As shown in Figure-1, the company has public addresses 200.2.2.1/24 to 200.2.2.3/24. Configure NO-PAT translation to enable hosts in the internal network to access the server on the Internet.
This configuration example was created and verified on R9900P2705 of the F5000-AI-55-G device.
Do not configure both the NAT translation methods and a global NAT policy.
Assign IP addresses to interfaces and add the interfaces to security zones.
# On the top navigation bar, click
# From the navigation pane, select
# Click the
# In the dialog box that opens, configure the interface:
Select the
On the
Click
# Add GE 1/0/2 to the
Configure settings for routing.
This example configures a static route. If dynamic routes are required, configure a dynamic routing protocol.
# On the
# In the dialog box that opens, configure a static route to permit packets from the internal hosts to the external server:
Specify the IP address of the server as the destination IP. In this example, the address is 100.100.100.100.
Enter the mask length. In this example, enter 24.
Specify the next-hop address as 200.2.2.253.
Click
Configure a security policy.
# Click
# In the dialog box that opens, configure policy parameters as follows:
Enter a policy name. In this example, the name is
Select the source zone. In this example, the source zone is Trust.
Select the destination zone. In this example, the destination zone is Untrust.
Select
Select
Specify the IP addresses of the hosts as the source IPv4 addresses. In this example, the addresses are 172.16.100.1, 172.16.100.2, 172.16.100.3.
Specify the IP address of the server as the destination IPv4. In this example, the address is 100.100.100.100.
Click
Configure a NAT address group.
# Click
# Create a NAT address group, as shown in Figure-2.
Figure-2 Creating a NAT address group
# Click
Configure an outbound dynamic NAT rule.
# On the
# Create an outbound dynamic NAT rule, as shown in Figure-3.
Figure-3 Creating an outbound dynamic NAT rule
# Click
Verify that the host can successfully ping the server on the external network.
C:\Users\abc>ping 100.100.100.100
Pinging host.com [100.100.100.100] with 32 bytes of data:
Reply from 100.100.100.100: bytes=32 time<1ms TTL=253
Ping statistics for 100.100.100.100:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Verify that a NAT session is generated when the host accesses the server.
Figure-4 Session list
