Single-packet attack logs
This help contains the following topics:
Introduction
Single-packet attacks are also known as malformed packet attacks. An attacker typically launches single-packet attacks by using the following methods:
To configure the device to output a log when it detects a packet with a specific signature, perform the following operations:
By default, log aggregation for single-packet attack events is enabled. The device aggregates multiple logs generated during a period of time and outputs one log. Logs that are aggregated must have the following attributes in common:
You can disable log aggregation for single-packet attack events on the System > Log Settings > Advanced Settings page. As a best practice, do not disable log aggregation if single-packet attacks frequently occur. A large number of logs will consume the display resources.
vSystem support information
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Manage single-packet attack logs
Import logs
  1. Click the Monitor tab.
  2. In the navigation pane, select Security Logs > Single-Packet Attack Logs.
  3. Click Import.
  4. In the dialog box that opens, click OK.
  5. Select a log file, and enter the password for the log file. The password was set when the file was exported.
Export logs
  3. Click on a column header, specify the search criteria to display the logs to be exported, and then click Apply.
  4. Click Export.
  5. On the page that opens, configure the log export settings.
    Table-1 Log export configuration items
    Item
    Set password
    Enter a password for encrypting the log files. This password is required when you view or import the exported log files.
    Logs per file
    Set the maximum number of log entries in each log file.
    • If the number of log entries to be exported is smaller than or equal to the specified number, the device exports all log entries to one file.
    • If the number of log entries to be exported is greater than the specified number, the device exports the log entries to multiple files.
  6. Click Export to export the log files to your local PC.
