This help contains the following topics:
The
You can enable logging in a URL filtering profile. The URL filtering module can then generates logs for packets that match the URL filtering profile.
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
To use URL filtering, you must purchase and install the required license. If the license expires, the existing URL filtering signature library is still available but you cannot upgrade the library on the device or perform a URL filtering cloud query task. For more information about licensing, see the license management help.
Support for this feature depends on the device model.
Only one log operation (import, export, or clear) is allowed at a time.
Only one user can perform a log operation at a time. When you import, export, or clear logs, make sure no one else is performing a log operation.
Click the
In the navigation pane, select
Click
In the dialog box that opens, click
Select a log file and enter the password for the log file. The password was set when the file was exported.
To export logs to the local, perform the following steps:
Click the
Click on the right of the displayed columns. On the page that opens, specify the search criteria and click
Click
On the page that opens, configure the log export settings.
Table-1 Log export configuration items
Item | Description |
Set password | Enter a password for encrypting the log files. This password must be provided to open the exported log files. |
Logs per file | Specify the maximum number of log entries in each file.
Click
Perform this task to enable log aggregation. Log aggregation reduces the number of log entries displayed on the Web interface and facilitates you to view the logs. With log aggregation enabled, the device aggregates service logs that meet the same aggregation criteria at the configured intervals. The log aggregation criteria include source IP address, destination IP address, application, source port, destination port, URL category, and URL.
Click the
Click
On the page that opens, enable log aggregation and configure the aggregation interval.
Click
