This help contains the following topics:
An access control list (ACL) is a set of rules for identifying traffic based on criteria such as source IP address, destination IP address, and port number. The rules are also called permit or deny statements. The device processed identified traffic according to the configured policy.
Table-1 ACL types
Type | IP version | Number range | Match criteria |
Basic ACLs | IPv4 | 2000 to 2999 | Source IPv4 address. |
IPv6 | 2000 to 2999 | Source IPv6 address. | |
Advanced ACLs | IPv4 | 3000 to 3999 | Source IPv4 address, destination IPv4 address, packet priority, protocol number, and other Layer 3 and Layer 4 header fields. |
IPv6 | 3000 to 3999 | Source IPv6 address, destination IPv6 address, packet priority, protocol number, and other Layer 3 and Layer 4 header fields. | |
Layer 2 ACLs | IPv4 and IPv6 | 4000 to 4999 | Layer 2 header fields, such as source and destination MAC addresses, 802.1p priority, and link layer protocol type. |
User-defined ACLs | IPv4 and IPv6 | 5000 to 5999 | User specified matching patterns in protocol headers. |
Table-2 Sorting ACL rules in depth-first order
ACL type | Sequence of tie breakers |
IPv4 basic ACL |
IPv4 advanced ACL |
IPv6 basic ACL |
IPv6 advanced ACL |
Layer 2 ACL |
If you do not assign an ID to the rule you are creating, the system automatically assigns it a rule ID. The rule numbering step sets the increment by which the system automatically numbers rules. For example, if the ACL rule numbering step is 5 and you do not assign IDs to rules you are creating, they are automatically numbered 0, 5, 10, 15, and so on. The wider the numbering step, the more rules you can insert between two rules.
By introducing a gap between rules rather than contiguously numbering rules, you have the flexibility of inserting rules in an ACL. This feature is important for a config-order ACL, where ACL rules are matched in ascending order of rule ID.
The ID automatically assigned to an ACL rule takes the nearest higher multiple of the numbering step to the current highest rule ID, starting with 0.
For example, if the step is 5, and there are five rules numbered 0, 5, 9, 10, and 12, the newly defined rule is numbered 15. If the ACL does not contain a rule, the first rule is numbered 0.
Whenever the step changes, the rules are renumbered, starting from 0. For example, changing the step from 5 to 2 renumbers rules 5, 10, 13, and 15 as rules 0, 2, 4, and 6.
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
You can create an ACL on the ACL page or on the page for a feature that uses the ACL. However, you can manage ACLs (for example, modify or delete ACLs) only on the ACL page.
Deleting or modifying an ACL might affect the feature that uses the ACL.
If the match order for an ACL is config, you can modify any rules in the ACL. If the match order for an ACL is auto, you cannot modify any rules in the ACL.
Complete the following tasks before you configure this feature:
Assign IP addresses to interfaces on the
Configure routes on the
Create security zones on the
Add interfaces to security zones. You can add interfaces to a security zone on the
Configure security policies to permit the target traffic on the
Click the
In the navigation pane, select
On the
On the
Figure-1 Creating an IPv4 ACL
Figure-2 Creating a rule for an IPv4 basic ACL
Figure-3 Creating a rule for an IPv4 advanced ACL
Table-3 IPv4 ACL configuration items
Item | Description |
Type. |
ACL | Configure an ACL name.
Rule match order | The rules in an ACL are sorted in a specific order. When a packet matches a rule, the device stops the match process and performs the action defined in the rule. Options include
Default numbering step | Configure the rule numbering step. |
Description | Configure a description for the ACL. |
OK & Add Rule | If you do not continue to add rules, this ACL is empty. If you need to configure rules for the IPv4 ACL, you must click this button. Table-4 describes the rule configuration items. |
Table-4 IPv4 ACL rule configuration items
ACL number | Configure an ACL name, which is automatically populated with the ACL field configured in Table 1 and does not need to be configured. |
Rule ID | Enter a rule ID. The rule numbering methods include:
If the specified rule ID already exists, the rule will be changed to the new configuration. |
Action | Select the action to take on packets matching the rule.
IP protocol type | Select the protocol type carried over IP. If you select This parameter is not available for an IPv4 basic ACL. |
Match criteria |
An IPv4 basic ACL supports only the following match criteria: source IPv4 address/wildcard mask, source IPv4 address object group. For an IPv4 advanced ACL, the supported match criteria vary by IP protocol type. |
Time range | If you select the time range when the rule takes effect, you can select an existing time range. To create a new one, click
The active period of a time range is calculated as follows:
VRF | Specify a VPN instance. If you select |
Fragments | Select this option to configure the rule to take effect only on non-first fragments and not take effect on first fragments and non-fragments. If you do not select this option, the rule takes effect on both non-fragments and fragments. |
Logging | Select this option to configure the rule to log packets matching the rule. The log information includes the ACL rule ID, action to take on matching packets (permit or deny), upper-layer protocol carried over IP, source/destination IP address, source/destination port number, and number of matching packets. |
Counting | Select the option to enable rule match counting for the rule. |
OK & Add More | Click this button to continue to configure the next ACL rule. |
Click
Click the
On the
On the
Figure-4 Creating an IPv6 ACL
Figure-5 Creating a rule for an IPv6 basic ACL
Figure-6 Creating a rule for an IPv6 advanced ACL
Table-5 IPv6 ACL configuration items
Type |
OK & Add Rule | If you do not continue to add rules, this ACL is empty. If you need to configure rules for the IPv6 ACL, you must click this button. Table-6 describes the rule configuration items. |
Table-6 IPv6 ACL rule configuration items
IP protocol type | Select the protocol type carried over IP. If you select This parameter is not available for an IPv6 basic ACL. |
Match criteria |
An IPv6 basic ACL supports only the following match criteria: source IPv6 address/wildcard mask, source IPv6 address object group. For an IPv6 advanced ACL, the supported match criteria vary by IP protocol type. |
Click
Click the
On the
On the
Figure-7 Creating a Layer 2 ACL
Figure-8 Creating a rule for a Layer 2 ACL
Table-7 Layer 2 ACL configuration items
ACL | Configure an ACL name, a number in the range of 4000 to 4999 or a string of 1 to 63 characters. |
OK & Add Rule | If you do not continue to add rules, this ACL is empty. If you need to configure rules for the Layer 2 ACL, you must click this button. Table-8 describes the rule configuration items. |
Table-8 Layer 2 ACL rule configuration items
Description | Configure a description for the ACL |
Match criteria |
Click
