This help contains the following topics:
You can enable ALG for the specified application protocol type to analyze and process the application layer packet payload. On the device, you can enable ALG for the following services:
NAT ALG
NAT44 supports ALG for the following protocols:
DNS.
SIP.
XDMCP.
PPTP.
SUNRPC.
FTP.
TFTP.
ILS.
RSH.
ICMP error packets.
RTSP.
MGCP.
SCCP.
H.323.
SQLNET.
NBT.
SCTP.
NAT64 supports ALG for the following protocols:
DNS.
FTP.
ICMP error packets.
HTTP.
SIP.
RTSP.
H.323.
NAT66 supports ALG for the following protocols:
FTP.
DNS.
H.323.
HTTP.
SIP.
RTSP.
SUN RPC.
TFTP.
LB ALG
LB LAG supports ALG for the following protocols:
DNS.
H.323.
RTSP.
ILS.
PPTP.
FTP.
SIP.
SQLNET.
MGCP.
RSH.
ICMP error packets.
TFTP.
XDMCP.
NBT.
SCCP.
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Support of protocols for this feature depends on the device model. This feature is available for a protocol on the Web interface only if it is supported by that protocol.
Complete the following tasks before you configure this feature:
Assign IP addresses to interfaces on the
Configure routes on the
To configure ALG:
Click the
In the navigation pane, select
Select protocols to be enabled with ALG.
Support for protocols varies by device model.
Figure-1 Enabling ALG for the specified protocols
Click
