Policy-based routing
This help contains the following topics:
Introduction
About PBR
Policy-based routing (PBR) uses user-defined policies to route packets. A policy can specify parameters for packets that match specific criteria such as ACLs, packet lengths, service object groups, or application groups. The parameters include the next hop, output interface, default next hop, and default output interface.
Policy
A policy includes match criteria and actions to be taken on the matching packets. A policy can have one or multiple nodes as follows:
You can specify a policy for local PBR to guide the forwarding of locally generated packets, or apply a policy to an interface to guide the forwarding of packets received on the interface.
A policy compares packets with nodes in priority order. If a packet matches the criteria on a node, it is processed by the action on the node. Otherwise, it goes to the next node for a match. If the packet does not match the criteria on any node, the device performs a routing table lookup
Node
Match criteria
You can set an ACL, service object group, application group, or packet length match criterion to match packets.
To match a node, a packet must match all types of the match criteria for the node.
Actions
PBR and Track
PBR can work with the Track feature to dynamically adapt the availability status of an action to the link status of a tracked object.
The tracked object can be a next hop, output interface, default next hop, or default output interface. The action is valid only when the track entry status changes to Positive or NotReady.
vSystem support information
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Configure PBR
Policy-based routing is a mechanism that achieves user-defined traffic forwarding. It allows network administrators to determine the forwarding path of data packets according to specific policies or conditions, which optimizes traffic management and improve resource efficiency in complex networks.
  1. Click the Network tab.
  2. In the navigation pane, select Routing > Policy-Based Routing > IPv4 PBR (or IPv6 PBR).
  3. Click Create.
  4. Configure IPv4 or IPv6 PBR policy parameters.
    Figure-1 Creating an PBR policy
    Table-1 IPv4 or IPv6 PBR policy configuration items
    Item
    Policy name
    Enter a PBR policy name.
    Apply to
    Apply the PBR policy locally (for local PBR) or to specific interfaces (for interface PBR).
    Figure-2 Creating an IPv4 policy node
    Figure-3 Creating an IPv6 policy node
    Table-2 Policy node configuration items
    Item
    Node ID
    Enter a policy node ID. A smaller ID has a higher priority. A policy compares packets with nodes in priority order.
    Mode
    Select a match mode for the policy node. Options include:
    • Permit
    • Deny
    Match criteria
    Specify packet match criteria. Options include:
    • Packet length: Specify the shortest and longest IP packet lengths.
    • IPv4/IPv6 ACL: Specify an ACL number of name. You can select an existing ACL or create a new ACL.
    • Match server object group: Specify a service object group name. You can select an existing service object group or create a new service object group. This parameter is supported by only IPv4 PBR.
    • Match application group: Specify an application group name. You can select an existing application group or create a new application group. This parameter is supported by only IPv4 PBR.
    Actions-Set next node
    Compare packets with the next node upon failure on the current node.
    Actions-Set IP precedence
    Set the precedence for IP packets. Eight precedence values (0 to 7) are available. Each precedence value corresponds to a precedence type
    Actions-Set DF bit
    Set the Don't Fragment (DF) bit in the IP header of matching packets. Options include:
    • 0: Allows packet fragmentation.
    • 1: Prohibits packet fragmentation.
    Actions-Set VPN instances
    Specify forwarding tables for the public network or VPN instances.
    Set next hops
    Set next hops for matching packets. You can specify multiple next hops for backup or load sharing.
    1. Click Create, and configure the following next hop address parameters:
      • VPN instance
      • IP address/IPv6 address
      • Default
      • Track entry
      • Direct next hop
    2. Click OK. The created next hop address will be displayed on the next hop address list.
    Set output interfaces
    Set output interfaces for matching packets. You can specify multiple output interfaces for backup or load sharing.
    1. Click Create, and configure the following output interface parameters:
      • Interface
      • Default
      • Track entry
    2. Click OK. The created output interface will be displayed on the output interface list.
    The output interface must be P2P type. Using a non-P2P output interface can result in forwarding failures when the interface has multiple next hops. Non-P2P interfaces include broadcast and NBMA interfaces such as Ethernet and virtual-template interfaces.
  5. On the Create Policy Node page, click OK.
    The created policy node will be displayed on the policy node list.
  6. On the Create IPv4 Policy or Create IPv6 Policy page, click OK.
    The created policy will be displayed on the IPv4 or IPv6 PBR policy list.
