IPv4 (NAT44)
This help contains the following topics:
Introduction
Network Address Translation (NAT) translates an IP address in the IP packet header to another IP address. Typically, NAT is configured on gateways to enable private hosts to access external networks and external hosts to access private network resources such as a Web server.
Dynamic NAT
Dynamic NAT uses an address pool to translate addresses. It applies to the scenario where a large number of internal users access the external network.
NAT Server
The NAT Server feature maps a public address and port number to the private IP address and port number of an internal server. This feature allows servers in the private network to provide services for external users. The following table describes the address-port mappings between an external network and an internal network for NAT Server.
Table-1 Address-port mappings for NAT Server
External network
Internal network
One public address
One private address
One public address and one public port number
One private address and one private port number
One public address and N consecutive public port numbers
  • One private address and one private port number
  • N consecutive private addresses and one private port number
  • One private address and N consecutive private port numbers
N consecutive public addresses
N consecutive public addresses and one public port number
One internal server group
Public addresses matching an ACL
One private address
Public addresses in an address object group
One private address
You can add multiple internal servers to an internal server group for load sharing so that these servers provide the same service for external hosts. The NAT device chooses one internal server based on the weight and number of connections of the servers to respond to a request from an external host to the public address of the internal server group.
Static NAT
Static NAT creates a fixed mapping between a private address and a public address. It supports connections initiated from internal users to external network and from external users to the internal network. Static NAT applies to regular communications.
NAT advanced settings
PAT mapping modes
The following PAT mapping modes are supported:
NAT DNS mappings
With NAT DNS mappings, a user in the internal network can access internal servers by using their domain names when the DNS server is located on the public network. The NAT DNS mapping works in conjunction with NAT server mappings. A NAT DNS mapping maps the domain name of an internal server to the public IP address, public port number, and protocol type of the internal server. A NAT server mapping maps the public IP and port to the private IP and port of the internal server.
The DNS reply from the external DNS server contains only the domain name and public IP address of the internal server in the payload. The NAT interface might have multiple NAT server mappings with the same public IP address but different private IP addresses. DNS ALG might find an incorrect internal server by using only the public IP address. If a NAT DNS mapping is configured, DNS ALG can obtain the public IP address, public port number, and protocol type of the internal server by using the domain name. Then it can find the correct internal server by using the public IP address, public port number, and protocol type of the internal server.
NAT hairpin
NAT hairpin allows internal hosts to access each other through NAT. The source and destination IP address of the packets are translated on the interface connected to the internal network. NAT hairpin works in conjunction with NAT Server and outbound dynamic or static NAT. To provide service correctly, you must configure NAT hairpin on the same interface module as its collaborative NAT feature.
NAT hairpin includes C/S and P2P modes:
NAT global settings
On a WAN network where two output interfaces of the NAT device are in the same security zone, if the link of one interface fails, traffic is switched to the link of the other interface. The NAT device retains old session entries after link switchover. Internal users cannot access the external network because the NAT device uses old session entries to match the user traffic. To avoid this issue, enable NAT session recreation to ensure availability of NAT services. The device will recreate NAT sessions when user traffic arrives.
vSystem support information
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
General restrictions and guidelines
Restrictions and guidelines: Dynamic NAT
You can configure multiple outbound dynamic NAT rules on an interface.
Restrictions and guidelines: Static NAT
Restrictions and guidelines: NAT Server
Configure NAT
NAT can be performed in the inbound or outbound direction.
Figure-1 Inbound NAT
Figure-2 Outbound NAT
Complete the following tasks before you configure this feature:
Configure dynamic NAT
Only outbound dynamic NAT is supported in the current software version. You can configure ACL-based outbound dynamic NAT or object group-based outbound dynamic NAT. Figure-3 shows the configuration procedure for dynamic NAT.
Figure-3 Dynamic NAT configuration procedure
  1. (Optional.) Create a NAT address group.
    1. Click the Objects tab.
    2. In the navigation pane, select Object Groups > NAT Address Groups.
    3. Click Create. For more information, see "Object groups."
    4. Click Apply.
  2. Configure ACL-based dynamic NAT.
    1. Click the Network tab.
    2. In the navigation pane, select Interface NAT > IPv4.
    3. Click the Outbound Dynamic NAT (ACL-Based) tab.
    4. Click Create.
    5. Create an ACL-based outbound dynamic NAT rule, as shown in Table-2.
      Figure-4 Clicking Create
      Figure-5 Creating an ACL-based outbound dynamic NAT rule
      Table-2 Configuration items for ACL-based outbound dynamic NAT
      Item
      Interface to which the NAT rule is applied. Outbound dynamic NAT is typically configured on the interface connected to the external network.
      ACL
      ACL for packet matching. If you specify an ACL, NAT translates the source IP addresses of outgoing packets permitted by the ACL. If you do not specify an ACL, NAT translates all packets.
      Source address after NAT
      Select the NAT address for address translation:
      • NAT address group—IP addresses in the NAT address group are used for address translation.
      • Easy IP—The IP address of the specified interface is used for address translation.
      An address group cannot be used by both PAT and NO-PAT modes.
      VRF
      VRF to which the source addresses belong after translation. The default setting is Public network.
      You must specify this parameter if you deploy outbound dynamic NAT for VPNs. The specified VRF must be the VRF to which the specified interface belongs.
      Translation mode
      Dynamic NAT translation mode:
      • PAT—Uses the IP addresses in the address group or the IP address of the interface to translate IP addresses of the matching packets. Source ports in the matching packets are also translated.
      • NO-PAT—Uses the IP addresses in the address group to translate IP addresses of the matching packets. Source ports in the matching packets are not translated.
      Use original port preferentially
      Try to preserve port number for PAT.
      This option is available only when the translation mode is set to PAT.
      Allow reverse NAT
      Enable reverse address translation. Reverse address translation uses existing NO-PAT entries to translate the destination address for connections actively initiated from the external network to the internal network.
      This option is available only when the translation mode is set to NO-PAT.
      Enable this rule
      Enable this NAT rule.
      Counting
      Enable hit counting for the NAT rule. After you enable this feature, you can view the hit count of the NAT rule.
    6. Click Apply.
  3. Configure object group-based dynamic NAT.
    3. Click the Outbound Dynamic NAT (Object Group-Based) tab.
    4. Click Create.
    5. Create an object group-based outbound dynamic NAT rule, as shown in Table-3.
      Figure-6 Clicking Create
      Figure-7 Creating an object group-based outbound dynamic NAT rule
      Table-3 Configuration items for object group-based outbound dynamic NAT
      Item
      Rule name
      Enter the name of a NAT rule.
      Rule description
      Enter the description of the NAT rule.
      Output interface
      Source IP
      Source IP address object group for the NAT rule.
      You can configure multiple source IP address object groups for a NAT rule. Each source IP object group is an independent packet match criterion.
      Destination IP
      Destination IP address object group for the NAT rule.
      You can configure multiple destination IP address object groups for a NAT rule. Each destination IP object group is an independent packet match criterion.
      Service
      Service object group for the NAT rule.
      You can configure multiple service object groups for a NAT rule. Each service object group is an independent packet match criterion.
      If you configure service object groups, source IP object groups, and destination object groups for a NAT rule, only packets with matching service type, source IP address, and destination IP address are translated.
      Action
      • Easy IP—Uses the IP address of the specified interface for address translation.
      • No translation—Does not translate matching packets.
      NAT address group for source address translation.
      This option is available only when the translation mode is set to PAT or Easy IP.
      Allow reverse NAT
      Enable this rule
    6. Click Apply.
Configure NAT Server
  1. Configure a NAT server rule.
    3. Click the NAT Servers tab.
    4. Click Create.
    5. Create a NAT server rule, as shown in Table-4.
      Figure-8 Clicking Create
      Figure-9 Creating a NAT server rule
      Table-4 NAT server configuration items
      Item
      Rule name
      Enter the name of a NAT server rule.
      Interface to which the NAT server rule is applied. The NAT server rule is typically configured on the interface connected to the external network.
      Protocol type
      Specify a protocol type. If you do not specify a protocol type, the configuration applies to packets of all protocols.
      Mapping
      Select an address-port mapping. For more information, see Table-1.
      Mapping description
      Mapping description for identification when a large number of NAT mappings exist.
      Public IP
      Specify an IP address
      Specify an IP address provided by the internal server for external network access.
      Use primary IP of the interface (Easy IP) as the public IP address of the NAT server
      Specify the IP address of the current interface as the public IP address of the internal server.
      Use primary IP of a Loopback interface as the public IP address of the NAT server
      Specify the IP address of a loopback interface as the public IP address of the server.
      Public port
      Public port number or port range, depending on the mapping method. When you specify a port range, make sure the end port is greater than the start port.
      Public port VRF
      VRF to which the advertised public IP addresses belong. The default setting is Public network.
      Server IP
      Private IP address or address range, depending on the mapping method. In the address range, the end address must be greater than the start address. The number of addresses in the range must equal the number of ports in the public port range.
      Server port
      Private port number or port range, depending on the mapping method. When you specify a port range, make sure the end port is higher than the start port.
      Server VRF
      VRF to which the NAT server belongs. The default setting is Public network.
      If you specify an ACL, NAT translates packets permitted by the ACL. If you do not specify an ACL, NAT translates all packets.
      VRRP group
      Specify a VRRP group for high availability purposes.
      The master device in the VRRP group uses the virtual IP address and virtual MAC address to answer ARP requests.
      Support for the VRRP group feature depends on the device model.
      Allow reverse NAT
      Allow reverse address translation. Reverse address translation applies to connections actively initiated by internal servers to the external network. It translates the private IP addresses of the internal servers to their public IP addresses.
      This option is available only when the mapping type is set to One single public address with one single or no public port.
      Enable this rule
      Enable this NAT server rule.
      Counting
      Enable hit counting for the NAT server rule. After you enable this feature, you can view the hit count of the NAT server rule.
    6. Click Apply.
Configure static NAT
Only outbound static NAT is supported in the current software version. Configure static NAT as shown in Figure-10.
Figure-10 Static NAT configuration procedure
  3. Click the Static NAT tab.
  4. Click Create.
  5. Create a static NAT mapping.
    Figure-11 Clicking Create
    Figure-12 Creating a static NAT mapping
    Table-5 Static NAT configuration items
    Item
    Translation method
    Select an address translation method:
    • One-to-one—Performs address translation from a private IP address to a public IP address.
    • Net-to-net—Performs address translation from a private network to a public network
    Private address
    Private IP address. The parameter setting depends on the translation method.
    Private VRF
    VRF to which the private IP address belongs. The default setting is Public network.
    Public address
    Public IP address. The parameter setting depends on the translation method.
    Public VRF
    VRF to which the public IP address belongs. The default setting is Public network.
    ACL
    Specify an ACL to define the destination IP addresses that internal hosts can access.
    VRRP group
    Allow reverse NAT
    Allow reverse address translation. Reverse address translation applies to connections actively initiated by external hosts to the internal host. It uses the mapping to translate the destination address for packets of these connections if the packets are permitted by ACL reverse matching.
    Enable this rule
    Enable this static NAT rule.
    Counting
    Enable hit counting for the static NAT rule. After you enable this feature, you can view the hit count of the static NAT rule.
  6. Click Apply.
  7. Click Policy Apply.
    Figure-13 Clicking Policy Apply
    Figure-14 Policy application page
  8. Select one or multiple interfaces.
  9. Click Enable.
Configure advanced NAT settings
Configure NAT DNS mappings
  3. Click the NAT DNS Mappings tab.
  4. Click Create to add a new mapping entry for a domain name to the internal server.
    Figure-15 Clicking Create
    Figure-16 Creating a NAT DNS mapping
    Table-6 NAT DNS mapping configuration items
    Item
    Domain name
    Specify a domain name for the internal server.
    Internal server running protocol
    Select a running protocol for the internal server:
    • TCP.
    • UDP.
    Public IP
    Easy IP
    Specify the IP address of a loopback interface as the public IP address of the internal server.
    Public port number
    Specify a public port number for the internal server.
  5. Click Apply.
Configure NAT Hairpin
Enable NAT hairpin on the interface connected to the internal network to allow internal hosts to access each other through NAT.
  3. Click the NAT Hairpin tab.
  4. Select an interface.
  5. Click Enable to enable NAT Hairpin on the selected interface.
    Figure-17 Enabling NAT hairpin on the selected interface
Configure general settings
  3. Click the General Settings tab.
  4. Select Nat session reconstruction under double exists.
  5. Click Apply.
    Figure-18 Enabling NAT session recreation
Configure PAT mode
  4. Select a PAT mapping mode. Options include Address and Port-Dependent Mapping (APDM) and Endpoint-Independent Mapping (EIM).
  5. Click Apply.
    Figure-19 Selecting a PAT mapping mode
