Security policies
This help contains the following topics:
Introduction
The security policy is a control strategy that forwards and conducts Deep Packet Inspection (DPI) based on the attributes of the packets. It uses various filtering criteria (such as source/destination security zones) to precisely match the packet attributes and processes the matched packets according to specified actions. The feature is widely applied in scenarios such as enterprise networks and data centers, providing comprehensive protection for network security.
Figure-1 Security policy operating mechanism
Security policy name
You can configure multiple security policies, each of which must be uniquely identified by its name and type.
Security policy filtering criteria
The filtering criteria include the following types: source security zone, destination security zone, source IP address and source MAC address, destination IP address, source microsegment, destination microsegment, Internet service, user, application, terminal, service, and time range. Support for specific filtering criteria depends on the device model.
A packet is considered matched if it matches all the criterion types in a policy. Each criterion type includes one or more criteria, and a packet matches a criterion type if it matches any criterion of the type.
If a packet does not match any policy, the system discards the packet. If no filtering criterion is specified for a security policy, the policy can match any packets.
Security policy matching order
The device matches packets against security policies in the order the policies were created. Follow the depth-first order during policy creation to create policies with stricter match criteria first.
Security policies on the Security Policies page are displayed in the policy creation order. Policies created first come first in the list. You can move the policies to change the policy matching order.
Security policy group
Security policy grouping allows users to enable, disable, delete, and move security policies in the same security policy group in batches. You can specify a security policy group for each security policy or specify a range of security policies for each security policy group.
A security policy takes effect only when both the security policy and its security policy group are enabled.
Policy auto deployment
This feature enables the system to learn service traffic transmitted through the device and automatically generate security policies to permit valid service traffic. This feature is suitable for users who deploy the device for the first time and are unfamiliar with the network traffic or the security policy feature.
Import and export
This feature allows the fast migration of security policy configurations.
The exported file supports .cfg and .csv formats.
When importing a file, follow these restrictions and guidelines:
Move a security policy
This feature allows you to adjust orders of security policies for changing the policy match priority or move a security policy to another security policy group.
Security policy deployment from SMP
The Security Management Platform (SMP) can deploy security policies to managed devices. On the Security Policies page, policies deployed from SMP are orange or green shaded. The packet matching priorities of the orange-shaded policies, locally created policies, and green-shaded policies are in descending order.
Logging configuration for the default policy
Users can handle service traffic by configuring security policies and generate logs by enabling logging function. Additionally, when service traffic is not processed through security policies, logs can be generated by configuring default policy logging. By simultaneously enabling these two functions, it ensures that all service traffic passing through the device will generate corresponding logs.
Flow logging
Flow logging logs flow start, flow end, and flow denial events.
When the security policy action is set to allow, it supports recording flow start and end logs. When the action is set to deny, it supports recording flow denial logs.
Flow logs cover most content from security policy logs. To avoid unnecessary duplicate logs and the extra data processing burden, enable only flow logging as a best practice.
vSystem support information
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Restrictions and guidelines: Security policies
Restrictions and guidelines: Security policy groups
Restrictions and guidelines: Import and export
Restrictions and guidelines: Security policy deployment from SMP
Configure security policies
Configure a security policy as shown in Figure-2.
Figure-2 Security policy configuration procedure
Before configuring a security policy, complete the following tasks:
Configure auto deployment of security policies
When you first deploy a device and lack sufficient understanding of network traffic or security policy functions, you can utilize the automatic deployment feature for security policies to complete the configuration automatically. This feature first learns the service traffic passing through the device. Once the learning process is complete, it automatically generates appropriate security policies based on the attributes of the traffic, allowing legitimate service traffic to pass through.
To configure auto deployment of security policies:
  1. Select Policies > Security Policies.
  2. On the Security Policies page, click Auto deployment.
  3. Click Start learning to configure automatic deployment parameters.
  4. Configure automatic deployment parameters as shown in the following table:
    Table-1 Automatic deployment parameters
    Item
    Learning period
    Time during which the device learns about network traffic.
    Internet security zone
    This field is optional.
    Security zone to which the device interface connecting to the external network belongs.
    Server security zone
    Security zone to which the device interface connecting to the internal network belongs.
  5. (Optional.) Click the slide button for advanced settings and configure advanced settings.
    To streamline the configuration of security policies, the device can intelligently aggregate the policies after learning the service traffic passing through it by using the mask length/prefix length set for automatic aggregation.
    Table-2 Automatic deployment advanced parameters
    Item
    Auto aggregated mask length
    Mask length based on which the device aggregates source or destination IPv4 addresses.
    Auto aggregated prefix length
    Prefix length based on which the device aggregates source or destination IPv6 addresses.
  6. Click OK to complete parameter configuration for automatic deployment.
  7. Click Start learning. The device will start learning the traffic packets. During this time, allow the device to forward all legitimate service traffic packets as much as possible.
  8. After the learning process is complete, select the learning records and click Generate policy to generate security policies.
Create a security policy
To block or allow specific traffic, set filtering criteria in a security policy to define the processing scope and specify the corresponding actions.
To create a security policy:
  2. Click Create and then select Create a policy.
  3. Configure basic security policy parameters.
    Table-3 Basic security policy configuration
    Item
    Name
    Enter a name for the security policy. Security policies of the same type cannot have the same name. The system automatically names security policies by default. To manually name a policy, edit the name directly.
    Specify the security policy type. Options include:
    • IPv4.
    • IPv6.
  4. Configure filtering criteria.
    By setting filtering criteria, you can limit the scope of packets processed by the security policy. If no filter criteria are set, the security policy processes all packets passing through the device.
    Table-4 Security policy configuration items
    Item
    Source zone
    Indicates that the security policy only processes packets from a specific security zone. For example, to allow internal network users from the Trust security zone to access internal servers in the DMZ zone, specify the source security zone as Trust and the destination security zone as DMZ.
    Destination zone
    Indicates that the security policy only processes packets destined to a specific security zone. For example, to allow internal network users from the Trust security zone to access the local device, specify the source security zone as Trust and the destination security zone as Local.
    Source address
    Specify source address object groups, source IP/MAC addresses, source locations, or source microsegments as filtering criteria for the security policy. For example, to prevent internal network addresses from accessing the external network, set the internal network addresses as the source addresses and block the packets matching those addresses.
    Only IPv4 security policies supporting specifying source MAC address object groups as filtering criteria.
    Matching any one of the source location, source region group, source IP address, or source MAC address is considered a successful match.
    User
    Indicates that the security policy only processes packets for specific users. For example, to prevent specific users from accessing internal resources, set those specific users as filtering criteria.
    A match is considered successful if either a single user or a user group is matched.
    Destination address
    Specify destination address object groups, destination IP addresses, destination locations, or destination microsegments as filtering criteria for the security policy. For example, to allow external network users to access specific internal resources, set the internal network addresses as the destination addresses and permit the packets matching those addresses.
    Matching any one of the destination location, destination location group, or destination IP address is considered a successful match.
    Internet service
    Specify an Internet service as a filtering condition. Internet services do not support user customization and cannot be configured at the same time with destination addresses or services.
    Support for this configuration depends on the device model.
    Time range
    Specify the time range during which the security policy takes effect.
    For example, to allow users to access internal servers during working hours, configure the time period to be the working hours and allow packets that match this time period.
    Service
    Indicates that the security policy only processes packets for specific service object groups and protocol/port numbers.
    Application
    Indicates that security policies only process packets for specific applications or application groups. For example, to prevent internal network users from accessing certain applications, specify these applications as the filtering criteria and block packets matching them.
    A match is considered successful if either an application or an application group is matched.
    URL category
    Indicates that the security policy only processes packets for specific URL categories. For example, to prevent internal network users from accessing certain URL categories, specify these URL categories as the filtering criteria and block packets matching them.
    Terminal
    Indicates that the security policy only processes packets for specific terminals or terminal groups. For example, to allow only traffic from certain terminals to pass, specify these terminals as the filtering criteria and permit packets matching them.
    A match with either a terminal or a terminal group is considered successful.
    Ingress VRF
    Indicates that the security policy only processes packets for specific incoming interface VPN instances. For example, to block traffic from certain incoming interface VRFs in the network, specify these interface VRFs as the filtering criteria and block packets matching them.
    Selecting Any VRF means that the security policy will process packets from all incoming interface VPN instances.
    Configure terminal and VRF in the Other field.
  5. Specify the security policy action. To block packets matching the policy, specify the action as Deny. To permit packets matching the policy, specify the action as Permit.
  6. Enable the security policy for the configuration to take effect.
  7. (Optional.) Configure security policy extended parameters.
    Table-5 Configuring security policy extended parameters
    Item
    Policy group
    Configure the policy group to which the newly created policy belongs. To manage security policies in bulk through a policy group, you can add the policy to a specified policy group for unified management.
    Configure a description for the security policy.
    Logging
    Enable logging for matched packets.
    Flow logging-Flow start logs
    With this feature enabled, the device generates and sends flow logs when a session table is created or when a matching security policy changes.
    Flow start logs are recorded only when the security policy action is set to Permit.
    Flow logging-Flow end logs
    With this feature enabled, the device generates and sends flow logs upon deleting a session table.
    If this feature is not configured, flow log output is controlled by the global flow log output feature (which must be enabled in System > Log Settings > Log Management). If the global feature is enabled, logs are sent when a session table is deleted. If the global feature is not enabled, no logs are sent.
    Flow end logs are recorded only when the security policy action is set to Permit.
    Flow logging-Flow denial logs
    With this feature enabled, the device generates and sends flow logs when traffic is blocked by a security policy.
    Flow denial logs are recorded only when the security policy action is set to Deny.
    Match counting
    Enable statistics collection for matched packets and specify the statistics collection period, Permanent or Custom.
    Session aging
    Session aging time is used to promptly clear session entries that have been inactive for a prolonged period. When a session reaches the specified aging time, the device will delete the session entry to conserve system resources and maintain the efficient operation and stability of the network device.
    If the session aging time is not configured in the security policy, the session will age out based on the aging time configured in the session management module.
    Persistent session aging
    Set the aging time for persistent sessions created for packets matching the security policy.
    If the aging time is not configured, stable sessions use the aging time configured on the System > Session Aging Time Set > Protocol Session Aging Set page.
    Persistent session aging time is used to handle situations in certain special services (such as FTP file downloads or database queries) where the interval between two consecutive packets is very long. By setting an extended aging time, it ensures that these session details are not cleared prematurely, thereby ensuring the normal operation of the services while avoiding other sessions, which do not require such long aging times, from occupying system resources.
    If the persistent connection aging time is not configured in the security policy, the persistent connection session will age out based on the persistent connection aging time configured in the session management module.
    Redundancy analysis
    Select whether to access the Redundancy Analysis page after the policy creation.
    Policy redundancy analysis helps identify redundant policies by analyzing the filtering criteria in security policies, thereby streamlining the policies. After you enable this function, newly created security policies can be added to the analysis list on the policy redundancy analysis page, where the device will perform redundancy analysis on the security policies in the list.
    Learning
    Select whether to enable policy learning for the system to analyze packet matching and streamline policies.
    When the learning feature is enabled, the device will learn and record the packets that match the security policies. Administrators can analyze the learning results to develop more refined security policies. The learning records can be viewed on the Policy > Security Policy > Broad Policy Analysis page.
  8. Click Apply. You can view the created policy on the Security Policies page.
Configure DPI for security policies
To conduct DPI on specific traffic, configure filtering criteria to limit the scope of the security policy and reference a security configuration file for appropriate processing. For instance, to detect and defend against application-layer attacks between specific security zones, specify the source and destination zones as the filtering criteria in the security policy, and specify an intrusion prevention configuration file.
To configure DPI for security policies:
  1. Create a security policy and configure the basic parameters and filtering criteria. For more information, see "Create a security policy."
  2. Specify the action as Permit and select the security configuration file in the content security field.
    By referencing specific configuration files, corresponding service processes can be handled. The security policy supports referencing multiple service configuration files simultaneously for detection, but each service only supports referencing one configuration file.
    Table-6 Configuration file content
    Item
    WAF profile
    By referencing this configuration file, Web application protection can be applied to inspect traffic that matches the security policy.
    The Web application protection service can defend against Web attacks, block illegal requests in real-time, and effectively protect the Web server.
    IPS profile
    By referencing this configuration file, intrusion prevention service detection can be performed on traffic that matches the security policy.
    Intrusion prevention services can detect intrusion activities in real-time, such as trojans and worms, and block them through certain response actions, thereby protecting enterprise information systems and networks from attacks.
    Data filtering profile
    By referencing this configuration file, data filtering service detection can be performed on traffic that matches the security policy.
    The data filtering service can filter the content carried in application layer protocol packets to prevent the leakage of enterprise confidential information and block the transmission of illegal and sensitive information.
    File filtering profile
    By referencing this configuration file, file filtering service detection can be applied to traffic that matches the security policy.
    The file filtering service can filter files transmitted by devices based on file type, allowing or blocking the transfer of specific types of files in bulk.
    Anti-virus profile
    By referencing this configuration file, antivirus service detection can be carried out on traffic that matches the security policy.
    The antivirus service can identify and handle virus-infected packets by inspecting the application layer information of the packets, preventing the spread of viruses across the network and effectively safeguarding network security.
    URL filtering profile
    By referencing this configuration file, URL filtering service detection can be applied to traffic that matches the security policy.
    URL filtering can control access to users' URL requests, allowing or blocking access to certain web resources, thereby regulating online behavior.
    APT defense profile
    By referencing this configuration file, APT defense service detection can be applied to traffic that matches the security policy.
    The device interacts with a sandbox to send traffic for isolated analysis and, based on the detection results returned by the sandbox, performs actions such as blocking the traffic to prevent APT attacks on the internal network. The APT defense configuration file can specify the conditions that files must meet to be sent for sandbox detection.
  3. Enable the security policy for the configuration to take effect.
  4. Click OK. You can view the security policy on the Security Policies page.
Manage security policy groups
Perform this task to enable, disable, delete, and move security policies in bulk.
Create a security policy group
  2. Click Create and then select Create a policy group.
  3. Create the security policy group.
    Table-7 Security policy group configuration items
    Item
    Name
    Enter a name for the security policy group, unique identifier of the group.
    Configure a description for the security policy group.
    The security policy types within the same security policy group must be the same. For example, you can choose to add only IPv4 type security policies to the security policy group.
    Start policy
    Specify the name of the start policy of a policy range in which all the security policies will be add to the group.
    End policy
    Specify the name of the end policy of a policy range in which all the security policies will be added to the group.
    Make sure the end policy is listed below the start policy and policies in the specified policy range do not belong to any other policy groups.
  4. Click Apply.
Manage security policies in bulk
To enable, disable, move, or delete security policies in a security policy group, click the Enable/Disable, Move, or Delete icon after the name of the target policy group.
