Terminal identification
This help contains the following topics:
Introduction
Identifying IoT terminals, such as cameras and sensors, is fundamental to establish secure Internet of Things (IoT) connections.
When the terminal traffic passes through a device, the device performs the following tasks:
Basic concepts
Terminal
You can predefine terminals in the device characteristics library to identify the terminal characteristics.
To enable terminal identification, select Objects > APP Security > Terminal Identification > Terminals, and then click Enable terminal identification logging.
Terminal group
You can add terminals sharing similar characteristics to a terminal group. The device can provide the same DPI service for packets of the same terminal group.
Object group for terminal identification
You can configure object groups for accurate terminal address identification. The device supports the following address object groups:
Terminal identification whitelist
The device permits the traffic of a terminal if the IP address of the terminal is in the terminal identification whitelist. Otherwise, the device drops the traffic of a terminal. The terminal identification whitelist supports the following actions:
Operating mode
Terminal identification supports the following operating modes:
To set an operating mode, select Objects > APP Security > Terminal Identification > Terminals, click Operating mode, and select an operating mode.
Workflow
Figure-1 Terminal identification workflow
Terminal identification works as follows:
vSystem support information
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Licensing requirements
To use terminal identification, you must purchase and install the required license. After the license expires, terminal identification can still use the existing APR signature library but cannot update the signature library. For more information about licensing, see the license management help.
In whitelist mode with the block action, the system drops traffic of a terminal in the whitelist when the terminal comes online for the first time. To permits the traffic of the terminal, click Approve for the terminal.
If you configure both a manager address object group or a terminal address object group, the manager address object group has higher priority.
Configure terminal identification
Configure a terminal group
  1. Click the Objects tab.
  2. In the navigation pane, select APP Security > Terminal Identification > Terminal Groups.
  3. Click Add.
  4. Select terminals from the Available Terminals pane and click Select to add them to the terminal group.
Configure an object group for terminal identification
  2. In the navigation pane, select APP Security > Terminal Identification > Terminals.
  3. Click Configure object groups for terminal identification.
  4. Configure a manager address object group or a terminal address object group, or configure both of them.
Configure the terminal identification whitelist
  3. Click Operating mode.
  4. Select Whitelist, and specify an action.
  5. Click OK.
  6. Click Configure object groups for terminal identification.
  7. Configure a terminal address object group.
