URL filtering
This help contains the following topics:
Introduction
URL filtering controls access to the Web resources by filtering the URLs that the users visit.
URL
A URL is a reference to a resource that specifies the location of the resource on a network and a mechanism for retrieving it. The syntax of a URL is protocol://hostname[:port]/path/[;parameters][?query]#fragment. Figure-1 shows an example URL.
Figure-1 URL syntax
Table-1 describes the fields in a URL.
Table-1 URL field descriptions
protocol
Transmission protocol, such as HTTP.
host
Domain name or IP address of the server where the indicated resource is located.
[:port]
Optional field that identifies the port number of the transmission protocol. If this field is omitted, the default port number of the protocol is used.
/path/
String that identifies the directory or file where the indicated resource is stored. The path is a sequence of segments separated by zero or multiple forward slashes.
[parameters]
Optional field that contains special parameters.
[?query]
Optional field that contains parameters to be passed to the software for querying dynamic webpages. Each parameter is a <key>=<value> pair. Different parameters are separated by an ampersand (&).
URI
Uniform resource identifier that identifies a resource on a network.
URL filtering rule
A URL filtering rule matches URLs based on the content in the URI or hostname field.
URL filtering provides the following types of URL filtering rules:
A URL filtering rule supports the following URL matching methods:
URL category
URL filtering provides the URL categorization feature to facilitate filtering rule management.
You can classify multiple URL filtering rules to a URL category and specify an action for the category. If a matching rule is in multiple URL categories, the system takes the action for the category with the highest severity level.
URL filtering supports the following types of URL categories:
URL filtering profile
A URL filtering profile can contain multiple URL categories, and each category has an action defined for packets that match a filtering rule in the category. You can also specify the default action for packets that do not match any filtering rules in the profile.
URL filtering whitelist/blacklist rule
The device supports using URL-based whitelist and blacklist rules to filter HTTP packets. If the URL in an HTTP packet matches a blacklist rule, the packet is dropped. If the URL matches a whitelist rule, the packet is permitted to pass through.
URL filtering cloud query
You can enable cloud query in a URL filtering profile to improve URL filtering accuracy for HTTP traffic.
With cloud query enabled, the device will send URLs that do not match any local URL filtering rules to the cloud server for further query. The device determines the action to apply according to the query result returned from the cloud server.
Datagram Transport Layer Security (DTLS) is a security protocol designed to protect datagram protocols. It is suitable for low-delay scenarios such as real-time communication (VoIP, video conferencing), IoT devices (wireless sensor networks), and streaming services.
HyperText Transfer Protocol Secure (HTTPS) is a protocol for transmitting hypertext data via a secure communication channel. It is suitable for scenarios requiring secure data transfer, such as online banking, social media platforms, email services, and Web applications that require user authentication and data encryption.
URL filtering action
You can specify URL filtering actions for URL categories and specify the default action for a URL filtering profile.
The device supports the following URL filtering actions:
URL filtering mechanism
URL filtering takes effect after you apply a URL filtering profile to a security policy rule.
As shown in Figure-2, upon receiving an HTTP packet, the device performs the following operations:
  1. The device compares the packet with the security policies.
    If the packet matches a security policy that is associated with a URL filtering profile, the device extracts the URL from the packet.
  2. The device compares the extracted URL with the whitelist and blacklist rules in the URL filtering profile.
    • If the URL matches a whitelist rule, the packet is permitted to pass through.
    • If the URL matches a blacklist rule, the packet is dropped.
    • If the URL does not match any whitelist or blacklist rule in the profile, the device performs step 3.
  3. The device compares the extracted URL with the URL filtering rules in the URL filtering profile.
    • If the URL matches a URL filtering rule that belongs to a user-defined URL category, the devices takes the action specified for the URL category.
      If the URL filtering rule belongs to multiple user-defined URL categories, the action specified for the URL category with the highest severity level apply.
    • If URL reputation is enabled, the device determines whether the matching URL filtering rule belongs to an attack category in the URL reputation signature library. If yes, the device takes the action specified for the attack category on the packet.
    • If the URL matches a URL filtering rule that belongs to a predefined URL category, the devices takes the action specified for the URL category.
      If the URL filtering rule belongs to multiple predefined URL categories, the action specified for the URL category with the highest severity level apply.
    • If the URL does not match any rule in the policy, and cloud query is disabled in the profile, the default action specified for the policy applies. If the default action is not configured, the device permits the packet to pass through.
    • If the URL does not match any rule in the policy, and cloud query is enabled in the policy, the device performs step 4.
  4. The device forwards the URL to the cloud server for further query.
    • If a matching rule is found for the URL, the device determines the action to take on the packet as described in step 3.
    • If no matching rule is found, the device executes the default action of the policy on the packet. If the default action is not configured, the device permits the packet to pass through.
    Figure-2 URL filtering mechanism
vSystem support information
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Licensing requirements
To use URL filtering, you must purchase and install the required license. If the license expires, the existing URL filtering signature library is still available but you cannot upgrade the library on the device or perform a URL filtering cloud query task. For more information about licensing, see the license management help.
Restrictions and guidelines: Configuration submission
Restrictions and guidelines: Text-based URL filtering rule configuration
Follow these guidelines when you use the asterisk character (*) in the text pattern for hostname or URI matching:
Restrictions and guidelines: Regular expression-based URL filtering rule configuration
Restrictions and guidelines: Whitelist
Restrictions and guidelines: URL filtering cloud query
Support for URL filtering cloud query depends on the device model.
Configure URL filtering
Configure URL filtering as shown Figure-3.
Figure-3 URL filtering configuration procedure
Configure a URL category
Perform this task to create a user-defined URL category and configure filtering rules for it to meet specific URL filtering requirements.
  1. Click the Objects tab.
  2. In the navigation pane, select Security Configuration File > URL Filtering > URL Categories.
  3. Click Create.
  4. Create a URL category.
    Table-2 URL category configuration items
    Item
    Name
    Enter a name for the URL category. The category name cannot start with Pre-.
    Enter a description for the URL category.
    Severity level
    Assign a unique severity level in the range of 1000 to 65535 to the URL category. The larger the value, the higher the severity level.
    Include predefined category
    Select a predefined URL category to add all its rules to the URL category.
  5. Add URL filtering rules to the URL category:
    1. Click Add.
    2. From the Match pattern list, select the match pattern type for the host name field. Options are Text and Regular expression.
    3. Enter the match pattern for the host name field.
    4. From the Match pattern list, select the match pattern type for the URI field. Options are Text, Regular expression, and –NONE—.
    5. Enter the match pattern for the URI field. This step is not required if the –NONE— option is selected for the match pattern of the URI field.
    6. Click OK.
    7. Repeat the preceding steps to add more URL filtering rules.
  6. Click OK.
    The URL category is displayed on the URL Categories page.
Configure the cloud query server
Perform this task to configure the cloud query server for URL filtering.
  3. Click Configure next to the Cloud server connection status field.
  4. Configure the cloud query server.
    Table-3 Cloud query server configuration items
    Item
    Server address
    Enter the IP address or hostname of the cloud query server. Only the cloud query server of our company is supported.
    Max cached URL entries
    Specify the maximum number of URL entries that can be cached.
    The device creates a URL cache entry for each unique URL submitted to the cloud query server for cloud query. The cloud query result will be stored in the cache entry.
    Min cache period
    Specify the minimum cache period for a URL cache entry in minutes.
    Setting the minimum cache period for URL cache entries ensures that the entries will not be deleted during the specified period of time.
    When the URL filtering cache is full, the system identifies the cache period of the oldest URL cache entry to determine whether to overwrite it:
    • If the cache period of the entry is equal to or less than the minimum cache period, the system does not delete the entry. The new entry is not cached.
    • If the cache period of the entry is greater than the minimum cache period, the system overwrites the entry with the new entry.
    However, if the configured maximum number of cached URL entries is less than that of the currently cached entries, the system will delete the oldest cache entries even if their cache periods are equal to or less than the minimum cache period.
    Protocol
    Protocol for the cloud server, including:
    • DTLS—Suitable for low-delay scenarios such as real-time communication (VoIP, video conferencing), IoT devices (wireless sensor networks), and streaming services.
    • HTTPS—Suitable for scenarios requiring secure data transfer, such as online banking, social media platforms, email services, and Web applications that require user authentication and data encryption.
    Configure Proxy Server
    Configure the proxy server's address, port, and the username and password for logging in to the proxy server. This field is available only when the cloud server protocol is HTTPS.
Configure a URL filtering profile
You can configure the following settings in a URL filtering profile:
  3. Click Create.
  4. Create a URL filtering profile.
    Table-4 URL filtering profile configuration items
    Item
    Name
    Enter a name for the URL filtering profile.
    Default action
    Select the default action to take on packets that do not match any URL filtering rules. Options are Permit, Drop, Reset, Redirect, and Blacklist.
    Cloud query
    Select the box to enable cloud query.
    Logging
    Select the box to enable logging for packets matching URL filtering rules.
    Before you select this item, configure the default action first.
    Alarm message template
    Select an alarm template. This template enables the device to send an alarm message to a client when the URL requested by the client is blocked by URL filtering.
    For more information about the template configuration, see security action online help.
    Enable HTTPS URL filtering
    Select the box to enable URL filtering on undecrypted HTTPS traffic.
    If the SSL decryption action is selected in any enabled proxy policy, this feature does not take effect. For more information about SSL decryption, see proxy policy online help.
    Enable referer whitelist
    Select the box to allow an HTTP request to pass if its referer header matches the URL filtering whitelist.
    Whitelist mode
    Select the box to allow users to access the websites in the URL filtering whitelist only.
    Whitelist
    Add whitelist rules to the URL filtering profile as needed.
    To add a whitelist rule to the URL filtering profile:
    1. In the Whitelist area, click Add.
    2. The Add Whitelist Rule window opens.
    3. From the Match pattern list, select the match pattern type for the host name field. Options are Text and Regular expression.
    4. Enter the match pattern for the host name field.
    5. From the Match pattern list, select the match pattern type for the URI field. Options are Text, Regular expression, and –NONE—.
    6. Enter the match pattern for the URI field. This step is not required if the –NONE—option is selected for the match pattern of the URI field.
    Blacklist
    Add blacklist rules to the URL filtering profile as needed.
    URL categories
    In the URL categories area, select the actions for individual URL categories. Supported actions are Permit, Drop, Reset, Redirect, Blacklist, and Logging.
    Before you select the logging action for a URL category, select an action among the Permit, Drop, Reset, Redirect, and Blacklist actions first.
    Enable URL reputation
    Select the box to enable URL reputation to block access to malicious URLs. With this feature enabled, the device will compare the URL extracted from a packet with the URLs in the URL reputation signature library. If a match is found, the URL is considered a malicious URL and the actions specified for the attack category where the matching URL belongs will be taken. If no match is found, the device permits the packet to pass through.
    Action configuration
    Configure the actions for individual attack categories in the URL reputation signature library.
  5. Click OK.
    The URL filtering profile is displayed on the URL Filtering Profiles page.
  6. Use the URL filtering profile in a security policy.
    For more information about security policies, see security policy online help.
  7. To have the configuration activated, click Submit.
    This operation can cause temporary DPI service outage. As a best practice, perform the operation after all DPI service configurations are complete.
