Application load statistics
This help contains the following topics:
Introduction
Virtual server statistics
Real-time statistics
You can display real-time statistics for virtual servers.
Table-1 shows the information displayed on the virtual sever statistics page.
Table-1 Virtual server statistics
Item
Virtual server name
Virtual server for which the statistics information is displayed.
Virtual server state:
  • Available.
  • Unavailable.
  • Disabled.
Connection count
Active
Number of active connections for the virtual server.
New
Average number of connections established with the virtual server per second.
Half-open
Number of half-open connections between the virtual server and client. This field is displayed for only TCP virtual servers.
Bandwidth (Kbps)
Outbound
Outbound bandwidth of the virtual server.
Inbound
Inbound bandwidth of the virtual server.
Click SSL offloading capability statistics to display SSL offloading real-time statistics.
Table-2 SSL offloading statistics
Item
New connections
Number of new SSL offloading connections per second.
Active connections
Number of active SSL offloading connections.
Inbound bandwidth(bps)
Inbound bandwidth of SSL offloading.
Outbound bandwidth(bps)
Outbound bandwidth of SSL offloading.
Trends
This page displays the virtual server statistics over time.
You can specify the virtual server scope and statistics duration in the Statistics conditions section to display the following information:
To view virtual server trend statistics, you must first enable Load balancing | Virtual server trend statistics, Load balancing | Virtual server trend statistics(Web cache), Load balancing | Virtual server trend statistics(HTTP information), and Load balancing | Virtual server trend statistics(server status) on the System > Log Settings > Storage Space Settings page.
  1. Click the Monitor tab.
  2. In the navigation pane, select Trends > Virtual Server Trends.
  3. Click Select widgets and select one or multiple of the following trends:
    • Select Traffic trend to view the traffic trend of the specified virtual servers over time.
      Click the Set icon in the upper right corner of the widget to specify a traffic direction. Options are:
      • Uplink: Displays the uplink traffic of the specified virtual servers over time.
      • Downlink: Displays the downlink traffic of the specified virtual servers over time.
      • Total: Displays the total traffic of the specified virtual servers over time.
    • Select New connections trend to view the average number of connections established with the specified virtual servers per second.
    • Select Concurrent connections trend to view the number of active connections for the specified virtual servers.
    • Select Stability trend to view the stability trend of the specified virtual server.
      This widget displays the stability trend of only one virtual server.
    • Select Traffic compression ratio to view the ratio of compressed response traffic to the total response traffic on the specified virtual servers.
    • Select HTTP status code to view the status codes in the redirection messages that the specified virtual servers return.
    • Select Cache policy memory usage to view the ratio of the memory used by cache files to the idle memory space on the specified virtual server.
      This widget displays the memory usage of the cache policy on only one virtual server.
    • Select Cache policy hit ratio to view the ratio of r cache policy hits by requests to the total number of requests on the specified virtual servers over time.
    • Select Matching traffic ratio of cache policy to view the ratio of response traffic that matches the cache policy to the total response traffic on the specified virtual servers.
  4. Click Statistics conditions to set the conditions as shown in Table-3.
    Table-3 Virtual server statistics conditions
    Item
    Auto refresh
    Enable or disable auto refresh for the trend statistics page.
    After you enable this function, the device will automatically refresh the trend statistics page at the specified refresh intervals.
    Refresh interval
    Specify the interval to automatically refresh the trend statistics page.
    Virtual server scope
    Specify the virtual server scope for collecting trend statistics. Options are:
    • Top 3 virtual servers: Displays trend statistics for only the top 3 virtual servers.
    • Specify virtual servers: Displays trend statistics for the specified virtual servers.
    Duration
    Specify the duration for collecting trend statistics. Options are:
    • Last 10 minutes
    • Last hour
    • Last day
    • Last week
    • Last 30 days
    • Customize: You must set a specific duration.
  5. Click Start to enable the device to collect virtual server statistics based on the specified statistics conditions and display the trends.
Server farm statistics
Table-4 shows the information displayed on the sever farm statistics page.
Table-4 Server farm statistics
Item
Server farm name
Server farm for which the statistics information is displayed.
Server farm state:
  • Available.
  • Unavailable.
Total real servers
Total number of real servers in the server farm.
Available real servers
Number of available real servers in the server farm.
Connection count
Active
Number of active connections for the server farm.
New
Average number of connections established with the server farm per second.
Total
Total number of connections for the server farm.
Total bandwidth (Kbps)
Total bandwidth of the server farm.
Packet count
Received
Number of packets received by the server farm.
Sent
Number of packets sent by the server farm.
Dropped
Number of packets dropped by the server farm.
HTTP packets
Received requests
Number of HTTP requests received by the server farm.
Dropped requests
Number of HTTP requests dropped by the server farm.
Sent responses
Number of HTTP responses sent by the server farm.
Dropped responses
Number of HTTP responses dropped by the server farm.
Traffic (bits)
Received
Data traffic received by the server farm.
Sent
Data traffic sent by the server farm.
Trends
This page displays the server farm statistics over time.
You can first select one or multiple trends in the Select widgets list, and then specify the server farm scope and statistics duration in the Statistics conditions section to view the selected trends.
To view server farm trend statistics, you must first enable Load balancing | Server farm trend statistics and Load balancing | Server farm trend statistics(server farm status) on the System > Log Settings > Storage Space Settings page.
  2. In the navigation pane, select Trends > Server Farm Trends.
    • Select Traffic trend to view the traffic trend of the specified server farms over time.
      • Uplink: Displays the uplink traffic of the specified server farms over time.
      • Downlink: Displays the downlink traffic of the specified server farms over time.
      • Total: Displays the total traffic of the specified server farms over time.
    • Select New connections trend to view the average number of connections established with the specified server farms per second.
    • Select Concurrent connections trend to view the number of active connections for the specified server farms.
    • Select Stability trend to view the stability trend of the specified server farm.
      This widget displays the stability trend of only one server farm.
  4. Click Statistics conditions to set the conditions as shown in Table-5.
    Table-5 Server farm statistics conditions
    Item
    Auto refresh
    Refresh interval
    Server farm scope
    Specify the server farm scope for collecting trend statistics. Options are:
    • Top 3 server farms: Displays trend statistics for only the top 3 server farms.
    • Specify server farms: Displays trend statistics for the specified server farms.
    Duration
    • Last 10 minutes
    • Last hour
    • Last day
    • Last week
    • Last 30 days
  5. Click Start to enable the device to collect server farm statistics based on the specified statistics conditions and display the trends.
Real server statistics
Table-6 shows the information displayed on the real sever statistics page.
Table-6 Real server statistics
Item
Real server name
Real server for which the statistics information is displayed.
  • Available.
  • Unavailable.
  • Service slow offline.
  • Service disabled.
  • Probe failed.
  • Ramp-up phase of slow online.
  • Busy.
  • Unknown.
IPv4 address
IPv4 address of the real server.
IPv6 address
IPv6 address of the real server.
Domain name
Domain name of the real server.
Connection count
Active
Number of active connections for the real server.
New
Average number of connections established with the real server per second.
Bandwidth (Kbps)
Outbound
Outbound bandwidth of the real server.
Inbound
Inbound bandwidth of the real server.
Trends
This page displays the real server statistics over time.
You can first select one or multiple trends in the Select widgets list, and then specify the real server scope and statistics duration in the Statistics conditions section to view the selected trends.
To view real server trend statistics, you must first enable Load balancing | Real server trend statistics and Load balancing | Real server trend statistics(Server status) on the System > Log Settings > Storage Space Settings page.
  2. In the navigation pane, select Trends > Real Server Trends.
    • Select Traffic trend to view the traffic trend of the specified real servers over time.
      • Uplink: Displays the uplink traffic of the specified real servers over time.
      • Downlink: Displays the downlink traffic of the specified real servers over time.
      • Total: Displays the total traffic of the specified real servers over time.
    • Select New connections trend to view the average number of connections established with the specified real servers per second.
    • Select Concurrent connections trend to view the number of active connections for the specified real servers.
    • Select Stability trend to view the stability trend of the specified real server.
      This widget displays the stability trend of only one real server.
    • Select HTTP delay trend to view the HTTP delay trend of the specified real servers over time. HTTP delay is the packet processing time on a real server. The lower the HTTP delay, the better the performance of the real server.
  4. Click Statistics conditions to set the conditions as shown in Table-7.
    Table-7 Real server statistics conditions
    Item
    Auto refresh
    Refresh interval
    Real server scope
    Specify the real server scope for collecting trend statistics. Options are:
    • Top 3 real servers: Displays trend statistics for only the top 3 real servers.
    • Specify real servers: Displays trend statistics for the specified real servers.
    Duration
    • Last 10 minutes
    • Last hour
    • Last day
    • Last week
    • Last 30 days
  5. Click Start to enable the device to collect real server statistics based on the specified statistics conditions and display the trends.
URL visit statistics
The URL visit statistics shows the statistics of URLs accessed by users in a bar chart, pie chart, or list.
The administrator can set statistics conditions to rank URLs by virtual server or statistics node. Table-8 shows the statistics conditions.
Table-8 URL visit statistics conditions
Item
Virtual server name
Counts the total number of URL accesses to a virtual server.
Statistics node name
Counts the total number of URL accesses to an HTTP statistics node that belongs to the specified virtual server.
Statistics period
Specifies the time period for collecting the total URL visit statistics.
Click Start to enable the device to collect URL visit statistics and rank URL accesses based on the specified statistics conditions.
TopN URL visit trends
The URL visit trends display information including the visit peak time ranges and the number of visits on URLs.
You can set statistics conditions to view URL visit trends for virtual servers, statistics nodes, and visit sources. Table-9 shows the statistics conditions.
Table-9 Statistics conditions for URL visit trends
Item
Statistics object
Select a statistics object:
  • Virtual server.
  • Statistics node.
  • Visit source.
Time range
Specify the time range for collecting the URL visit statistics.
Table-10 URL visit trend statistics conditions for virtual servers
Item
Query scope
Select a query scope:
  • Top 5 virtual servers—Provide URL visit trends for the top five most visited virtual servers.
  • Specify virtual servers—Provide URL visit trends for the specified virtual servers.
Virtual server name
Names of the virtual servers for which the URL visit trends are displayed.
This parameter is supported only when the query scope is Specify virtual servers.
Table-11 URL visit trend statistics conditions for statistics nodes
Item
Virtual server name
Specifies a virtual server to obtain the URL visit trends for the statistics nodes on the virtual server.
Query scope
  • Top 5 statistics nodes—Provide URL visit trends for the top five most visited statistics nodes on the specified virtual server.
  • Specify statistics nodes—Provide URL visit trends for the specified statistics nodes on the specified virtual server.
Names of the statistics nodes for which the URL visit trends are displayed.
This parameter is supported only when the query scope is Specify statistics nodes.
Table-12 URL visit trend statistics conditions for visit sources
Item
Virtual server name
Name of the virtual server visited by the visit sources.
Name of the statistics node visited by the visit sources.
Query scope
  • Top 5 visit sources—Display URL visit trends for the top five visit sources that visited URLs most.
  • Specify visit sources—Display URL visit trends for the specified visit sources.
Visit source name
Source address object group names or source IP addresses for which the URL visit trends are displayed.
This parameter is supported only when the query scope is Specify visit sources.
Click Start to enable the device to collect URL visit statistics based on the specified statistics conditions.
HTTP protection statistics
The HTTP protection statistics page shows attack record statistics and attack rankings in a bar chart or a list to help you understand the protection results of protection policies.
Attack records
The Attack Records tab displays information about attack traffic matching a protection policy, including attack duration, source IP address, URL, virtual server name, cookie name, protection action, attack times, and context.
You can click the icon for each column to specify criteria to filter attack records. You can also click Export to Excel to download the attack records on the current page.
Attack ranking
You can set statistics conditions to rank attack traffic. Table-13 shows the supported statistics conditions.
Table-13 Attack traffic statistics conditions
Item
Ranking
Specifies the top N ranking: Top 5 or Top 10.
Count by
Specifies the counting type:
  • Source IP address.
  • URL.
Duration
Specifies the duration for collecting the total attack traffic statistics.
Click Start to enable the device to collect attack traffic statistics and rank attack traffic based on the specified statistics conditions.
vSystem support information
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
