This help contains the following topics:
Routing Information Protocol (RIP) is a distance-vector Interior Gateway Protocol (IGP) suited to small-sized networks. It is still widely used because of easy configuration and maintenance.
The Advertise all networks option is not available when multiple RIP processes exist.
An interface preferentially uses the interface-specific RIP version. If no interface-specific version is specified, the interface uses the global RIP version.
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Complete the following tasks before you configure this feature:
Assign IP addresses to interfaces on the
RIP is a dynamic routing protocol used to exchange routing information within an autonomous system. This protocol uses the hop count as the metric to determine the best path.
Click the
In the navigation pane, select
Click
Figure-1 Creating an RIP instance
Configure RIP instance parameters.
Table-1 RIP instance configuration items
Item | Description |
Instance ID | Enter a RIP instance ID. |
VRF | Select a VPN instance or public network for the RIP instance. |
Networks | Enable RIP on the specified networks. Options include:
Redistributed routes | Enable route redistribution from another routing protocol or another RIP instance.
Interface | Enable RIP on the specified interface. To specify an interface to enable RIP, click |
On the
Figure-2 RIP interface parameters
Configure RIP interface parameters.
Table-2 RIP interface configuration items
Item | Description | |
Interface name | Specify an interface name. | |
RIP interface settings | Version | Specify a RIP version. Options include:
Message reception | Enable or disable RIP packet reception on the interface. | |
Message sending | Enable or disable RIP packet sending on the interface. | |
RIP authentication settings | AuthN mode | Specify a RIPv2 packet authentication mode. Options include:
Although you can specify an authentication mode for RIPv1, the configuration does not take effect because RIPv1 does not support authentication. |
Password | Enter a password. | |
Key ID | Enter an authentication key ID. This parameter is displayed only when you select |
On the
The added interface will be displayed in the interface list.
On the
The created RIP instance will be displayed in the RIP instance list.
