CLI example: Configuring the HA group in dual-active mode in collaboration with a routing protocol (IPv6)
As shown in Figure-1, set up the HA group at the border between the Internet and the internal network of an enterprise to ensure service continuity.
Figure-1 Network diagram
Software versions used
This configuration example was created and verified on R9900P2705 of the F5000-AI-55-G device.
Hardware environment consistency
Before you configure hot backup, verify that the following hardware settings are the same on the devices to be assigned to a hot backup system:
Software environment consistency
Before you configure hot backup, verify that the following software settings are the same on the devices to be assigned to a hot backup system:
Procedures
Configure Router A
  1. Configure IPv6 addresses for interfaces.
    # Assign an IPv6 address to GigabitEthernet 1/0/7.
    [RouterA] interface gigabitethernet 1/0/7
    [RouterA-GigabitEthernet1/0/7] ipv6 address 3003::2/64
    [RouterA-GigabitEthernet1/0/7] quit
  2. Specify 3007::15/64 as the next hop of the route to the Internet.
    [RouterA] ipv6 route-static 0::0 64 3007::15
  3. Configure OSPFv3 on the device, and use the default OSPFv3 link cost as a best practice.
    [RouterA] ospfv3 1
    [RouterA-ospfv3-1] router id 1.1.1.1
    [RouterA-ospfv3-1] quit
    [RouterA-GigabitEthernet1/0/7] ospfv3 1 area 0
    [RouterA] interface gigabitethernet 1/0/8
    [RouterA-GigabitEthernet1/0/8] ospfv3 1 area 0
    [RouterA-GigabitEthernet1/0/8] quit
  4. Configure per-flow load sharing.
    [RouterA] ip load-sharing mode per-flow global
Configure Router B
    <RouterB> system-view
    [RouterB] interface gigabitethernet 1/0/7
    [RouterB-GigabitEthernet1/0/7] ipv6 address 3001::2/64
    [RouterB-GigabitEthernet1/0/7] quit
  2. Configure OSPFv3 on the device, and use the default OSPFv3 link cost as a best practice.
    [RouterB] ospfv3 1
    [RouterB-ospfv3-1] router id 4.1.1.1
    [RouterB-ospfv3-1] quit
    [RouterB-GigabitEthernet1/0/7] ospfv3 1 area 0
    [RouterB] interface gigabitethernet 1/0/8
    [RouterB-GigabitEthernet1/0/8] ospfv3 1 area 0
    [RouterB-GigabitEthernet1/0/8] quit
    [RouterB] interface gigabitethernet 1/0/9
  3. Configure per-flow load sharing.
    [RouterB] ip load-sharing mode per-flow global
Configure Device A
    # Assign an IPv6 address to GigabitEthernet 1/0/1.
    [DeviceA-GigabitEthernet1/0/1] ipv6 address 3003::1/64
    [DeviceA-GigabitEthernet1/0/1] ipv6 address auto link-local
  2. Add interfaces to security zones.
    [DeviceA] security-zone name untrust
    [DeviceA-security-zone-Untrust] import interface gigabitethernet 1/0/1
    [DeviceA-security-zone-Untrust] quit
    [DeviceA] security-zone name trust
    [DeviceA-security-zone-Trust] import interface gigabitethernet 1/0/2
    [DeviceA-security-zone-Trust] quit
    [DeviceA] ospfv3 1
    [DeviceA-ospfv3-1] router-id 2.1.1.1
    [DeviceA-ospfv3-1] quit
    [DeviceA-GigabitEthernet1/0/1] ospfv3 1 area 0
    [DeviceA] interface gigabitEthernet1/0/2
    [DeviceA-33] ospfv3 1 area 0
    [DeviceA-33] quit
  4. Configure a security policy.
    Perform this task only on the primary device. After the HA group is set up, the secondary device automatically synchronizes its security policy configuration with the primary device.
    # Configure security policy rule named trust-untrust to permit the packets from 2001::0/64 to the Internet.
    [DeviceA] security-policy ipv6
    [DeviceA-security-policy-ipv6] rule name trust-untrust
    [DeviceA-security-policy-ipv6-0-trust-untrust] source-zone trust
    [DeviceA-security-policy-ipv6-0-trust-untrust] destination-zone untrust
    [DeviceA-security-policy-ipv6-0-trust-untrust] source-ip-subnet 2001::0 64
    [DeviceA-security-policy-ipv6-0-trust-untrust] action pass
    [DeviceA-security-policy-ipv6-0-trust-untrust] quit
    # Configure rules to permit OSPFv3 protocol packets.
    [DeviceA-security-policy-ipv6] rule name ospf1
    [DeviceA-security-policy-ipv6-1-ospf1] source-zone trust
    [DeviceA-security-policy-ipv6-1-ospf1] destination-zone local
    [DeviceA-security-policy-ipv6-1-ospf1] service ospf
    [DeviceA-security-policy-ipv6-1-ospf1] action pass
    [DeviceA-security-policy-ipv6-1-ospf1] quit
    [DeviceA-security-policy-ipv6] rule name ospf2
    [DeviceA-security-policy-ipv6-2-ospf2] source-zone local
    [DeviceA-security-policy-ipv6-2-ospf2] destination-zone trust
    [DeviceA-security-policy-ipv6-2-ospf2] service ospf
    [DeviceA-security-policy-ipv6-2-ospf2] action pass
    [DeviceA-security-policy-ipv6-2-ospf2] quit
    [DeviceA-security-policy-ipv6] rule name ospf3
    [DeviceA-security-policy-ipv6-3-ospf3] source-zone untrust
    [DeviceA-security-policy-ipv6-3-ospf3] destination-zone local
    [DeviceA-security-policy-ipv6-3-ospf3] service ospf
    [DeviceA-security-policy-ipv6-3-ospf3] action pass
    [DeviceA-security-policy-ipv6-3-ospf3] quit
    [DeviceA-security-policy-ipv6] rule name ospf4
    [DeviceA-security-policy-ipv6-4-ospf4] source-zone local
    [DeviceA-security-policy-ipv6-4-ospf4] destination-zone untrust
    [DeviceA-security-policy-ipv6-4-ospf4] service ospf
    [DeviceA-security-policy-ipv6-4-ospf4] action pass
    [DeviceA-security-policy-ipv6-7-ospf4] quit
    [DeviceA-security-policy-ipv6] quit
  5. Configure HA group settings.
    # Associate track entries with interfaces.
    [DeviceA] track 1 interface gigabitethernet 1/0/1
    [DeviceA-track-1] quit
    [DeviceA] track 2 interface gigabitethernet 1/0/2
    [DeviceA-track-2] quit
    # Set up an HA group.
    [DeviceA] remote-backup group
    [DeviceA-remote-backup-group] remote-ipv6 3005::2
    [DeviceA-remote-backup-group] local-ipv6 3005::1
    [DeviceA-remote-backup-group] data-channel interface gigabitethernet 1/0/3
    [DeviceA-remote-backup-group] device-role primary
    RBM_P[DeviceA-remote-backup-group] backup-mode dual-active
    RBM_P[DeviceA-remote-backup-group] hot-backup enable
    RBM_P[DeviceA-remote-backup-group] configuration auto-sync enable
    RBM_P[DeviceA-remote-backup-group] configuration sync-check interval 12
    RBM_P[DeviceA-remote-backup-group] delay-time 1
    # Configure the HA group to change the link costs advertised in OSPFv3 routes to 1.
    RBM_P[DeviceA-remote-backup-group] adjust-cost ospfv3 enable absolute 1
    # Configure the HA group to monitor the status of track entry 1 and track entry 2.
    RBM_P[DeviceA-remote-backup-group] track 1
    RBM_P[DeviceA-remote-backup-group] track 2
    RBM_P[DeviceA-remote-backup-group] quit
  6. Configure security services on Device A. (Details not shown.)
Configure Device B
  1. Assign IP addresses to interfaces.
    [DeviceB-GigabitEthernet1/0/1] ipv6 address 3004::1/64
    [DeviceB-GigabitEthernet1/0/1] ipv6 address auto link-local
    [DeviceB] security-zone name untrust
    [DeviceB-security-zone-Untrust] import interface gigabitethernet 1/0/1
    [DeviceB-security-zone-Untrust] quit
    [DeviceB] security-zone name trust
    [DeviceB-security-zone-Trust] import interface gigabitethernet 1/0/2
    [DeviceB-security-zone-Trust] quit
  3. Configure OSPFv3. Use the default OSPFv3 link cost configuration.
    [DeviceB] ospfv3 1
    [DeviceB-ospfv3-1] router-id 3.1.1.1
    [DeviceB-ospfv3-1] quit
    [DeviceB-GigabitEthernet1/0/1] ospfv3 1 area 0
    [DeviceB] interface 33
    [DeviceB-33] ospfv3 1 area 0
    [DeviceB-33] quit
  4. Configure HA group settings.
    [DeviceB] track 1 interface gigabitethernet 1/0/1
    [DeviceB-track-1] quit
    [DeviceB] track 2 interface gigabitethernet 1/0/2
    [DeviceB-track-2] quit
    [DeviceB] remote-backup group
    [DeviceB-remote-backup-group] remote-ipv6 3005::1
    [DeviceB-remote-backup-group] local-ipv6 3005::2
    [DeviceB-remote-backup-group] data-channel interface gigabitethernet 1/0/3
    [DeviceB-remote-backup-group] device-role secondary
    RBM_S[DeviceB-remote-backup-group] backup-mode dual-active
    RBM_S[DeviceB-remote-backup-group] hot-backup enable
    RBM_S[DeviceB-remote-backup-group] configuration auto-sync enable
    RBM_S[DeviceB-remote-backup-group] configuration sync-check interval 12
    RBM_S[DeviceB-remote-backup-group] delay-time 1
    RBM_S[DeviceB-remote-backup-group] adjust-cost ospfv3 enable absolute 1
    RBM_S[DeviceB-remote-backup-group] track 1
    RBM_S[DeviceB-remote-backup-group] track 2
    RBM_S[DeviceB-remote-backup-group] quit
Configure the hosts
# On the hosts, specify 2001::1 as the default gateway. (Details not shown.)
Device A
# Verify that the HA channels have been set up.
RBM_P[DeviceA] display remote-backup-group status
Remote backup group information:
Backup mode: Dual-active
Device management role: Primary
Device running status: Active
Data channel interface: GigabitEthernet1/0/3
Local IPv6: 3005::1
Remote IPv6: 3005::2 Destination port: 60064
Control channel status: Connected
Keepalive interval: 1s
Keepalive count: 10
Configuration consistency check interval: 12 hour
Configuration consistency check result: Not Performed
Configuration backup status: Auto sync enabled
Session backup status: Hot backup enabled
Delay-time: 1 min
Uptime since last switchover: 0 days, 3 hours, 11 minutes
Switchover records:
Time Status change Cause
2021-06-22 13:33:33 Initial to Active Local device rebooted
# Verify that the OSPFv3 routes advertised by Device A and Device B include the same link cost.
RBM_P[DeviceA] display ospfv3 interface
OSPFv3 Process 1 with Router ID 2.1.1.1
Area: 0.0.0.0
ID State Cost Pri DR BDR Ins Name
2 DR 1 1 2.1.1.1 1.1.1.1 0 GE1/0/1
3 BDR 1 1 4.1.1.1 2.1.1.1 0 GE1/0/2
Device B
RBM_S[DeviceB] display remote-backup-group status
Device management role: Secondary
Local IPv6: 3005::2
Remote IPv6: 3005::1 Destination port: 60064
Keepalive count: 10
Delay-time: 1 min
Switchover records:
RBM_S[DeviceB] display ospfv3 interface
OSPFv3 Process 1 with Router ID 3.1.1.1
Area: 0.0.0.0
2 DR 1 1 3.1.1.1 1.1.1.1 0 GE1/0/1
3 BDR 1 1 4.1.1.1 3.1.1.1 0 GE1/0/2
Configuration files
