This help contains the following topics:
Border Gateway Protocol (BGP) is an exterior gateway protocol (EGP). It is called internal BGP (IBGP) when it runs within an AS and called external BGP (EBGP) when it runs between ASs. As shown in Figure-1, EBGP runs between Router A and Router B, and IBGP runs between Router B and Router C. An AS refers to a group of routers that use the same routing policy and work under the same administration.
The current version in use is BGP-4. It is widely used by Internet Service Providers (ISPs).
A router running BGP is a BGP speaker. A BGP speaker establishes peer relationships with other BGP speakers to exchange routing information over TCP connections.
BGP peers include the following types:
| If you create a BGP peer without selecting an address family for it, the BGP peer remains in idle state. It does not attempt to establish peer relationships through Open messages. |
BGP-4 can only advertise IPv4 unicast routing information.
Multiprotocol Extensions for BGP-4 (MP-BGP) can advertise routing information for the following address families:
IPv6 unicast address family.
IPv4 multicast address family and IPv6 multicast address family.
PIM uses static and dynamic unicast routes to perform RPF check before creating multicast routing entries. When the multicast and unicast topologies are different, you can use MP-BGP to advertise the routes for RPF check. MP-BGP stores the routes in the BGP multicast routing table.
IPv4 MDT address family.
MP-BGP advertises MDT information including the PE address and default group so that multicast VPN can create a default MDT that uses the PE as the root on the public network. For more information about multicast VPN, see
Inject a local network. Perform this task to inject a network in the local routing table to the BGP routing table, so BGP can advertise the network to BGP peers. The ORIGIN attribute of BGP routes advertised in this way is IGP. You can also use a routing policy to control route advertisement.
| The specified network must be available and active in the local IP routing table. |
Redistribute IGP routes: Perform this task to configure route redistribution from an IGP to BGP.
By default, BGP does not redistribute default IGP routes. You can configure BGP to redistribute default IGP routes into the BGP routing table.
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Before you perform operations on the
For a device with BGP configuration, if you clear the
Configure BGP as shown in Figure-2.
Figure-2 BGP configuration procedure
Complete the following tasks before you configure this feature:
Assign IP addresses to interfaces on the
BGP is a distance vector routing protocol that implements inter-AS route reachability and optimal route selection. It is an exterior gateway protocol and is widely used between ISPs.
Navigate to the
Select
Figure-3 BGP configuration
Table-1 BGP state configuration items
Item | Description |
Enable BGP | Select whether to enable BGP. |
AS Number | Specify an AS number for AS identification. |
Specify BGP address families as needed. You can then perform address family-specific configuration. |
Navigate to the
Click the
Configure the BGP peer settings as needed.
Figure-4 Creating a BGP peer
Table-2 BGP peer configuration items
Peer IP Address | Specify the IPv4 address of the peer. |
AS Number | Specify the AS number of the peer.
MD5 Authentication | Configure MD5 authentication settings to enhance BGP data security. |
Click
Navigate to the
Click the
Configure BGP network settings as needed.
Figure-5 Creating a BGP network
Table-3 BGP network configuration items
Click
Navigate to the
Click the
Configure the following BGP route redistribution settings as needed:
Figure-6 Creating a BGP route redistribution rule
Table-4 BGP route redistribution configuration items
Address Family | Specify a BGP address family view. |
Protocol | Specify an IGP as needed. BGP can then redistribute routes from the specified IGP to the BGP routing table and advertise these routes to peers. |
Process ID | Specify an IGP process by its ID. If the protocol is IS-IS, IPv6 IS-IS, OSPF, OSPFv3, RIP, or RIPng, and you do not specify a process, BGP redistributes routes from process 1. |
