As shown in Figure-1, the device connects the LAN and the Internet. The LAN resides in security zone
Configure the device to decrypt the HTTPS traffic and perform deep packet inspection on the traffic.
This configuration example was created and verified on R9900P2705 of the F5000-AI-55-G device.
Assign IP addresses to interfaces:
# Assign an IP address to interface GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] ip address 192.168.1.1 255.255.255.0
Configure settings for routing.
This example configures static routes, and the next hop in the routes is 2.2.2.2.
[Device] ip route-static 5.5.5.0 24 2.2.2.2
Add interfaces to security zones.
[Device] security-zone name trust
[Device-security-zone-Trust] import interface gigabitethernet 1/0/1
[Device] security-zone name untrust
[Device-security-zone-Untrust] import interface gigabitethernet 1/0/2
[Device-security-zone-Untrust] quit
Create an IP address object group named
[Device] object-group ip address obj1
[Device-obj-grp-ip-obj1] network subnet 192.168.1.0 24
[Device-obj-grp-ip-obj1] quit
Import CA certificate
[Device] app-proxy ssl-decrypt-certificate import trust pem filename trust.pem
[Device] app-proxy ssl-decrypt-certificate import untrust pem filename untrust.pem
Install CA certificate
Create proxy policy rule
[Device] app-proxy-policy
[Device-app-proxy-policy] rule 1 name https
[Device-app-proxy-policy-rule-1-https] source-zone trust
[Device-app-proxy-policy-rule-1-https] destination-zone untrust
[Device-app-proxy-policy-rule-1-https] source-ip object-group obj1
[Device-app-proxy-policy-rule-1-https] service object-group https
[Device-app-proxy-policy-rule-1-https] action ssl-decrypt
[Device-app-proxy-policy-rule-1-https] quit
[Device-app-proxy-policy] quit
Configure URL filtering:
# Create user-defined URL category
[Device] url-filter category https severity 1001
[Device-url-filter-category-https] rule host text www.baidu.com
[Device-url-filter-category-https] quit
# Create a URL filtering policy named
[Device] url-filter policy p1
[Device-url-filter-policy-p1] category https action reset logging
[Device-url-filter-policy-p1] quit
Apply URL filtering policy
# Create a DPI application profile named
[Device] app-profile sec
[Device-app-profile-sec] url-filter apply policy p1
[Device-app-profile-sec] quit
# Activate the URL filtering policy and rule settings.
[Device] inspect activate
Configure a security policy:
# Create a security policy rule named
[Device] security-policy ip
[Device-security-policy-ip] rule name trust-untrust
[Device-security-policy-ip-10-trust-untrust] source-zone trust
[Device-security-policy-ip-10-trust-untrust] source-ip-subnet 192.168.1.0 24
[Device-security-policy-ip-10-trust-untrust] destination-zone untrust
[Device-security-policy-ip-10-trust-untrust] action pass
[Device-security-policy-ip-10-trust-untrust] profile sec
[Device-security-policy-ip-10-trust-untrust] quit
[Device-security-policy-ip] rule name untrust-trust
[Device-security-policy-ip-11-untrust-trust] source-zone untrust
[Device-security-policy-ip-11-untrust-trust] destination-zone trust
[Device-security-policy-ip-11-untrust-trust] destination-ip-subnet 192.168.1.0 24
[Device-security-policy-ip-11-untrust-trust] action pass
[Device-security-policy-ip-11-untrust-trust] profile sec
[Device-security-policy-ip-11-untrust-trust] quit
# Create two security policy rules named
[Device-security-policy-ip] rule name proxyserverlocalin
[Device-security-policy-ip-12-proxyserverlocalin] source-zone trust
[Device-security-policy-ip-12-proxyserverlocalin] source-ip-subnet 192.168.1.0 24
[Device-security-policy-ip-12-proxyserverlocalin] destination-zone local
[Device-security-policy-ip-12-proxyserverlocalin] action pass
[Device-security-policy-ip-12-proxyserverlocalin] quit
[Device-security-policy-ip] rule name proxyserverlocalout
[Device-security-policy-ip-13-proxyserverlocalout] source-zone local
[Device-security-policy-ip-13-proxyserverlocalout] destination-zone trust
[Device-security-policy-ip-13-proxyserverlocalout] destination-ip-subnet 192.168.1.0 24
[Device-security-policy-ip-13-proxyserverlocalout] action pass
[Device-security-policy-ip-13-proxyserverlocalout] quit
[Device-security-policy-ip] rule name proxyclientlocalin
[Device-security-policy-ip-14-proxyclientlocalin] source-zone untrust
[Device-security-policy-ip-14-proxyclientlocalin] destination-zone local
[Device-security-policy-ip-14-proxyclientlocalin] destination-ip-subnet 192.168.1.0 24
[Device-security-policy-ip-14-proxyclientlocalin] action pass
[Device-security-policy-ip-14-proxyclientlocalin] quit
[Device-security-policy-ip] rule name proxyclientlocalout
[Device-security-policy-ip-15-proxyclientlocalout] source-zone local
[Device-security-policy-ip-15-proxyclientlocalout] source-ip-subnet 192.168.1.0 24
[Device-security-policy-ip-15-proxyclientlocalout] destination-zone untrust
[Device-security-policy-ip-15-proxyclientlocalout] action pass
[Device-security-policy-ip-15-proxyclientlocalout] quit
# Activate rule matching acceleration.
[Device-security-policy-ip] accelerate enhanced enable
[Device-security-policy-ip] quit
Verify that the device can deny HTTPS requests to www.baidu.com and generate logs. You can also execute the
SSL server certificates received by the device as the SSL proxy client.
Number of times connections to the server had been proxied.
Most recent time the device proxied a connection to the server.
First time the device proxied a connection to the server.
0 network subnet 192.168.1.0 255.255.255.0
ip address 2.2.2.1 255.255.255.0
security-zone name Trust
import interface GigabitEthernet1/0/1
security-zone name Untrust
import interface GigabitEthernet1/0/2
rule 1 host text www.baidu.com
app-profile sec
inspect activate
app-proxy-policy
rule 1 name https
source-zone trust
action ssl-decrypt
security-policy ip
rule 0 name trust-untrust
action pass
profile sec
source-zone trust
source-ip-subnet 192.168.1.0 255.255.255.0
rule 1 name untrust-trust
action pass
profile sec
source-zone untrust
destination-ip-subnet 192.168.1.0 255.255.255.0
rule 2 name proxyserverlocalin
action pass
source-zone trust
rule 3 name proxyserverlocalout
action pass
source-zone local
rule 4 name proxyclientlocalin
action pass
source-zone untrust
rule 5 name proxyclientlocalout
action pass
source-zone local
