Simple Network Management Protocol (SNMP) is used for a management station to access and operate the devices on a network, regardless of their vendors, physical characteristics, and interconnect technologies.
SNMP enables network administrators to read and set the variables on managed devices for state monitoring, troubleshooting, statistics collection, and other management purposes.
The SNMP framework contains the following elements:
SNMP manager—Works on an NMS to monitor and manage the SNMP-capable devices in the network.
SNMP agent—Works on a managed device to receive and handle requests from the NMS, and sends notifications to the NMS when events, such as an interface state change, occur.
Management Information Base (MIB)—Specifies the variables (for example, interface status and CPU usage) maintained by the SNMP agent for the SNMP manager to read and set.
The device supports SNMPv1, SNMPv2c, and SNMPv3. For an NMS and an SNMP agent to establish an SNMP connection, they must use the same SNMP version.
SNMPv1—Uses community names for authentication. To access an SNMP agent, an NMS must use the same community name as set on the SNMP agent. If the community name used by the NMS differs from the community name set on the agent, the NMS cannot establish an SNMP session to access the agent or receive traps from the agent.
SNMPv2c—Uses community names for authentication. SNMPv2c is compatible with SNMPv1, but supports more operation types, data types, and error codes.
SNMPv3—Uses a user-based security model (USM) to secure SNMP communication. You can configure authentication and privacy mechanisms to authenticate and encrypt SNMP packets for integrity, authenticity, and confidentiality.
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Click the System tab.
In the navigation pane, select Maintenance > SNMP.
Enable SNMP.
Select one or multiple SNMP versions and set the common settings for the versions as described in the following table.
Table-1 Configuration items for SNMP versions and their common settings
Item | Description |
Version | Specify SNMP versions. Options are:
The device can receive packets of an SNMP version only after you specify that SNMP version. For an NMS and device to communicate, they must use the same SNMP version. If settings of multiple SNMP versions take effect, the device and NMS will negotiate for an SNMP version to communicate. The community name and data carried in SNMPv1 and SNMPv2c packets are in plaintext form, which has security risks. As a best practice, uses SNMPv3. To use SNMP notifications in an IPv6 environment, specify SNMPv2c or SNMPv3. |
Trap source interface | Select an interface as the source interface of traps. The system will use the primary IP address of that interface as the source IP of traps. The NMS will use that IP address to identify the agent. Even if the agent sends traps from multiple interfaces, the NMS can use that IP address to filter all traps from the agent. If the specified interface is configured with a valid IP address, the device will use that IP as the source IP of traps. This configuration does not take effect if the specified interface is not configured with a valid IP address, and will take effect automatically after the interface is configured with a valid IP. |
Location | Enter physical location of the device. For the device to be easily identified and managed, configure this parameter to record the physical location of the device on the device. |
Contact | Enter contact information of the device. This information helps the maintenance personnel to contact the device vendor in time when the device fails. |
Click Apply for the SNMP versions and their common settings to take effect.
Select an SNMP version and configure the settings for that version. For SNMPv1 and SNMPv2c settings, see Table-2. For SNMPv3 settings, see Table-3.
Click Apply for the SNMP settings to take effect.
Table-2 SNMPv1 and SNMPv2c configuration items
Read community | SNMP read community name, case sensitive. Using this community name, the NMS has only read access to the MIB objects on the agent. You can also specify escape characters (a backslash \ followed by characters) as the read community name. |
Write community | SNMP read-write community name, case sensitive. Using this community name, the NMS has read and write access to the MIB objects on the agent. You can also specify escape characters (a backslash \ followed by characters) as the read-write community name. |
Trap target host | Create the trap target host. You can configure multiple trap target hosts as required for the device to send traps to multiple NMSs.
Table-3 SNMPv3 configuration items
Username | SNMPv3 username, case sensitive. If the username changes, you must reconfigure the authentication and encryption passwords. |
Authentication algorithm | Select an SNMPv3 authentication algorithm. Options are:
Authentication password | Set an authentication password, which is case sensitive. For the device and NMS to establish an SNMP connection, the device and NMS must use the same authentication password. |
Encryption algorithm | Select an SNMPv3 encryption algorithm. Options are:
Encryption password | Set an encryption password, which is case sensitive. For the device and NMS to establish an SNMP connection, the device and NMS must use the same encryption password. |
