This help contains the following topics:
This feature enables the device to learn the MAC address of a terminal (a PC for example) when a Layer 3 device (typically a gateway) exists between the device and the terminal for network traffic control.
Figure-1 MAC address learning through a Layer 3 device workflow
As shown in Figure-1, MAC address learning through a Layer 3 device proceeds as follows:
The Layer 3 device learns the IP-MAC binding of the terminal, and then generates an ARP entry.
The device sends SNMP requests to the Layer 3 device at the specified intervals to request the ARP entry.
The Layer 3 device sends a response that contains the ARP entry.
Upon receiving the response, the device saves the ARP entry in the memory. Then it can learn the MAC address of the terminal.
Only MAC addresses mapped from IPv4 addresses can be learned.
Make sure no NAT devices exist between the device and the Layer 3 device.
This feature is not applicable to a VRF network.
Complete the following tasks before you configure this feature:
Assign IP addresses to interfaces on the
Configure routes on the
Create security zones on the
Add interfaces to security zones. You can add interfaces to a security zone on the
Configure security policies to permit the target traffic on the
Make sure the Layer 3 device supports SNMPv2c or SNMPv3, has SNMP agent enabled, and has a community name configured.
When terminals use dynamic IP addresses for network access, IP address-based traffic filtering can no longer provide precise access control. In such cases, MAC addresses must be used as a supplementary criterion to filter traffic. However, in a scenario deployed with multiple Layer 3 devices, a device cannot directly obtain the MAC addresses of terminals connected to other Layer 3 devices. To resolve this issue, enable MAC address learning through Layer 3 devices.
Select
Click
Figure-2 Enabling MAC address learning through a Layer 3 device
(Optional.) Set the polling interval and idle timeout
Table-1 Configuration items for MAC address learning through a Layer 3 device
Item | Description |
Polling interval | Interval for sending SNMP requests, in seconds |
Idle timeout | Idle timeout for SNMP responses, in seconds |
Click
Add a Layer 3 device:
Click
Figure-3 Adding a Layer 3 device running SNMPv2c
Figure-4 Adding a Layer 3 device running SNMPv3
Configure the following settings:
Table-2 Layer 3 device settings
SNMP version | SNMP version. Options include v2c and v3. |
IP address | IP address of the target Layer 3 device, typically the gateway of the terminal network. Only IPv4 addresses are supported. |
Community name (SNMPv2c) | Devices in a community use a community name for authentication. The device can communicate with the Layer 3 device only if it has the same community name as the SNMP agent on the Layer 3 device. |
Username (SNMPv3) | Authentication can be performed only if the device and the SNMP agent on the Layer 3 device have the same username. |
Authentication algorithm | For a successful authentication, make sure these settings are the same as those on the SNMP agent of the Layer 3 device. |
Authentication password | |
Encryption algorithm | |
Encryption password |
Click
After MAC address learning is completed, you can view the learning records the
Figure-5 Learned ARP entries
