SSL VPN
This help contains the following topics:
Introduction
SSL VPN provides SSL-based secure remote access services through an SSL VPN gateway. Users from anywhere on the Internet can establish a secure connection to an SSL VPN gateway through an SSL-enabled browser to access protected resources behind the gateway.
SSL VPN operating mechanism
To allow remote user access to protected resources behind an SSL VPN gateway, you must configure these resources on the gateway. Remote users can access only the resources authorized to them after they establish an SSL-encrypted connection to the gateway and pass the identity authentication.
SSL VPN operates as follows:
  1. The remote user establishes an HTTPS connection to the SSL VPN gateway.
    In this process, the remote user and the SSL VPN gateway perform SSL certificate authentication.
  2. The remote user enters the username and password.
  3. The SSL VPN gateway authenticates the credentials that the user entered, and authorizes the user to access a range of resources.
  4. The user selects a resource to access.
    An access request for that resource is sent to the SSL VPN gateway through the SSL connection.
  5. The SSL VPN gateway resolves the request and forwards the request to the corresponding internal server.
  6. The SSL VPN gateway forwards the server's reply to the user through the SSL connection.
SSL VPN networking modes
SSL VPN supports the following networking modes:
SSL VPN access modes
Tunnel service
Tunnel service implements secured IP communications between remote users and internal servers.
To access an internal server in tunnel service mode, a user must install dedicated tunnel service client software (iNode). The client software will install a virtual network interface card (VNIC) on the SSL VPN client.
Web proxy
In Web proxy mode, remote users use browsers to access Web resources allowed by an SSL VPN gateway through HTTPS. After login, a user can access any resources listed on the webpage. In Web proxy mode, all operations are performed on webpages.
The resources available for SSL VPN Web proxy users are Web servers only.
TCP proxy
In TCP proxy access mode, users access TCP applications on internal servers by accessing the applications' open ports. Supported applications include remote access services (such as Telnet), desktop sharing services, mail services, Notes services, and other TCP services that use fixed ports.
In TCP proxy access mode, a user installs the TCP proxy client software on the SSL VPN client (the terminal device that the user uses). The client software uses an SSL connection to transmit the application layer data.
BYOD access
BYOD access enables secured access to internal resources through mobile clients.
For mobile clients to access internal resources in BYOD access mode:
Resource access control
SSL VPN controls user access to resources on a per-user basis.
As shown in Figure-1, an SSL VPN gateway can be associated with multiple SSL VPN contexts. An SSL VPN context contains multiple resource groups. A resource group defines accessible Web resources, TCP resources, and tunnel service resources.
Figure-1 SSL VPN resource access control
An SSL VPN user can access an SSL VPN gateway by using the following methods:
After determining the SSL VPN context for a user, the SSL VPN gateway uses the authentication and authorization methods of the ISP domain specified for the context to perform authentication and authorization for the user.
The SSL VPN gateway uses AAA to perform user authentication and authorization. SSL VPN supports AAA protocols RADIUS and LDAP. RADIUS is most often used.
vSystem support information
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Disabling an SSL VPN AC interface might interrupt the IP access service. Please perform this operation with caution.
Restrictions and guidelines: SSL VPN
You can only configure the SSL VPN feature for high availability on a network where RBM-based hot backup is configured in active/standby mode and RBM is associated with VRRP. Other hot backup modes do not support high availability configuration. For more information about hot backup, see the description for the hot backup module.
Restrictions and guidelines: SSL VPN gateway configuration
If the SSL server policy used by an SSL VPN gateway is changed, or the policy settings are changed, you must re-enable the gateway to make the configuration take effect.
Restrictions and guidelines: Context configuration
Restrictions and guidelines: TCP proxy configuration
Restrictions and guidelines: Tunnel service configuration
When you configure the IP access address pool for IP access clients, follow these restrictions and guidelines:
When you bind IP addresses to an SSL VPN user, follow these restrictions and guidelines:
Restrictions and guidelines: Domain name configuration
Make sure you specify valid domain names for SSL VPN configuration items such as Web resource URLs or port forwarding entries.
SSL VPN does not check the existence or validity of the specified domain names.
Restrictions and guidelines: Webpage template configuration
Restrictions and guidelines: LDAP authentication configuration
If you configure LDAP authentication for SSL VPN users, you must also configure LDAP authorization. Configure LDAP authorization settings from the CLI on the device.
Restrictions and guidelines: SSO login configuration
For the auto-build SSO method, the following requirements must be met:
Restrictions and guidelines: WeChat Work authentication
If WeChat Work authentication is enabled in an SSL VPN context, the SSL VPN context supports only the Exclusive access mode for the associated gateway.
Restrictions and guidelines: URI ACLs
The URI pattern of a URI ACL rule is in the format of protocol://host:port/path, where protocol and host are required.
Configure SSL VPN
Analysis
Configure an SSL VPN context as shown in Figure 2.
Figure-2 SSL VPN configuration procedure
In addition to the preceding configuration procedure, you can also perform the following tasks in SSL VPN:
Complete the following tasks before you configure this feature:
Access internal resources in tunnel service access mode
The tunnel service access mode is suitable for scenarios that require comprehensive network layer communication between remote hosts and internal servers, such as pinging an internal server from a remote host or running applications that require a stable network connection.
Configure an SSL VPN gateway
  1. Click the Network tab.
  2. In the navigation pane, select VPN > SSL VPN > SSL VPN Gateways.
  3. Click Create.
  4. Create an SSL VPN gateway.
    Figure-3 SSL VPN gateway page
    Figure-4 Creating an gateway
    Table-1 Gateway configuration items
    Item
    Gateway
    Enter a name for the SSL VPN gateway.
    IP selection method
    Select an IP selection method, including Select Interface IP and Custom IP.
    IP address type
    Select IPv4 or IPv6 as the IP address type.
    Select interface IP
    Select an interface from the drop-down list. The IP address of this interface will be used as the address of the SSL VPN gateway.
    You cannot specify the management address of the device as the address of the SSL VPN gateway.
    IP address
    Select the IP address of the SSL VPN gateway.
    HTTPS port
    Specify the HTTPS port number of the SSL VPN gateway.
    HTTP port
    Specify the HTTP port number of the SSL VPN gateway.
    SSL server policy
    Select an SSL server policy to be associated with the SSL VPN gateway.
    Quantum Encryption
    This item is optional.
    Quantum encryption enables SSL VPN to use a type of key pair to encrypt and decrypt SSL VPN messages.
    Support for quantum encryption varies by device model.
    Encryption type
    Select the type of quantum key for quantum encryption, including:
    • GD-quantum—SSL VPN uses GD-quantum secret keys to encrypt and decrypt SSL VPN messages.
    • CSP-quantum—SSL VPN uses CSP-quantum secret keys to encrypt and decrypt SSL VPN messages.
    Support for this feature varies by device model.
    Mandatory encryption
    You can select whether to enable mandatory quantum encryption.
    • If you select Mandatory, the SSL VPN gateway can only performs SSL negotiation with iNode clients that use quantum encryption. Other clients are unable to access the SSL VPN gateway.
    • If you select Non-mandatory, the following rules apply:
      • If an iNode client uses quantum encryption for SSL negotiation, SSL negotiation will use quantum key pairs.
      • If an iNode client does not use quantum encryption or an SSL VPN user accesses the gateway in Web access mode, SSL negotiation will not use quantum key pairs.
    Support for mandatory quantum encryption varies by device model.
    VRF
    Select the VRF to which the SSL VPN gateway belongs.
    This field is available only when you edit an SSL VPN gateway.
    Enable
    Select whether to enable the SSL VPN gateway.
  5. Click OK.
Configure basic settings in an SSL VPN context
Configure the basic settings, including the associated SSL VPN gateways and the enabling status of the SSL VPN context.
To configure basic settings in an SSL VPN context:
  2. In the navigation pane, select VPN > SSL VPN > SSL VPN Contexts.
  3. Click Create.
    The Create SSL VPN Context page opens.
    Figure-5 SSL VPN Contexts page
  4. On the Basic settings tab, configure the basic settings for the SSL VPN context, and then click Next.
    Figure-6 Configuring basic settings of an SSL VPN context
    Table-3 Basic configuration items for an SSL VPN context
    Item
    Context name
    Enter an SSL VPN context name.
    Associated gateways
    Configure the gateways associated with the SSL VPN context.
    You can select an associated gateway from the drop-down list. If no SSL VPN gateway exists, you can add an SSL VPN gateway.
    When multiple contexts are associated with the same gateway, you can assign different domain names or host names to these contexts. If you do not specify any domain name or host name, a gateway can only be associated with one context.
    Enable SSL VPN context
    Select this item to enable the SSL VPN context.
    Auto-generate security policy
    This feature enables the device to automatically generate a security policy that allows SSL VPN service packets to pass when the device creates the SSL VPN context.
Configure access services in an SSL VPN context
To allow external users to access internal resources in IP access mode, perform the following operations:
  1. On the Access services tab, click the toggle button to the Tunnel service field.
    Figure-7 Configuring the tunnel service
  2. Specify an SSL VPN AC interface for the SSL VPN context to effectively separate SSL VPN traffic from other types of network traffic. You can select an existing SSL VPN AC interface from the drop-down list or use one of the following methods to create an SSL VPN AC interface:
    • Click Add SSL VPN AC interface from the SSL VPN AC interface drop-down list, enter an interface number and click OK. Then, configure the security zone and IP address on the Modify Interface Settings page and click OK.
      Figure-8 Adding an SSL VPN AC interface
      Figure-9 Entering an interface number
      Figure-10 Modifying interface settings
    • Navigate to the Network > VPN > SSL VPN > SSL VPN AC Interfaces page and click Create. Then, create an SSL VPN AC interface as above.
  3. Specify the IPv4 or IPv6 address pool to be associated with the SSL VPN gateway.
    If a client accesses the SSL VPN gateway in tunnel service mode, the SSL VPN gateway must assign an IP address to the client to ensure that the client can communicate with internal network through the gateway tunnel.
    In the Tunnel mode area, select IPv4 or IPv6, and then specify the IP access address pool. Then, the SSL VPN gateway will use the specified address pool to assign addresses to clients. You can also use one of the following methods to create an IP access address pool:
    • Click IPv4 or IPv6, and then click Add IP access address pool from the IP access address pool drop-down list. Then, configure an address pool name and the start and end addresses for the address pool, and then click OK.
      Figure-11 Adding an IPv4 address pool
      Figure-12 Configuiring an IPv4 address pool
    • Navigate to the Network > VPN > SSL VPN > IP Access Address Pools page and create an IP access address pool on the IPv4 Access Address Pool or IPv6 Access Address Pool tab as above.
  4. Configure tunnel service resources, including IPv4 and IPv6 access resources. In tunnel service access mode, you can define accessible resources through route entries, which effectively control and limit the range of client access, thereby enhancing network security.
    Perform the following operations in sequence:
    • In IPv4 access resources area, click Create. On the page that opens, enter an IPv4 route list name.
    • In the IPv4 route entries section, click Create. On the page that opens, configure an IPv4 route entry.
      Figure-13 Creating an IPv4 route list
      Figure-14 Creating an IPv4 route entry
      Table-4 Configuration items for an IPv4 route entry
      Item
      Select a route entry type. Options include:
      • Included route—Add the route entry to the route list as an included route.
      • Excluded route—Add the route entry to the route list as an excluded route.
      The SSL VPN gateway issues the route list to a login client. The client adds the routes to the local routing table. Traffic that matches the included routes is sent to the SSL VPN gateway. Traffic that matches the excluded routes is not sent to the SSL VPN gateway.
      Subnet address
      Specify the destination address of the route entry. To configure an included route, the destination network of the route entry must be the network where the internal server locates.
      Mask length
      Specify the subnet mask length.
    • Click OK.
      The route entry is displayed on the IPv4 route entries section.
    • Click OK.
      The route list is displayed on the IPv4 access resources section.
    • In IPv6 access resources section, click Create. On the page that opens, enter an IPv6 route list name.
    • In the IPv6 route entries section, click Create. On the page that opens, configure an IPv6 route entry.
      Figure-15 Creating an IPv6 route list
      Figure-16 Creating an IPv6 route entry
      Table-5 Configuration items for an IPv6 route entry
      Item
      Subnet address
      Prefix length
      Specify the prefix length for the destination address.
    • Click OK. The route entry is displayed on the IPv6 route entries section.
    • Click OK. The route list is displayed on the IPv6 access resources section.
  5. Click Next.
Configure resource authorization in an SSL VPN context
To configure resource authorization, you must configure resource groups and role-based resource authorization. Create a resource group to define the resource range accessible to users, and then associate the resource group to a role on the role-based resource authorization page. This ensures that users with different roles have access to all resources within their associated resource groups.
To configure a resource group:
  1. Create a resource group. click Create in the Resource groups section.
  2. On the page that opens, configure basic settings for the resource group.
    Figure-17 Configuring resource authorization
    Figure-18 Creating a resource group
    Table-6 Configuration items for basic resource group settings
    Item
    Resource group name
    Enter a name for the resource group.
    Instant access resource after login
    Select the resource opened for users immediately after they log in to the SSL VPN gateway. Users do not need to select the resource on the SSL VPN resource page to access the resource.
    Shortcut list
    Select a shortcut list for the resource group.
  3. In the IP access section, configure accessible IP resources and IP access filters.
    Table-7 Configuration items for IP access
    Item
    Force all IPv4 traffic to SSL VPN
    Select this item to force all IPv4 traffic of a client to be sent to the SSL VPN gateway.
    The SSL VPN gateway will issue a default IPv4 route to the SSL VPN client. The default IPv4 route uses the VNIC as the output interface and has the highest priority among all default IPv4 routes on the client. Packets for destinations not in the IPv4 routing table are sent to the SSL VPN gateway through the VNIC. The SSL VPN gateway monitors the SSL VPN client in real time. It does not allow the client to delete the default IPv4 route or add a default IPv4 route with a higher priority.
    Issue specified IPv4 routes to client
    Select an IPv4 route list to issue the routes in the list to the client, or select Host IPv4 address and configure an IPv4 route to issue to the client.
    IPv4 access address pool
    Specify the IPv4 address pool for the resource group. When a client accesses the SSL VPN gateway in tunnel service access mode, the SSL VPN gateway assigns an IPv4 address in the IPv4 address pool to the client. If no IP addresses are available in the IPv4 address pool, the SSL VPN gateway will fail to assign an IPv4 address to the client. Then, the client will fail to access the SSL VPN gateway through the tunnel service.
    If no IPv4 access address pool is specified for the authorized resource group, the SSL VPN gateway will assign IPv4 addresses in the IPv4 address pool specified for the SSL VPN context to clients.
    Force all IPv6 traffic to SSL VPN
    Select this item to force all IPv6 traffic of a client to be sent to the SSL VPN gateway.
    The SSL VPN gateway issues a default IPv6 route to the SSL VPN client. The default IPv6 route uses the VNIC as the output interface and has the highest priority among all default IPv6 routes on the client. Packets for destinations not in the IPv6 routing table are sent to the SSL VPN gateway through the VNIC. The SSL VPN gateway monitors the SSL VPN client in real time. It does not allow the client to delete the default IPv6 route or add a default IPv6 route with a higher priority.
    Issue specified IPv6 routes to client
    Select an IPv6 route list to issue the routes in the list to the client, or select Host IPv6 address and configure an IPv6 route to issue to the client.
    IPv6 access address pool
    Specify the IPv6 address pool for the resource group. When a client accesses the SSL VPN gateway in tunnel service access mode, the SSL VPN gateway assigns an IPv6 address in the IPv6 address pool to the client. If no IP addresses are available in the IPv6 address pool, the SSL VPN gateway will fail to assign an IPv6 address to the client. Then, the client will fail to access the SSL VPN gateway through the tunnel service.
    If no IPv6 access address pool is specified for the authorized resource group, the SSL VPN gateway will assign IPv6 addresses in the IPv6 address pool specified for the SSL VPN context to clients.
    IPv4 ACL
    Specify an IPv4 ACL to filter IPv4 tunnel service requests to further control user access.
    IPv6 ACL
    Specify an IPv6 ACL to filter IPv6 tunnel service requests to further control user access.
    URI ACL
    Specify a URI ACL to filter tunnel service requests to further control user access.
  4. Click OK.
    The newly created resource group is displayed on the Resource groups section.
To configure role-based resource authorization
  1. In the Role-based Resource Authorization section, click Create.
  2. On the page that opens, configure role-based resource authorization settings.
    Figure-19 Configuring role-based resource authorization
    Table-8 Configuration items for role-based resource authorization
    Item
    Role
    Select a role.
    Resource group
    Select a resource group to be associated with the role.
    Access mode
    Select an access mode for the role.
  3. Click OK.
  4. Click Next to access the More page. You can configure extended features as needed, including SSL VPN session rate limit, resource access logging, user authentication, shortcuts, and user management. For more information, see "Configure more settings in an SSL VPN context."
  5. Click Finish.
View statisitcs
To view statistics after you configure the previous settings, navigate to the Network > VPN > SSL VPN > Statistics page. The statistics including online user statistics, online user details, locked user information, locked IP information, and IP access-related statistics.
Figure-20 View statistics
Access internal resources in Web proxy access mode
In Web proxy access mode, users can quickly access internal Web resources via a browser. This mode is suitable for temporary access or users with limited resources.
In Web proxy mode, no client software is required and all operations are performed on webpages. The resources available for SSL VPN Web proxy users are Web servers only.
For information about configuring an SSL VPN gateway, see "Configure an SSL VPN gateway."
For information about configuring an SSL VPN context, see "Configure basic settings in an SSL VPN context."
  1. On the Access services page, click the toggle button to the Web proxy field for users to access internal resources in Web proxy access mode.
    Figure-21 Web proxy
  2. Specify an SSL client policy for Web proxy. This configuration allows the SSL VPN gateway to use the specified SSL client policy to establish connections with the internal HTTPS server. If no SSL client policy is specified, the SSL VPN gateway uses the default SSL client policy. The default SSL client policy uses cipher suite rsa_rc4_128_md5.
  3. Configure Web access resources. In Web proxy access mode, URL lists define accessible resources. You can add multiple URL items to a URL list. Each URL item corresponding to an internal Web resource.
    Perform the following operations:
    1. In the URL items section, click Create. On the page that opens, configure a URL item, and then click OK.
      Figure-22 Creating a URL item
      Table-9 Configuration items for a URL item
      Item
      URL item name
      Enter a URL item name.
      URL
      Enter a URL for an internal Web resource.
      URI ACL
      Select a URI ACL as a filtering criterion.
      Mapping type
      The SSL VPN gateway rewrites the resource URL returned from the internal server before sending this URL to the requesting user. The URL mapping type determines how the gateway rewrites the URL.
      The following example describes how URL mapping works when the user accesses internal resources at URL http://www.server.com:8080. The SSL VPN gateway name is gw, domain name is https://www.gateway.com:4430, and IP address is 1.1.1.1.
      The following mapping types are supported:
      • Normal rewriting—This is the default mapping method. The resource URL returned to the client will be rewritten to https://www.gateway.com:4430/_proxy2/http/8080/www.server.com. By default, the SSL VPN gateway uses normal rewriting of URLs. However, normal rewriting might cause issues like missed or incorrect URL rewrites, preventing SSL VPN clients from accessing internal resources. To resolve this issue, use domain mapping or port mapping.
      • Domain mapping—The resource URL returned to the client will be rewritten to https://mapped domain name:4430, where mapped domain name is the user-defined domain name.
      • Port mapping—You can specify a gateway name with or without a host name for port mapping. For example:
        • If you specify gw2 as the gateway name and do not specify a host name, the resource URL will be rewritten to https://2.2.2.2:4430, where 2.2.2.2 and 4430 are the IP address and port number of SSL VPN gateway gw2.
        • If you specify gw as the gateway name and vhosta as the host name, the resource URL will be rewritten to https://vhosta:4430.
      Enable URL masking
      Select whether to enable the masking for the specified URL.
      When this feature is enabled, the user will not be able to see the real address of the visited internal server.
      Single sign-on
      Select whether to enable SSO login.
      When this feature is enabled, a user can use one set of login credentials to access multiple trusted systems.
      SSO mode
      Select an SSO login mode. Options include:
      • Basic access request—Requires configuring login parameters.
      • Auto-build access request—Requires configuring the request method, encoding mode, request parameters, and encryption file uploading.
      Login parameters
      This item is available only after you select Basic access request for the SSO mode field.
      Select a method to obtain login parameters. Options include:
      • Use SSL VPN login username and password—Uses SSL VPN login username and password for SSO login.
      • Use custom username and password—Uses a custom username and password for SSO login. The custom username and password are configured on the SSL VPN Web interface.
      Request method
      This item is available only after you select Auto-build access request for the SSO mode field.
      Select a request method. Options include GET and POST.
      Encoding mode
      Select an encoding method. Options include GB18030 and UTF-8.
      Request parameters
      To add a request parameter (attribute name and value), click Add in this field, and configure the following items in the dialog box that opens:
      • Parameter name—Enter a parameter name. The parameter name is the attribute name used for SSO login requests.
      • Type—Select a parameter type. The parameter value used for SSO login is the actual value abstracted according to the parameter type. Options include:
        • Login name—Uses the SSL VPN login username as the value of the SSO request parameter.
        • Login password—Uses the SSL VPN login password as the value of the SSO request parameter.
        • Certificate subject—Uses the certificate title as the value of the SSO request parameter.
        • Certificate serial number—Uses the certificate serial number as the value of the SSO request parameter.
        • Certificate fingerprint—Uses the certificate fingerprint as the value of the SSO request parameter.
        • Phone number—Uses the mobile phone number as the value of the SSO request parameter.
        • User group—Uses the user group name as the value of the SSO request parameter.
        • Custom name—Uses the customized username as the value of the SSO request parameter.
        • Custom password—Uses the customized password as the value of the SSO request parameter.
        • Custom—Specifies an actual parameter value of the SSO request parameter in the Parameter value field.
      • Encrypt parameter value—Select whether to enable parameter value encryption.
      Set encryption file
      Upload an encryption file for parameter value encryption. The encryption file must be a .js file, and cannot exceed 200 KB.
      To upload an encryption file, click Select file to select a .js file, and then click Upload.
      To cancel the use of the current encryption file, click Cancel encryption.
      Current encryption file
      Display the current encryption file.
    2. In the URL List section, click Create. On the page that opens, configure a URL list, and then click OK.
      Figure-23 Creating a URL list
      Table-10 Configuration items for a URL list
      Item
      URL list name
      Enter a URL list name.
      Heading
      Enter a URL list heading.
      URL entry list
      Select the URL items to add to the URL list.
  4. Click Next.
The procedure for configuring resource authorization in Web proxy access mode is the same as that in tunnel service access mode. For more information, see "Configure resource authorization in an SSL VPN context."
In Web proxy mode, Web access users access different resources than in tunnel service mode. The Web resources in Web proxy mode are URL lists. You can use URL lists to define the resources accessible to Web access users.
After you configure resource authorization, click Next to access the More page. You can configure extended features as needed, and then click Finish. The extended features include SSL VPN session rate limit, resource access logging, user authentication, shortcuts, and user management.
View statisitcs
To view statistics after you configure the previous settings, navigate to the Network > VPN > SSL VPN > Statistics page. The statistics including online user statistics, online user details, locked user information, and locked IP information.
Access internal resources in TCP proxy access mode
TCP proxy access mode is suitable for securely accessing internal TCP protocol services. It is ideal for users that require services with fixed ports, such as remote access (Telnet), desktop sharing, email, and other TCP services.
In TCP proxy access mode, you must install dedicated TCP proxy client software to transmit application layer data via SSL connection.
  1. On the Access services page, click the toggle button to the TCP proxy field for users to access internal resources in TCP proxy access mode.
    Figure-24 TCP proxy
  2. Configure TCP proxy resources. In TCP proxy access mode, accessible resources are defined through a port forwarding list. This list maps internal TCP services (such as Telnet, SSH, and POP3) to local addresses and ports on the SSL VPN client. This allows the client to access internal servers through these local configurations.
    For example, you can configure a port forwarding item to allow a client to access the HTTP service provided on port 80 of server 192.168.0.213 through IP address 127.0.0.1 and port 80.
    1. In the Port forwarding items section, click Create. On the page that opens, configure a port forwarding item, and then click OK.
      Figure-25 Creating a port forwarding item
      Table-11 Configuration items for a port forwarding item
      Item
      Name
      Enter a port forwarding item name.
      Client host
      Specify the local address or host name of the SSL VPN client to which a TCP service on an internal server is mapped.
      Client port
      Specify the local port of the SSL VPN client to which a TCP service on an internal server is mapped.
      Server address
      Specify the IP address or FQDN of the internal server that provides the TCP service.
      Server port
      Specify the port of the internal server that provides the TCP service.
      Enter a description for the port forwarding item.
      Resource link
      Specify the resource link for the port forwarding item. SSL VPN users can click the resource link on the SSL VPN Web interface to access the resource.
    1. In the Port forwarding list section, click Create. On the page that opens, configure a port forwarding list, and then click OK.
      Figure-26 Creating a port forwarding list
      Table-12 Configuration items for a port forwarding list
      Item
      Enter a port forwarding list name.
      Specify the port forwarding items to add to the port forwarding list.
  3. Click Next.
The procedure for configuring resource authorization in TCP proxy access mode is the same as that in tunnel service access mode. For more information, see "Configure resource authorization in an SSL VPN context."
In TCP proxy access mode, TCP access users access different resources than in tunnel service mode. The resources in TCP proxy access mode are port forwarding lists. You can use port forwarding lists to define the resources accessible to TCP access users.
View statisitcs
Access internal resources in BYOD access mode
BYOD access is suitable for scenarios that require secure access to internal resources via mobile devices. It supports mobile work environments by allowing employees to use their personal devices to connect to the internal network.
For mobile clients to access internal resources in BYOD access mode, you must install SSL VPN client software dedicated for mobile clients. In addition, the Endpoint Mobile Office (EMO) server manages and assigns accessible internal resources.
  1. On the Access services tab, click the toggle button to the BYOD access field for users to access internal resources via mobile client.
    Figure-27 Enabling BYOD access
  2. Configure BYOD access service resources. For mobile clients, port forwarding items are not required. Install the dedicated client software for mobile clients and specify the EMO server on the SSL VPN gateway. Mobile clients can access internal resources through the EMO server.
    Table-13 Configuration items for BYOD access services
    Item
    EMO server address
    Host name of the EMO server.
    EMO server port number
    Port number of the EMO server.
    Message server address
    This field is optional.
    Host name of the message server.
    Message server port number
    Port number of the message server.
    After the configuration, the SSL VPN gateway will distribute the configured EMO server information to the client. This enables the mobile client to access available service resources through the EMO server.
  3. Click Next to access the Resource Authorization page. Use the default settings on the Resource Authorization page and click Next to access the More page.
    You can configure extended features on the More page as needed, and then click Finish. The extended features include SSL VPN session rate limit, resource access logging, user authentication, shortcuts, and user management.
View statisitcs
Perform this task to configure extended features on the More page for an SSL VPN context.
  1. On the Basic Settings tab, configure the basic settings.
    Figure-28 Configuring basic settings
    Table-14 Configuration items for basic settings
    Item
    VRF
    Select the VPN instance to which the SSL VPN context belongs.
    Max sessions
    Specify the maximum number of SSL VPN sessions for the SSL VPN context. If the limit is reached, new users cannot access the SSL VPN gateway.
    Max connt per session
    Select whether to enable or disable limiting the number of connections in a session.
    If the number of connections in a session has reached the limit, new connection requests for the session will be rejected with a 503 Service Unavailable message.
    Session idle timeout
    Specify the maximum idle time of an SSL VPN session. If the idle time of an SSL VPN session exceeds the specified idle timeout time, the session is terminated.
    Idle-cut traffic threshold
    Specify the idle-cut traffic threshold in kilobytes.
    An SSL VPN session will be disconnected if the session traffic observed within the session idle timeout time is below the idle-cut traffic threshold.
    Rate limit per session
    When the packet transmission rate in a direction of the SSL VPN session exceeds the specified limit, subsequent packets in that direction will be dropped. Uplink traffic refers to the traffic sent from users to the server. Downlink traffic refers to the traffic sent from the server to users.
    User login logging
    Select this item to enable logging for user login and logout events.
    Resource access logging
    Select this item to enable logging for resource access.
    After you enable resource access logging, you can select a logging method. Options include Log filtering and Summary log. If log filtering is enabled, the device generates only one log for accesses of the same user to the same resource in a minute. When log filtering is disabled, the device generates a log for each resource access.
    Online password change
    Select this item to enable password modification. An SSL VPN user is able to modify the password only when this feature is enabled in both SSL VPN user view and SSL VPN context view.
    Global URL Masking
    Select this item to enable URL masking for all Web resources in the SSL VPN context.
    Allowed clients
    Select the client types allowed.
    Client types include browsers, PC iNode clients, and mobile iNode clients.
    If browsers are denied (not selected), no users can use browsers to access the SSL VPN. If iNode clients are denied, new users cannot use iNode clients to access the SSL VPN. Online users will not be affected.
Configure service settings
On the Services Settings tab, configure the service settings.
Figure-29 Configuring service settings
Table-15 Configuration items for service settings
Item
Tunnel mode
Select an IP type for the tunnel mode, including IPv4 and IPv6.
Primary DNS server
Specify the IP address of the internal primary DNS server.
Secondary DNS server
Specify the IP address of the internal secondary DNS server.
Primary WINS server
Specify the IP address of the internal primary WINS server. Only IPv4 addresses are supported.
Secondary WINS server
Specify the IP address of the internal secondary WINS server. Only IPv4 addresses are supported.
Keepalive interval
Specify the keepalive interval. A client sends keepalive messages to the SSL VPN gateway to maintain sessions between them.
Start IP access client
Select this item to enable automatic startup of the IP access client after Web login. After a user logs in to the SSL VPN gateway through a Web browser, the IP access client on the user host will automatically start and connect to the gateway.
Push Web resources
Select this item to enable automatic pushing of accessible resources to a user through Web after the user logs in to the SSL VPN gateway through the IP access client.
Rate limit
Specify the rate limits for upstream traffic and downstream traffic.
Upstream traffic refers to the traffic sent from the user to the server. Downstream traffic refers to the traffic sent from the server to the user.
Packet drop logging
Select this item to enable logging for IP access packet drop events. The SSL VPN gateway generates logs when packets for SSL VPN IP access users are dropped.
IP connt close logging
Select this item to enable logging for IP access connection close events. The SSL VPN gateway generates logs when the connections established for SSL VPN IP access users are closed.
IP addr asgmt and release logging
Select this item to enable logging for IP address assignment and release events. The SSL VPN gateway generates logs when it assigns or releases an IP address to or from the VNIC of the SSL VPN client.
Configure authentication settings
The authentication mode for users to log in to an SSL VPN context includes password authentication, certificate authentication, and IMC SMS verification.
To configure authentication settings
On the Authentication Settings tab, configure the authentication settings.
Figure-30 Configuring authentication settings
Table-16 Configuration items for authentication settings
Item
Auth server type
Select an authentication server type, including:
  • AAA—If you select AAA, configure an ISP domain.
  • CUSTOM—If you CUSTOM, configure related settings from CLI. For more information, see the SSL VPN configuration guide for the device.
  • SMP—If you SMP, configure the security platform address, security platform key, and authentication platform type.
Security platform addr
Specify the security platform address. After the security platform address is specified, the SSL VPN gateway will communicate with the security platform to authenticate users.
VRF
Select a VPN instance to which the security platform belongs.
Security platform key
Specify a security platform key. For the SSL VPN gateway to establish a connection with the security platform, the gateway must provide this key to the security platform. The security platform uses this key to authenticate the SL VPN gateway. The connection can be established only after the SSL VPN gateway passes authentication.
Auth platform type
Select the type of the third-party authentication platform that interoperates with the security platform. Only Paraview is available in the current software version.
ISP domain
Select the ISP domain used for authentication, authorization, and accounting.
Certificate auth
Select this item to enable certificate authentication.
To use certificate authentication, make sure client authentication is enabled in the SSL server policy. The SSL VPN gateway uses the digital certificate sent by an SSL VPN client to authenticate the client.
Username attribute
Select the certificate attribute to be used as the SSL VPN username. By default, the CN attribute in the Subject field of a certificate is used as the username.
Enable password authentication
Select this item to enable password authentication.
After password authentication is enabled, a user can use the username and password to log in to the SSL VPN Web interface.
Certificate and pwd authN
Select the authentication mode for users if both certificate and password authentication methods are enabled.
To require users to pass both certificate and password authentications, select Use all methods. To require users to pass either certificate or password authentication, select Use any method.
Code verification
Select this item to enable code verification.
After code verification is enabled, a user must enter a correct verification code to log in to the SSL VPN Web interface.
IMC user pwd modify
Select this item to enable password modification for IMC authentication users. You must specify the IMC server's IP address and port number, and the VRF instance to which the IMC server belongs.
For this feature to take effect, make sure the online password change feature is enabled.
SMS verification-IMC
Select IMC to enable IMC SMS verification.
After IMC SMS verification is enabled, an SSL VPN client can dynamically obtain a verification code for SSL VPN getaway login authentication.
The administrator must configure SMS verification settings on the IMC server in advance.
SMS verification-SMS Gateway
Select SMS Gateway to enable SMS gateway verification.
After SMS gateway verification is enabled, an SSL VPN client can dynamically obtain a verification code for SSL VPN getaway login authentication.
The administrator must configure SMS verification settings on the SMS gateway in advance.
Enable WeChat Work authN
Select this item to enable WeChat Work authentication.
To use this feature, make sure the following tasks have been completed:
  • Configuring the company Apps on the WeChat Work management platform.
  • Configuring the App homepage redirect link and the trusted domain name of the SSL VPN gateway for each App on the WeChat Work management platform.
  • Completing the domain name ownership verification: download the domain name ownership verification file from the WeChat Work management platform, and then upload the file on the Network > VPN > SSL VPN > Global Settings page.
After the WeChat Work authentication is enabled, the device obtains user information from the third party of WeChat Work and uses the user information for authentication and authorization.
Agent ID
To authenticate and authorize users by using the QR code in WeChat Work, you must specify the agent ID.
API server address
Enter a WeChat Work API server address.
With this address configured, the device interacts with the WeChat Work API server to obtain user information on receiving a message redirected from the WeChat Work server. Then, the device uses the obtained information for user authentication and authorization.
Corp ID
Enter the company ID, which uniquely identifies a company on the WeChat Work.
App secret
Enter an App secret key.
Each App has an independent access key. For data security, make sure the App secret key is not leaked.
AuthN request timeout
Enter the timeout time of the authentication request sent from the SSL VPN gateway to the API server. A WeChat Work authentication fails if the SSL VPN gateway does not receive the response from the API server within the timeout time after sending an HTTP request.
User ID field name
Enter a user ID field name. The SSL VPN gateway uses this item to construct the parameter that carries user information in the access requests sent to the internal server.
AuthZ policy group field name
Enter an authorization policy group name. The SSL VPN gateway uses this item to obtain the authorization policy group name from the response of the WeChat Work API server.
WeChat open platform URL
Select a method to configure a WeChat open platform URL. Options include:
  • Predefined—The URL is https://open.weixin.qq.com by default, which cannot be edited.
  • User-defined—You can enter a URL as needed.
After this item is configured, the client can access the WeChat open platform directly to complete the authentication when the internal server requires client authentication again.
Brute-force cracking prevention
To prevent brute-force cracking, follows these restrictions:
  • If the number of consecutive login failures reaches the specified threshold, enable captcha verification.
  • The number of consecutive login failures on an IP reaches the specified threshold, lock the IP for the specified period. You can use the IP only after the locking period expires.
Configure URI ACL resources
You can create multiple URI ACLs in an SSL VPN context.
A URI ACL is a set of rules that permit or deny access to resources. You can add multiple rules to a URI ACL. The device matches a packet against the rules in ascending order of the rule ID. The match process stops once a matching rule is found.
A URL ACL can be used for the following purposes:
To configure URI ACL resources
  1. On the URI ACL Resources tab, click Create.
    Figure-31 URI ACL resoruces
  2. On the Add URI ACL page that opens, enter an ACL name.
    Figure-32 Creating a URI ACL list
  3. In the URI ACL Resources section, click Create.
  4. On the Add URI ACL Rule page that opens, create a URI ACL rule.
    Figure-33 Creating a URI ACL rule
    Table-17 Configuration items for a URI ACL rule
    Item
    Rule ID
    Enter a rule ID. A URI ACL matches packets according to rule IDs from smallest to largest, stopping once a rule is matched.
    Action
    Select the action for the matching packets. Options include Permit and Deny.
    URI pattern
    Enter a URI pattern in the format of protocol://host:port/path, where protocol and host are required.
  5. Click OK.
    The rule is displayed on the Add URI ACL page.
  6. Click OK.
    The URI ACL is displayed on the URI ACL Resources page.
  7. Click Next.
Configure shortcuts
To provide quick access to frequently accessed internal resources on the SSL VPN Web page, configure shortcuts for these resources and add the shortcuts to a shortcut list.
You can create multiple shortcut lists in an SSL VPN context.
To configure shortcuts:
  1. On the Shortcut tab, click Create in the Shortcut section.
    Figure-34 Shortcuts tab
  2. On the page that opens, configure a shortcut, and then click OK.
    Figure-35 Configuring a shortcut
    Table-18 Configuration items for a shortcut
    Item
    Shortcut name
    Enter a name for the shortcut.
    Enter a description for the shortcut.
    Resource address
    Specify the resource address for the shortcut. SSL VPN users can click the link on the SSL VPN Web interface to access the resource. You can configure a resource address in one of the following methods:
    • Enter a resource link in the format of url('url-value'). The url-value argument specifies the corresponding resource. The complete format for url-value is protocol://hostname or address:port number/resource path.
    • Enter an application path in the format of app('app-value'). The app-value argument specifies the corresponding resource. The complete format for app-value can be an absolute path or environment variable, for example, c:\windows\system32\notepad++.exe.
    • Enter an executable JavaScript for a resource to provide access to the resource.
  3. In the Shortcut List section, click Create.
  4. On the page that opens, configure a shortcut list, and then click OK.
    Figure-36 Configuring a shortcut list
    Table-19 Configuration items for a shortcut list
    Item
    List name
    Enter a shortcut list name.
    Select shortcuts
    Select shortcuts to add them to the shortcut list.
  5. Click Next.
Configure user management
  1. On the User Management tab, click Create in the User Management section.
  2. Create a user management item.
    Figure-37 User Management tab
    Figure-38 Creating a user management item
    Table-20 User management configuration items
    Item
    Username
    Enter the username of an SSL VPN user.
    Phone number
    Enter the phone number bound to the SSL VPN user.
    Auto binding on the Bind IPv4 Addresses tab
    If you select Auto binding on the Bind IPv4 Addresses tab, the SSL VPN gateway will automatically assign IPv4 addresses to clients and bind these IPv4 addresses to the user. You can specify the number of available IPv4 addresses to be bound.
    Auto binding on the Bind IPv6 Addresses tab
    If you select Auto binding on the Bind IPv6 Addresses tab, the SSL VPN gateway will automatically assign IPv6 addresses to clients and bind these IPv6 addresses to the user. You can specify the number of available IPv6 addresses to be bound.
    IPv4 Addresses to be Bound
    Specify the comma-separated IPv4 address items. Each item specifies an IPv4 address or a range of IPv4 addresses in the form of start address-end address. The end address must be higher than the start address, for example, 10.1.1.5,10.1.1.10-10.1.1.20. Multicast, broadcast, and loopback addresses are not supported.
    IPv6 Addresses to be Bound
    Specify the comma-separated IPv6 address items. Each item specifies an IPv6 address or a range of IPv6 addresses in the form of start address-end address. The end address must be higher than the start address, for example, 1234::10,1234::100-1234::200. Only unicast and anycast addresses are supported. Unspecified, multicast, and loopback addresses are not supported.
  3. Click OK.
  4. Click Finish.
Configure global SSL VPN settings
Login page customization
To use a template file to customize the display content on the SSL VPN log page.
  2. In the navigation pane, select VPN > SSL VPN > Global Settings.
  3. In the Login page customization area, select a webpage template from the drop-down list. The SSL VPN gateway login page will display content defined in the template.
    Figure-39 Login page customization
Manage templates on the SSL VPN login page
An SSL VPN page template defines the style of the SSL VPN gateway login and resource pages. You can customize the login page template as needed.
To manage templates:
  2. In the navigation pane, select VPN > SSL VPN > TempManagement.
    Figure-40 Template management
  3. Click Create.
    The Create Template page opens.
  4. Select a template file.
    Figure-41 Creating a template
  5. Click OK.
    After the template file is uploaded, you can associate the template on the Global Settings or Edit SSL VPN Context page.
Custom IP access client
IP access clients to be downloaded by SSL VPN users are typically stored on the device. However, IP access clients cannot be deployed on a device with small storage space.
To resolve this issue, you can specify the official website or a custom URL as the download path for IP access clients.
To customize IP access client settings:
  3. In the Custom IP access client area, select a method for downloading IP access clients based on the OS type. Options include:
    • Device—Downloads the IP access client download from the local device. Only the Windows system supports this method. To use this method, you must obtain the genuine client file from the official channel and upload it to the device.
    • Official website—Downloads the IP access client from the official website.
    • Custom—Downloads the IP access client from a URL.
    Figure-42 Custom IP access client
  4. Click Apply.
Single sign-on
  3. Click Export user custom configuration to download an SSO file. Fill in context names, URL items, login usernames, and resource usernames and passwords as prompted in the downloaded file. Then, save the downloaded file to the local.
    Figure-43 Single sign-on
  4. Click Import user custom configuration. On the page that opens, click Select to select an SSO file. Then, click Apply to import the selected SSO file.
    Figure-44 Importing user custom configuration
WeChat Work domain name ownership verification file
  3. In the WeChat Work domain name ownership verification code area, click Select file, select the domain name verification file from the back end of the WeChat Work admin console, and then click Upload.
    Figure-45 WeChat Work domain name ownership verification file
    To obtain the domain name verification file:
    1. Enter https://work.weixin.qq.com in the browser and use the WeChat Work client to scan the QR code to log in to the WeChat Work admin console. Then, click App Management and select an app.
    2. In the Web Authorization and JS-SDK area, click Apply for domain name verification. In the window that opens, enter the domain name and port number of the SSL VPN gateway in the gateway.example.com:port format in the Trustable Domain Names field.
    3. Click Domain name to be verified and download the verification file as instructed. Then, upload the verification file on the SSL VPN Web interface.
    Do not edit the downloaded verification file after downloading.
Quantum encryption
  3. In the Quantum Encryption area, click GD-Quantum or CSP-Quantum as needed.
    Figure-46 GD-quantum encryption
    Figure-47 CSP-quantum encryption
    Table-21 Configuration items for GD-quantum keys
    Item
    Exchange Cipher Machine IP
    Enter the IP address of the exchange cipher machine. Make sure you specify the IP address that the GD-quantum exchange cipher machine actually uses.
    Exchange Cipher Machine Port
    Enter the port number of the exchange cipher machine. Make sure you specify the port number that the GD-quantum exchange cipher machine actually uses.
    Exchange Cipher Machine ID
    Enter the GD-quantum exchange cipher machine ID. To obtain the GD-quantum exchange cipher machine ID, contact the GD-quantum administrator.
    Cipher Service Platform ID
    Enter the GD-quantum cipher service platform ID. To obtain the GD-quantum cipher service platform ID, contact the GD-quantum administrator.
    Application Account
    Enter the GD-quantum application account. To obtain the GD-quantum application account, contact the GD-quantum administrator.
    Table-22 Configuration items for CSP-quantum keys
    Item
    Enter the IP address of the exchange cipher machine. Make sure you specify the IP address that the CSP-quantum exchange cipher machine actually uses.
    Enter the port number of the exchange cipher machine. Make sure you specify the port number that the CSP-quantum exchange cipher machine actually uses.
    Application Account
    Enter the CSP-quantum application account. To obtain the CSP-quantum application account, contact the CSP-quantum administrator.
  4. Click Apply.
IP access flow redirect
If NAT OpenFlow entry deployment is disabled, the device cannot use the NAT module for flow redirect. In this case, To ensure normal processing of the IP access service, enable IP access flow redirect.
  3. In the IP access floe redirect area, click the toggle button to the IP access flow redirect field.
    Figure-48 IP access flow redirect
FAQ
After I change resource authorization settings in SSL VPN, the settings do not take effect immediately. Why?
The SSL VPN gateway does not support dynamic authorization. Table-23 describes how and when changed resource authorization settings in SSL VPN will take effect.
Table-23 How and when changed authorization settings take effect
Changed item
How and when the changes take effect
Authorization to a remote server
The changes take effect only on new users. Users already logged in are not affected.
ACL or ACL rules in a resource group
For tunnel service, TCP proxy, and Web proxy users, the changes take effect immediately.
Accessible Web resources
The changes take effect after the user refreshes the SSL VPN Web page.
Accessible TCP resources
The changes take effect after the user restarts the TCP proxy client software.
Routing entries, DNS server address, and WINS server address configured for the tunnel service
The changes take effect immediately.
Do SSL VPN users need to pass certificate authentication to log in to an SSL VPN gateway?
Whether users need to pass certificate authentication to log in to an SSL VPN gateway depends on the following settings:
Table-24 describes the possible certificate authentication methods that users might encounter when connecting the SSL VPN gateway.
Table-24 Certificate authentication methods
Authentication method
Certificate authentication disabled
The user will not be asked to select a certificate for authentication when connecting the SSL VPN gateway through the Web browser.
Mandatory certificate authentication enabled
The user will be asked to select a certificate for authentication when connecting the SSL VPN gateway through the Web browser. The connection request will be rejected if the user does not have a certificate.
Optional certificate authentication enabled
The user will be asked to select a certificate for authentication when accessing the SSL VPN gateway through the Web browser. A connection to the SSL VPN gateway will be established in either of the following situations:
  • The user selects a certificate and passes the identity authentication.
  • The user chooses not to select a certificate and proceed with the connection request.
If you want users to pass certificate authentication to log in to an SSL VPN gateway, make sure the following requirements are met:
After receiving the client certificate, the SSL VPN gateway will extract the username from the CN field of the certificate, and then sends the username to the AAA server. The user passes the authentication only when extracted username exists on the local AAA server.
Mandatory certificate authentication is supported only for Web users and tunnel service users. For TCP proxy users and mobile client users to access the SSL VPN gateway successfully, you need to enable the optional SSL client authentication.
