < | Left brace | { |
Left bracket | [ | Left parenthesis | ( |
Minus sign | - | Percent sign | % |
Plus sign | + | Pound sign | # |
Quotation marks | " | Right angle bracket | > |
Right brace | } | Right bracket | ] |
Right parenthesis | ) | Semi-colon | ; |
Slash | / | Tilde | ~ |
Underscore | _ | Vertical bar | | |
Depending on the system's security requirements, you can set the minimum number of character types a password must contain and the minimum number of characters for each type, as shown in Table-2.
Table-2 Password composition check
Password combination level | Minimum number of character types | Minimum number of characters for each type |
Level 1 | One | One |
Level 2 | Two | One |
Level 3 | Three | One |
Level 4 | Four | One |
When a user sets or changes a password, the system examines whether the password meets the combination requirement. If the password does not meet the requirement, the operation fails.
By default, the minimum number of character types is one and the minimum number of characters for each type is one.
Password complexity check
The strength of a password increases as its complexity grows. A less complicated password is more likely to be cracked. For example, a password that contains the username or repeated characters is more likely to be cracked than those do not. To increase system security, configure a password complexity checking policy to make sure the user-configured passwords are complex enough against most password attacks.
You can apply the following password complexity requirements:
A password cannot contain the username or the username spelled backwards. For example, if the username is
| For this feature to take effect on a local user, you must enable it both in the user-specific password control settings and in the global password control settings. |
A password cannot contain more than two consecutive identical characters. For example, password
| For this feature to take effect on a local user, you can enable it in the user-specific password control settings or in the global password control settings. |
Password history
This feature allows the system to store passwords that a user has used. When a user changes the password, the system compares the new password with the current password and those stored in the password history records. The new password must be different from the current one and those stored in the history records by a minimum of four characters. If the new password does not meet this requirement, the system displays an error message and rejects the password change operation.
You can set the maximum number of history password records for the system to maintain for each user. When the number of history password records exceeds the setting, the most recent record overwrites the earliest one.
Password updating
This feature allows you to set the minimum interval at which users can change their passwords. A user can only change the password once within the specified interval.
The minimum interval does not apply to the following situations:
A user is prompted to change the password at the first login.
The password expiration time expires.
User login control
You can set the idle time for local user accounts globally. For the idle time to take effect on a local user account, a user must have used that local user account to successfully log in to the device. After the idle time takes effect on a local user account, if no user has logged in successfully by using that user account within the idle time, the account will be locked. To restore the login permission of the account, access the local user page and clear the user idle lock state for the account.
The user identification feature can be used with other security features to perform user-based network access control and network privilege management.
The user identification feature has the following benefits:
Facilitates security policy deployment on a per-user basis.
Implements network access behaviors auditing on users by providing user-based network attack/access traffic statistics.
Enables the device to use fixed usernames instead of dynamic IP addresses to implement policy control.
Identity users are used to record identification information of network access users from different sources. The identification information includes the username, user group name, and identity domain name of the users. The user identification module uniformly manages identity users from different sources.
The device supports the following methods to create identity users:
Identity users will be deleted due to one of the following reasons:
The network administrator deletes identity users manually.
The user identification module automatically deletes identity users after the corresponding network access users are deleted from the local user database.
Identity users can be added to different groups for batch configuration and hierarchical user management. The groups are called identity groups. The user identification module uniformly manages identity groups from different sources.
The device supports the following methods to create identity groups:
An identity group is activated when it is used by an application module, and all services based on the identity group will take effect. When the application module stops using the identity group, the identity group is inactive.
Identity groups will be deleted due to one of the following reasons:
The network administrator deletes identity groups.
The user identification module automatically deletes an identity group if the corresponding local user group is deleted from the local user database.
All identity users are organized in a tree structure. An identity user can belong to one or multiple identity groups. An identity group can belong to one or multiple higher-layer identity groups. The tree structure facilitates user location and query. As shown in Figure-1, the device uniquely identifies a managed object by the combination of identity domain and username or the combination of identity domain and identity group.
Figure-1 Identity user management architecture
The following shows the process for identity-based user access control:
Identity authentication. A network access user passes identity authentication and comes online.
User identification. The device obtains the username and IP address of the online user, and associates the information with the local identity user account and the local identity group. Then, the username-IP mapping for the network access user is created. The administrator can also add static username-IP mappings to permit network access without identity authentication.
Identity-based access control. The device identifies the source IP address of the traffic destined for the network, and resolves the IP address to the username and user group based on the mapping. The device performs network access control for the user or user group based on other security feature settings such as blacklist and object policy.
Online users are online network access users (including portal, PPP, and IPoE users) that are managed by the user identification module. The device records the username, identity domain name, IP address, and MAC address of online users.
Online users include dynamic online users and static online users.
Dynamic creation.
Static configuration.
The network administrator manually creates online users. Each static identity user contains the mapping between the username and the IP addresses of the user. After a static identity user is created, the user identification module searches the user's username and domain name in local identity users. If a matching entry is found, the device creates a static online user entry for the static identity user. Static online users can access the network without identity authentication but their access to the network is controlled by security features. The network administrator can configure static identity users when only few people need to temporarily access the network.
Application modules can impose security policies on online users. When online user entries are deleted, the user identification module will instruct the application modules to stop processing services for the users.
Online users will be deleted due to one of the following reasons:
The network administrator deletes online users manually.
The access modules instruct the user identification module to delete online users after the associated network access users go offline.
All dynamic online users are deleted after the device restarts up.
All dynamic online users are deleted after the user identification feature is disabled.
The third-party servers instruct the device to delete online users after associated users go offline.
A user import policy is used to import identity users, online users, or identity groups from a RESTful server or LDAP servers.
The user import policy supports the following import methods:
An email server is used for the random password generation feature.
The system can generate random passwords for network access users on the Web interface and use emails to send the random passwords to the users. After that, the users can use the random passwords to log in to the device.
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
A non-password-protected local user passes authentication if the user provides the correct username and passes attribute checks. To enhance security, configure a password for each local user.
For portal users, only the authorization ACL and idle timeout attributes take effect.
For SSL VPN users, only the SSL VPN resource group attribute takes effect.
Deletion of identity users does not delete the corresponding network access users from the local user database.
When you import users from a .CSV template, make sure the file is a standard .CSV file and do not modify the annotation headers of the template. A violation might cause data loss.
To use the IMC RESTful server, make sure the server is installed with the SSM component and runs on IMC PLAT 7.0 (E0201) or its patch version.
After the device establishes a connection with the RESTful server, the RESTful server sends real-time user login and logout information for the device to update online users.
Before you configure the email address of the receiver, you must configure the email server.
The settings on the
The
After password control is enabled, the password set for a local user must have a minimum of four different characters.
For password control settings configured for a user to take effect, you must enable password control. To enable password control, click
You can create local users manually or import local users in bulk.
Click the
In the navigation pane, select
Click the
Figure-2 Users tab
Create a local user.
Figure-3 Creating a local user
Table-3 Local user configuration items
Item | Description |
Username | Enter the name of a network access user. The user accesses the network resources through the device. To implement local authentication, you must configure local users on the device |
Set random password | Select to generate a random password for the user. |
Receiver email | Enter the email address of the receiver to receive the random password. Before you configure this field, please enter the Email Server page to configure the email server. |
Password | Enter the password of the user. |
Confirm | Enter the password of the user again, |
Validity period | Set the validity period of the user. Expired user accounts cannot be used for authentication.
Authorization user group | Select an authorization user group. Each local user belongs to a user group and has all attributes of the group. The attributes include the password control attributes and authorization attributes. |
Identity group | Select an identity group. The user identification module controls the network access of a local user based on the identity group to which the user belongs. |
Available services | Select services that the user can use. Local authentication checks the service types of a local user. If none of the service types is available, the user cannot pass authentication. |
Max number of concurrent logins | Enter the maximum number of users that can concurrently access the device by using the same username. When the number of logins using a username reaches the limit, no more local users can access the device by using the username. |
Phone number | Enter the phone number of the user. |
Description | Enter the descriptive information of the user. |
(Optional.) Configure authorization attributes.
Figure-4 Authorization attributes
Table-4 Authorization attribute configuration items
ACL type | |
Authorization ACL | Select an authorization ACL. The device restricts authenticated users to access only the network resources permitted by the ACL. You can select an existing ACL or create a new ACL. To view the newly created ACL, visit |
Idle timeout | Enter the idle cut timeout period. The device logs out a user if the user's total traffic in the idle timeout period at the specified direction is less than the specified minimum traffic. |
Authorization VLAN | Enter a VLAN ID. The device restricts authenticated users to access only the network resources in the VLAN. |
SSL VPN resource group | Enter an SSL VPN resource group. The device restricts authenticated users to access only the network resources specified in the SSL VPN resource group. |
(Optional.) Configure binding attributes.
Figure-5 Binding attributes
Table-5 Binding attribute configuration items
Access interface | Select an access interface. If the actual access interface of the user is not the same as the binding interface, the user fails authentication. |
IPv4 address/mask length | Enter an IPv4 address and its mask length. If the IP address/mask length of the user is not the same as the binding IPv4 address/mask length, the user fails authentication. |
MAC address | Enter a MAC address. If the MAC address of the user is not the same as the binding MAC address, the user fails authentication. |
VLAN | Enter a VLAN ID. If the user belongs to a VLAN different from the binding VLAN, the user fails authentication. |
(Optional.) Configure password settings.
Figure-6 Password settings
Table-6 Password setting configuration items
Min password length | Enter the minimum password length. If the password that a user enters is shorter than this value, the system rejects the password setting. |
Min character types | Enter the minimum number of character types in a password. If the number of character types in the password that a user enters is less than this value, the system rejects the password setting. |
Min number of characters for each type | Enter the minimum number of characters for each type in a password. If the number of characters for each type in the password that a user enters is less than this value, the system rejects the password setting. |
Enable password expiration | Select this item to restrict the password validity period. |
Password expiration time | Set the password expiration time. A user needs to change its password to a new password when its password expires. |
No username or reversed username in password | Select this item to reject a password that has the username or the reverse of the username. |
No more than two consecutive identical characters in password | Select this item to reject a password that has more than two identical consecutive characters. |
Max login attempts | Set the maximum number of consecutive login attempts. When a user fails the maximum number of consecutive attempts, login attempt limit limits the user and user account according to the specified action. |
Account handling for login failure | Specify the action to take if the number of login failures of a user reaches the maximum number of login attempts. Options:
Account lock time | Set the period during which login is denied. After the specified period of time, a user can use the user account to log in to the device. |
Account idle time | Set the idle time for the local user account. For the idle time to take effect on the local user account, a user must have used the local user account to successfully log in to the device. After the idle time takes effect on the local user account, if no user has logged in successfully by using the user account within the idle time, the account will be locked. To restore the login permission of the account, access the local user page and clear the user idle lock state for the account. |
Click
Click the
Click the
Figure-7 Users tab
Import local users.
Figure-8 Importing local users
Table-7 Configuration items for importing local users
Import file | Specify a .CSV file for the device to import local users. Make sure the .CSV file is a standard .csv file and do not modify the annotation headers of the template. A violation might cause data loss. |
Automatically create groups | Select this item to enable the device to automatically create an identity group for a user if the identity group to which the user belongs does not exist on the device. If you do not select this item, the device does not create nonexistent user groups and it assigns the user to the system-defined user group |
Overriding existing user accounts | Select this item to enable the device to override an existing identity user account that has the same name as an identity user account to be imported. If you do not select this item, the device retains the existing identity user account. |
Import from line | Enter the number of the line at which the account import begins. If you do not specify the line number, the device imports identity user account information from the first line. |
Click
Click the
Click the
Figure-9 Users tab
Configure the password control settings.
Figure-10 Password control settings
Table-8 Password control configuration items
Enable password control | Select this item to enable password control. |
Enable password length check | Select this item to enable password length check. |
Enable password composition check | Select this item to enable password composition check. |
Min number of character types | Enter the minimum number of character types in a password. If the number of character types in the password that a user enters is less than this value, the system rejects the password setting. |
No more than two same consecutive characters in password | Select this item to reject a password that has more than two identical consecutive characters. |
Enable local user password change upon first login | Specify whether to enable local user password change upon first login. If you enable this feature, the system requires a user to change the password upon first successful login. |
Enable password history recording | Select this item to enable password history recording. |
Max number of history password records | Enter the maximum number of history password records. When the number of history password records exceeds this value, the most recent record overwrites the earliest one. |
Enable password expiration | Globally enable password expiration to restrict the password validity period. |
Password expiration time | Globally set the password expiration time. A user needs to change its password to a new password when its password expires. |
Password expiration notification | Set the number of days before a user's password expires during which the user is notified of the pending password expiration. |
Max period allowed to log in after expiration | Set the maximum number of days during which a user can log in using an expired password. |
Max number of logins with an expired password | Set the maximum number of times a user can log in after the password expires. |
Min password update interval | Enter the minimum password update interval. A user can only change the password once within the specified interval. |
Account idle time | Set the idle time for local user accounts globally. For the idle time to take effect on a local user account, a user must have used that local user account to successfully log in to the device. After the idle time takes effect on a local user account, if no user has logged in successfully by using that user account within the idle time, the account will be locked. To restore the login permission of the account, access the local user page and clear the user idle lock state for the account. |
Max Entries with Same Username | When users that use the same username with different IP addresses log in and the logins fail, the device records the user information for each IP address. If a user fails to log in with a new IP address after the number of recorded user information entries has reached the maximum number, the device will delete the earliest user information entry related to that username and add a new record. |
Lockdown Type Upon Login Failures | Use this drop-down box to change the display style of locked user information. You can view locked user information on the SSL VPN statistics page. Changing the display style of locked user information also clears existing locked user information. |
Click
Click the
Click the
Figure-11 User Group tab
Create a user group.
Figure-12 Creating a user group
Table-9 User group configuration items
Group name | Name of the local user group. |
Identity users | Identity users of the local user group. |
Identity groups | User group to which the current user group belongs. |
Configure authorization attributes and SSL VPN authorization attributes (see Table-4 ).
Click
To configure identity users, perform the following tasks:
Click the
You can view the organization structure on the
Figure-13 Organization structure
Edit the target identity user or user group.
Figure-14 Editing the target identity user
Table-10 Configuration items for configuring identity users
User/User group | Existing identity users or user groups. |
Group role | Group role inherited by the current user or user group. |
Role | Role of the user or user group. You can select one or more existing roles or create new roles. |
To manage online users, perform the following tasks:
Click the
Manage online users.
Figure-15 Online users
Table-11 Configuration items for managing online users
To create a static identity user:
Click the
Click
Click
Figure-16 Static identity users
Figure-17 Creating a static identity user
Table-12 Static identity user configuration items
Domain name | Specify the identity domain to which the static identity user belongs. |
Username | Specify the username for the static identity user. |
IP address type | Specify the type of the IP address bound to the static identity user. Options are |
IP address | Specify the IP address bound to the static identity user. |
MAC address | Specify the MAC address bound to the static identity user. |
Click
Click the
Click
Figure-18 User import policy
Create a user import policy.
Figure-19 Creating a user import policy
Table-13 User import policy configuration items
Name | Enter the name of a user import policy. The name uniquely identifies a user import policy. |
RESTful server | Select a RESTful server. The device imports identity users and online users from the RESTful server. |
LDAP schemes | Select LDAP schemes. The device imports identity users from the LDAP servers specified in the LDAP schemes. |
Import types | Select the type of information to be imported. This parameter is applicable only to LDAP schemes. |
Enable auto import | Select this item to enable automatic user import. After this feature is enabled, the device first imports identity users and online users from the servers specified in the user import policy and then periodically imports identity users from the servers. |
Import interval | Enter the automatic import interval. The device automatically imports identity users from the servers specified in the user import policy at the specified interval. |
Click
After you configure the user import policy, you can manually import identity users and online users from the servers specified in the user import policy.
Figure-20 User import policy list
To manually import users, perform the following tasks:
The device sends a created random password or generated random verification code in an email notification to a user. Before you configure the email address of the receiver, you must configure the email server.
To configure the email server, perform the following tasks:
Click the
Configure the email server.
Figure-21 Configuring the email server
Table-14 Email server configuration items
Sender address | Set the address of the email sender. |
Server address | Enter the URL of the email server, which starts with smtp://. |
Username | Enter the username used to log in to the email server. |
Password | Enter the password used to log in to the email server. |
