CLI example: Configuring login to the device Web interface using USB key-based method
As shown in Figure-1, configure the host to log in to the firewall using the USB key-based method, and to access the Web interface of the firewall through HTTPS. This provides higher security for authentication, effectively preventing data leakage and unauthorized access.
Figure-1 Network diagram
Software versions used
This configuration example was created and verified on R9900P2705 of the F5000-AI-55-G device.
Make sure the system clock of the device is synchronized with that of the CA certificate server, allowing the device to request certificates properly.
Procedures
Obtaining the certificates
Before requesting the certificates, first install a CA certificate server (this example uses a Windows 2012 server). During the installation of the CA certificate server, set the server's name to myca and using the default settings for other parameters. Make sure the system clock of the device is synchronized with that of the server. For more information about CA certificate server setup, see PKI configuration in Security Configuration Guide.
Requesting a root certificate
  1. Open an IE browser, and type http://192.168.200.201/certsrv in the address bar. On the login page, enter the account and password for logging in to the CA certificate server.
    Figure-2 Certificate homepage
  2. Click Download a CA certificate, certificate chain, or CRL.
    Figure-3 CA certificate download
  3. Click Download CA certificate. Select the downloaded certnew.cer file, and double-click to view it.
    Figure-4 Root certificate
Requesting server certificates
  1. Type http://192.168.200.201/certsrv in the address bar of the browser. On the homepage, click Request a certificate.
    Figure-5 Requesting a certificate
  1. On the page that opens, click advanced certificate request.
    Figure-6 Requesting an advanced certificate
  1. Click Create and submit a request to this CA.
    Figure-7 Creating a request
  1. Configure the server authentication certificate parameters. Select Mark keys as exportable.
    Figure-8 Requesting a server certificate
  1. Click Submit. The status of the certificate is pending.
    Figure-9 Certificate pending
Issuing certificates
  1. Log in to the CA certificate server. Open the Server Manager, click Tools, and then select Certification Authority. You can view the pending requests.
    Figure-10 Pending requests
  1. Right click the target pending request, and then select All Tasks > Issue to issue the certificate.
Exporting the server certificate
  1. On the certificate request homepage, click View the status of a pending certificate request.
    Figure-11 Viewing certificates
  1. Select the server certificate for installation. The status of the certificate becomes issued.
    Figure-12 Certificate status
  1. Click Install this certificate to complete the certificate installation.
    Figure-13 Installation completed
  1. Open the Internet Explorer. Click Tools, select Internet Options, click the Content tab, and then click Certificates.
    Figure-14 Installed certificates
  1. Select the server certificate, click Export…, and then select Yes, export the private key.
    Figure-15 Private key export setting
  1. Click Next.
    Figure-16 Export format settings
  1. Set a password for the private key and a name for the export file.
    Figure-17 Setting a password
  1. Export local certificate server.pfx.
    Figure-18 Successful local certificate export
Configuring the device
Assigning IP addresses to interfaces
[Device-GigabitEthernet1/0/1] ip address 192.168.10.2 255.255.255.0
[Device-GigabitEthernet1/0/2] ip address 192.168.20.2 255.255.255.0
Adding interfaces to security zones
[Device] security-zone name trust
[Device-security-zone-Trust] import interface gigabitethernet 1/0/1
[Device] security-zone name untrust
[Device-security-zone-Untrust] import interface gigabitethernet 1/0/2
[Device-security-zone-Untrust] quit
Configuring a static route
This example takes static routing as an example. Select the routing configuration method as needed in the actual network.
# Configure a static route as needed. In this example, the next hop IP address of the route to the CA server is 192.168.20.5.
[Device] ip route-static 192.168.200.192 26 192.168.20.5
Configuring a security policy
# Configure a rule named trust-untrust to allow the host to access the CA certificate server in the external network.
[Device] security-policy ip
[Device-security-policy-ip] rule 0 name trust-untrust
[Device-security-policy-ip-0-trust-untrust] source-zone trust
[Device-security-policy-ip-0-trust-untrust] destination-zone untrust
[Device-security-policy-ip-0-trust-untrust] action pass
[Device-security-policy-ip-0-trust-untrust] quit
# Configure a rule named untrust-trust to allow the CA certificate server to communicate with the host.
[Device-security-policy-ip] rule 1 name untrust-trust
[Device-security-policy-ip-1-untrust-trust] source-zone untrust
[Device-security-policy-ip-1-untrust-trust] destination-zone trust
[Device-security-policy-ip-1-untrust-trust] action pass
[Device-security-policy-ip-1-untrust-trust] quit
[Device-security-policy-ip] quit
Configuring a PKI domain
# Create PKI domain aaa and enter its view.
[Device] pki domain aaa
[Device-pki-domain-aaa] public-key rsa general name aaa
# Disable CRL checking.
[Device-pki-domain-aaa] undo crl check enable
[Device-pki-domain-aaa] quit
Uploading and importing the server certificate to the device
# Use FTP/TFTP to upload the server certificate obtained in "Obtaining the certificates", then import the root certificate into the PKI domain.
[Device] pki import domain aaa der ca filename certnew.cer
The trusted CA's finger print is:
MD5 fingerprint:52F5 B43F 5D19 7752 EAC8 840D 0458 F66D
SHA1 fingerprint:208B 1668 DCE9 3AF6 D9B2 9A82 1825 D357 E0F8 DA05
Is the finger print correct?(Y/N):y
# Import the server certificate into the PKI domain. Enter the password as prompted.
[Device] pki import domain aaa p12 local filename server.pfx
Please input the password:
[Device]
Configuring an SSL server policy
# Create an SSL server policy named sss, and specify PKI domain aaa for the SSL server policy.
[Device] ssl server-policy sss
[Device-ssl-server-policy-sss] pki-domain aaa
# Enable mandatory SSL client authentication.
[Device-ssl-server-policy-sss] client-verify enable
[Device-ssl-server-policy-sss] quit
Creating an administrator
# Create a device management user using the @ sign in the emailAddress field of the client certificate as the username.
[Device] local-user abc class manage
[Device-luser-manage-abc] service-type https
[Device-luser-manage-abc] password simple Admin@1234
[Device-luser-manage-abc] authorization-attribute user-role network-admin
[Device-luser-manage-abc] authorization-attribute user-role network-operator
[Device-luser-manage-abc] quit
Configuring the HTTP service and login authentication mode
# Disable the HTTP and HTTPS services.
[Device] undo ip http enable
[Device] undo ip https enable
# Specify the port number for the HTTPS service. Configure the HTTPS service to use SSL server policy sss.
[Device] ip https port 4430
[Device] ip https ssl-server-policy sss
# Set the HTTPS login authentication and authorization mode to certificate.
[Device] web https-authorization mode certificate
# Use the string before the @ sign in the emailAddress field of the certificate as the username.
[Device] web https-authorization username email-prefix
# Enable the HTTP and HTTPS services.
[Device] ip http enable
[Device] ip https enable
Viewing device certificate information
Viewing the root certificate
[Device] display pki certificate domain aaa ca
Certificate:
Data:
Version: 3 (0x2)
Serial Number:
7a:42:0d:16:02:e5:fb:a7:43:d4:82:f6:1e:ec:28:60
Signature Algorithm: sha1WithRSAEncryption
Issuer: CN=myca
Validity
Not Before: Sep 14 02:55:28 2023 GMT
Not After : Sep 14 03:05:28 2033 GMT
Subject: CN=myca
Subject Public Key Info:
Public Key Algorithm: rsaEncryption
Public-Key: (2048 bit)
Modulus:
00:be:df:6c:1f:b5:4b:c6:2f:03:ea:06:ea:1e:8d:
b6:b0:88:01:2b:f7:e6:5c:89:d0:9e:d7:57:94:9f:
36:78:e7:95:76:bf:24:bc:7c:9a:c6:15:eb:da:5d:
db:8e:45:40:7b:d2:cc:87:5c:3d:77:51:ae:69:3a:
21:3a:9e:be:6c:43:a0:52:03:ba:a6:6a:17:4e:a8:
4a:98:3b:a7:e0:cf:a2:1c:df:c0:6e:8f:cf:bf:90:
60:7c:f5:e6:30:3b:dc:68:5b:f4:02:6a:42:a7:e7:
a1:c1:56:54:de:03:1f:41:dd:8b:18:99:f2:b8:83:
7e:ef:a7:ae:a1:cc:94:e4:5f:c3:35:1d:18:2f:a0:
e7:d4:21:de:de:38:f3:90:31:e5:b5:f7:01:17:f4:
76:8b:4b:d4:95:a9:98:4f:6f:ca:b4:d9:c2:5b:c7:
f5:77:fb:0d:1e:b3:1c:6e:99:0d:24:9c:f7:c2:d1:
50:9b:a1:40:20:39:42:15:89:0a:82:d4:69:79:9e:
f9:5d:af:d6:f4:9d:37:ee:8a:cf:75:45:65:53:f6:
40:33:db:88:7e:66:72:f1:e5:c1:56:a8:9a:c9:67:
f2:bb:89:52:6f:bd:8e:ad:3f:12:ea:a0:41:f6:8e:
fb:14:f0:db:24:32:d1:85:86:30:84:9c:20:f4:91:
12:c3
Exponent: 65537 (0x10001)
X509v3 extensions:
X509v3 Key Usage:
Digital Signature, Certificate Sign, CRL Sign
X509v3 Basic Constraints: critical
CA:TRUE
X509v3 Subject Key Identifier:
D9:59:9F:66:D3:72:C1:07:44:18:F2:98:63:7D:DE:DF:41:D2:9D:4E
1.3.6.1.4.1.311.21.1:
3e:2b:fb:98:9b:b3:ac:26:01:2e:25:84:14:92:52:82:82:37:
c6:b2:a3:5b:d6:e0:41:1f:91:76:b5:a2:ba:86:26:f9:2d:28:
f5:e3:1a:2b:8c:4e:49:e6:50:12:64:44:d8:09:75:01:42:08:
b3:f2:a9:9d:ed:21:fc:cc:cb:b7:ec:62:14:45:51:74:ab:11:
04:78:02:16:f2:7c:84:cb:16:c4:e1:b7:69:95:80:c8:ca:5c:
b9:2e:96:9f:8e:1c:10:76:6c:fd:7a:96:b5:0b:2b:3e:e7:e0:
f7:50:d5:97:aa:8a:28:73:ce:c5:33:d8:3b:99:7c:6f:ca:dc:
4c:7a:bd:d9:2f:e4:d0:19:cd:b3:62:80:ec:8e:58:c8:72:b2:
2e:57:a7:fa:fb:e3:d4:54:44:12:92:d2:95:2a:81:72:c8:67:
09:10:6e:e5:32:40:06:5c:f0:66:33:84:54:ec:4c:28:1f:ea:
b7:e8:a4:6e:52:a2:98:a7:c8:74:21:ba:db:27:8d:71:3e:3b:
cd:bf:15:32:ad:cd:1e:7c:93:3e:4f:19:65:fc:6f:ac:ed:6c:
ca:c9:b5:be:83:bb:24:07:eb:c4:03:e5:0e:f8:a3:e8:51:7d:
46:6e:a5:3d:03:3e:c1:ab:12:d3:d1:67:db:5a:34:7e:1c:75:
e8:3a:58:12
Viewing the server certificate
[Device] display pki certificate domain aaa local
Certificate:
Data:
Version: 3 (0x2)
Serial Number:
17:00:00:00:17:da:42:78:2d:a5:18:1a:01:00:00:00:00:00:17
Issuer: CN=myca
Validity
Not Before: Sep 20 03:22:16 2023 GMT
Not After : Sep 20 03:32:16 2024 GMT
Subject: C=CN,CN=192.168.10.2,[email protected]
Modulus:
00:c1:dc:d1:6a:28:ea:5f:b5:37:c5:b1:f3:b6:5d:
ae:11:79:95:2d:36:6c:2f:4f:4a:45:ab:d4:73:4e:
ac:7e:44:db:29:7a:c5:aa:78:96:79:dc:37:cd:db:
62:70:d3:d7:41:cb:35:89:88:65:1e:ca:3a:6b:4d:
f3:f2:a4:7f:9e:fe:a4:75:a7:35:2f:ad:d8:5b:46:
70:73:65:00:5e:9b:e7:c1:8b:b6:4d:a9:48:d4:e5:
7f:7c:f3:08:c5:ae:4e:db:05:25:f5:04:7d:c2:cc:
99:1b:7f:55:9e:c1:b9:16:81:2d:6a:44:bc:78:f6:
2f:a0:46:69:65:88:ac:8c:ee:92:20:80:16:9d:f5:
1c:dd:5c:c7:c3:58:4d:bf:23:8f:6e:b3:e6:35:1d:
93:26:51:64:e3:54:06:0d:4b:c5:06:4d:88:78:df:
c4:df:49:38:ae:7b:ed:37:5c:a1:7e:8a:ec:7b:c8:
a0:16:f3:0b:06:75:ef:20:f3:6b:e9:78:26:35:f3:
05:f6:3a:56:fa:49:d8:10:78:b6:75:de:66:9c:95:
7b:cd:51:12:ea:6d:6e:84:69:5d:df:9c:7d:c7:fc:
bb:8d:20:21:39:6c:cd:cf:32:4d:de:f5:4e:a1:e2:
0f:54:c1:d8:70:52:27:bd:1a:ce:34:1e:9d:fa:87:
0f:9f
X509v3 extensions:
X509v3 Key Usage: critical
Digital Signature, Non Repudiation, Key Encipherment, Data Encip
herment
X509v3 Extended Key Usage:
TLS Web Server Authentication
30:B4:FC:8B:BC:6C:8B:5B:33:4D:85:E0:0C:0F:58:3B:E9:AC:05:6C
X509v3 Authority Key Identifier:
keyid:D9:59:9F:66:D3:72:C1:07:44:18:F2:98:63:7D:DE:DF:41:D2:9D:4E
X509v3 CRL Distribution Points:
Full Name:
URI:file://12DC-CN-x64/CertEnroll/myca.crl
Authority Information Access:
CA Issuers - URI:file://12DC-CN-x64/CertEnroll/12DC-CN-x64_myca.
crt
CA:FALSE
11:90:80:b3:f1:da:7b:93:38:a4:04:5a:76:fb:74:08:76:cf:
9c:b8:4f:ae:b9:ec:e5:8f:1b:f6:22:06:24:b7:57:cf:1d:0e:
51:b2:02:8d:b3:e0:56:b3:7b:42:9b:66:34:36:2f:d0:19:d1:
75:c8:7a:74:45:89:42:22:87:f6:01:3a:2e:a5:3c:fe:f5:ac:
d2:8f:57:66:be:0a:1b:bb:df:0a:af:51:16:5e:87:3c:35:55:
c9:9e:d5:3c:4c:1d:0f:d6:8a:76:5a:fc:17:90:31:fe:19:63:
70:f7:64:d4:2c:92:35:b8:bd:d5:f6:27:e1:6e:db:a6:c6:2d:
45:1c:fd:24:e3:f5:11:9b:f3:ac:cb:dd:37:1d:2e:0f:c8:da:
13:b5:ac:70:6a:8a:f8:b2:d5:db:c5:91:cf:7f:c5:bc:73:b5:
90:22:b6:99:5d:cb:50:44:1b:25:db:25:a0:47:00:8f:b3:9d:
f7:ae:89:3e:47:c7:12:d0:33:8b:47:58:c5:e7:b6:fe:8e:c3:
64:fe:2c:62:e1:67:15:b8:5c:1c:70:53:d7:0a:50:03:2c:80:
0e:4c:2c:8b:34:56:5a:c1:04:2a:0e:fe:3f:57:9e:7f:20:ae:
9c:f7:0f:4a:52:a0:87:5a:bf:b1:c2:7f:48:7b:3d:63:a5:4b:
c7:0b:0e:22
Verifying login
Verify that you can log in to the device's Web interface:
  1. Obtain the USB key.
    Install the USB key obtained from the administrator to the host or create your own USB Key. For information about creating a USB key, see "Appendix: Creating a USB key." When you create a USB Key, the device in this example uses the email-prefix field of the certificate for login verification. Therefore, the email prefix in the requested client certificate must match the username, which is abc in this example, created on the device.
    Figure-19 Identification information in the client certificate
  2. Open a browser, insert the USB with the client certificate, enter the IP address of the device in the address bar, and then select the client certificate for authentication.
    Figure-20 Web login
  1. On the device login page, click Other login methods.
    Figure-21 Clicking Other login methods
  1. Click USB-Key Log in to log in to the device. Verify that you can log in as user abc.
    Figure-22 Successful login to the device
Configuration files
Device
security-zone name Trust
import interface GigabitEthernet1/0/1
security-zone name Untrust
import interface GigabitEthernet1/0/2
password hash $h$6$kEnRxrjkMV2btaA+$Fp0Qq8IRg6uzj5ewCAJsgBeY36okplMU+jRz6zJOfhEcAm99sn+nKPOEizmk7P27qdVvwXaeFK40jueH/6lctQ==
service-type https
pki domain aaa
public-key rsa general name aaa length 2048
ip https port 4430
ip http enable
ip https enable
pki-domain aaa
version ssl3.0 disable
version tls1.0 disable
undo version tls1.1 disable
security-policy ip
action pass
source-zone trust
action pass
source-zone untrust
To create a USB key on the administrator's PC:
  1. Configure the IP address and gateway on the PC to ensure that the PC can reach the CA server. This example uses Windows 2008 server as a CA server.
    Figure-23 Creating a USB key
  2. Request a USB key client certificate:
    # Enter http://192.168.100.247/certsrv in the address bar of the browser to access the certificate request page.
    Figure-24 Requesting a certificate
    # Click Request a certificate. The following page opens.
    Figure-25 Requesting a certificate
    # Click advanced certificate request, and then select Create and submit a request to this CA on the page that opens to request a client certificate. Configure the parameters as shown in Figure-26.
    Figure-26 Requesting a client certificate
    # Keep the default settings for the other options, and click Submit at the bottom of the page to submit the client certificate request.
    # After you submit the request successfully, a dialog box opens. In the dialog box, enter the user password of the USB key as prompted and then click Login.
    Figure-27 Installing the client certificate into the USB key
    # Click Install this certificate. Click Yes in the potential script conflict dialog box that opens. The client certificate will be directly installed into the USB key.
    Figure-28 USB key client certificate
    At this point, the USB key creation is complete.
