Blacklist
This help contains the following topics:
Introduction
IP blacklist
The IP blacklist feature is an attack prevention method that uses the source or destination IP addresses to filter packets.
If the global blacklist feature is enabled, the blacklist feature is enabled on all interfaces.
Compared with ACL-based packet filtering, IP blacklist filtering is simpler and provides effective screening at a faster speed.
Blacklist entries can be manually added or dynamically learned:
Address object group blacklist
The address object group blacklist feature is an attack prevention method that filters packets by address object group. The address object group blacklist feature must be used together with the address object group feature. An address object group is a set of IP address objects. Compared with IP blacklist filtering, address object group blacklist filtering performs access control for subnets and improves the filtering usability. For more information about object groups, see the help for object groups.
vSystem support information
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Configure the blacklist
Analysis
Configure the blacklist as shown in Figure-1.
Figure-1 Blacklist configuration procedure
Complete the following tasks before you configure this feature:
Configure access control based on the IP blacklist
Use this feature to filter packets by IP addresses in blacklist entries.
  1. Click the Network tab.
  2. In the navigation pane, select Active Defense > Blacklist.
  3. Click the IP Blacklist tab.
  4. Click Create.
  5. Add an IP blacklist entry.
    Figure-2 Adding an IP blacklist entry
    Table-1 IP blacklist configuration items
    Item
    VRF
    VRF to which the blacklist entry belongs. You can select an existing VRF or create a new one. The newly created VRF will be displayed on the Network > Interface Configuration > VRF page.
    IP version
    Version of the IP address. Options are:
    • IPv4.
    • IPv6.
    Match field
    Packet field to compare with the criterion:
    • Source IP.
    • Destination IP.
    IP address
    IP address in the blacklist entry. Packets sourced from or destined to the IP address will be dropped.
    Aging time (sec)
    Aging time of the blacklist entry. If you do not set the aging time, the blacklist entry never ages out. You must delete it manually.
    Comment
    Description for the IP blacklist entry.
  6. To import IP blacklist entries, select Import/Export > Import file.
  7. On the page that opens, configure the following items:
    Figure-3 Importing IP blacklist entries
    Table-2 Configuration items for importing IP blacklist entries
    Item
    IP Type
    IP address type for packet matching. Packets sourced from or destined to the IP addresses will be dropped. Options are:
    • Source IP.
    • Destination IP.
    VRF
    VRF to which the blacklist entries belong. You can select an existing VRF or create a new one. The newly created VRF will be displayed on the Network > Interface Configuration > VRF page.
    File Path
    Select the file to be imported and the file path is displayed in this field.
    Comment
    Description for the IP blacklist entries.
  8. Click Apply. The IP Blacklist page displays the newly added IP blacklist entries and imported IP blacklist entries.
  9. Click Enable globally. The IP blacklist takes effect on all interfaces.
Configure access control based on the address object group blacklist
Use this feature to filter packets by address object groups in blacklist entries.
  3. Click the Address Object Group Blacklist tab.
  4. Click Create.
  5. Add an address object group blacklist entry.
    Figure-4 Adding an address object group blacklist entry
    Table-3 Address object group blacklist configuration items
    Item
    Object group type
    Select a type of address object groups, IPv4 or IPv6.
    Object group name
    Name of an address object group. You can select an existing object group or create one. To view the newly created object group, navigate to the Objects > Object Groups > IPv4 Address Object Groups or IPv6 Address Object Groups page.
  6. Click Apply. The Address Object Group Blacklist page displays the newly added address object group blacklist.
  7. Click Enable globally. The address object group blacklist takes effect on all interfaces.
Configure access control based on the dynamic blacklist entries added by scanning attack defense
IP blacklist entries can also be automatically added when the blacklist feature collaborates with scanning attack defense. Make sure adding the attacker's IP address to the IP blacklist is specified as the scanning attack prevention action. For more information about scanning attack defense, see "Attack defense."
  1. On the IP Blacklist or Address Object Group Blacklist tab, click Enable globally. The blacklist takes effect on all interfaces.
  2. Click the Network tab.
  3. In the navigation pane, select Active Defense > Attack Defense Policies.
  4. Click Create. On the page that opens, click the Scanning Attack Defense tab. Select an option (except for Close) from the Detection sensitivity list, configure the related parameters, and then turn on the Add attackers' IP addresses to blacklist feature.
    Figure-5 Adding an attack defense policy
    Table-4 Configuration items for a scanning attack defense policy
    Item
    Scanning attack detection level:
    • Close—Disables the scanning attack defense.
    • Low—Specifies the low level. This level provides basic scanning attack detection and has a low false alarm rate, but many scanning attacks cannot be detected.
    • Medium—Specifies the medium level. Compared with the high and low levels, this level has medium false alarm rate and attack detection accuracy.
    • High—Specifies the high level. This level can detect most of the scanning attacks, but has a high false alarm rate. Some packets from active hosts might be considered as attack packets.
    • User-defined—Specifies the user-defined level. You can set a threshold for scanning attack prevention.
    Configure the following parameters as needed:
    • Enable port scan attack prevention—This feature is enabled when Detection sensitivity is set to Low, Medium, or High. You can determine whether to enable this feature when Detection sensitivity is set to User-defined.
    • Threshold (packets)—Threshold that triggers port scanning attack prevention. The value is 100000 for the low detection sensitivity level, 40000 for the medium detection sensitivity level, and 5000 for the high detection sensitivity level. You can specify a threshold when Detection sensitivity is set to User-defined. This parameter is not displayed when Detection sensitivity is disabled.
    • Enable address scan attack prevention—This feature is enabled when Detection sensitivity is set to Low, Medium, or High. You can determine whether to enable this feature when Detection sensitivity is set to User-defined.
    • Threshold (packets)—Threshold that triggers address scanning attack prevention. The value is 100000 for the low detection sensitivity level, 40000 for the medium detection sensitivity level, and 5000 for the high detection sensitivity level. You can specify a threshold when Detection sensitivity is set to User-defined. This parameter is not displayed when Detection sensitivity is disabled.
    • Detection cycle—Scanning attack detection cycle. The detection period is 10 seconds when Detection sensitivity is set to Low, Medium, or High. You can specify a detection cycle when Detection sensitivity is set to User-defined. This parameter is not displayed when Detection sensitivity is disabled.
    Actions
    Prevention actions against scanning attacks.
    • Generate logs.
    • Drop attack packets.
    • Add attackers' IP addresses to blacklist.
    • Age out after n minutes—Aging time for the dynamically added blacklist entries. This parameter is available only when Add attackers' IP addresses to blacklist is selected.
    Prevention actions are not available when Detection sensitivity is disabled.
  5. Click Apply. After the device detects a scanning attack based on the behavior characteristics of packets from a specific IP address, it automatically adds the attacker's IP address to the blacklist and filters out subsequent packets sent from the IP address. You can view the IP address on the IP Blacklist tab.
