This help contains the following topics:
Virtual Routing and Forwarding (VRF) implements route isolation, data independence, and data security for VPNs.
A VRF has the following components:
A separate Label Forwarding Information Base (LFIB).
An IP routing table.
Interfaces bound to the VRF.
VRF administration information including a route distinguishers (RD).
An RD is added before a site ID to distinguish the sites that have the same site ID but reside in different VPNs. An RD and a site ID uniquely identify a VPN site.
An RD is a string of 3 to 21 characters in one of the following formats:
16-bit AS number:32-bit user-defined number. For example, 101:3.
32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
32-bit AS number:16-bit user-defined number, where the minimum value of the AS number is 65536. For example, 65536:1.
VRFs can be bound to the multiple instances of a multicast or routing protocol to implement service isolation. For example, if a device supports multiple OSPF instances, you can bind a VRF to each OSPF process, so that routes learned by an OSPF process are added into the routing table of the bound VRF.
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Click the Network tab.
In the navigation pane, select Interface Configuration > VRF.
Click Create.
The Create VRF page opens.
Configure the VRF parameters.
Table-1 VRF configuration items
Item | Description |
VRF | Enter the name of a VPN instance (VRF). |
Description | Configure a description for the VPN instance. |
RD | Configure a route distinguisher for the VPN instance. The address spaces of VPNs might overlap. RD is used to distinguish the overlapping IP addresses of VPNs. An eight-byte RD is added to an IPv4 prefix to form a unique VPN-IPv4 address. |
IPv4 route limit IPv6 route limit | Specify the maximum number of active route prefixes in the VPN instance. |
Overrun action |
Alarm threshold | Set an alarm threshold in the range of 1 to 100 in percentage. This parameter is not available if you select the Reject new routes action. |
Associated interfaces | Select the interfaces to be associated with the current VPN instance. |
Click OK.
