This help contains the following topics:
Network Address Translation (NAT) translates an IP address in the IP packet header to another IP address. Typically, NAT is configured on gateways to enable private hosts to access external networks and external hosts to access private network resources such as a Web server.
Policy-based NAT contains a set of NAT rules to identify and translate matching packets. The packet match criteria include source security zone, destination security zone, source IP address, destination IP address, and service.
Policy-based NAT is applicable to the scenario where the external interface is not fixed. You do not need to change relevant configurations if the external interface changes, which reduces maintenance costs.
Policy-based NAT supports the following types of rules, which are applicable to different scenarios:
NAT44 rule—Used for NAT translation between IPv4 networks.
NAT64 rule—Used for NAT translation between IPv4 networks and IPv6 networks.
NAT66 rule—Used for NAT translation between IPv6 networks.
Policy-based NAT supports the following translation modes:
Source address translation—Translates the source IP address and source port of packets. Source address translation can hide the IP addresses of internal hosts to external devices. The NO-PAT and PAT modes are supported. For more information about NO-PAT and PAT, see the help for NAT.
Destination address translation—Translates the destination IP address and destination port of packets. Destination address translation is commonly used for internal servers to access external users. This translation mode supports many-to-one NAT and many-to-many NAT modes.
Many-to-one NAT—Translates different destination IP addresses and destination ports of the matching packets to the same IP address and port. You only need to configure only one IP address and one port for destination address translation.
Many-to-many NAT—Translates destination IP addresses and destination ports based on the numbers of destination IP addresses and services (ports) in the original packets and the numbers of destination IP addresses and destination ports after destination address translation. Make sure the number of public addresses multiplied by the number of public ports is equal to the number of private addresses multiplied by the number of private ports. In this translation mode, you can configure multiple destination IP addresses and one destination port or one destination IP address and multiple destination ports.
Table-1 describes the address translation configuration available for many-to-many NAT in different scenarios.
Table-1 Many-to-many NAT configuration guide
Application scenario | Item | |
Public network (destination IP addresses and services in the original packets) | Private network (IP addresses and ports after destination address translation) | |
External users can use one public address to access internal servers | One public address | One private address |
External users can use one public address and one public port to access internal servers | One public address and one public port number | One private address and one private port number |
External users can use one public address and multiple different public port numbers to access internal servers | One public address and N public port numbers | N private addresses and one private port number |
One public address and N public port numbers | One private address and N private port numbers | |
External users can use multiple different public addresses to access internal servers | N public addresses | N private addresses |
External users can use multiple different public addresses and one public port number to access internal servers | N public addresses and one public port number | One private address and N private port numbers |
N public addresses and one public port number | N private addresses and one private port number |
Source and destination address translation—Translates the source IP address, source port, destination IP address, and destination port of packets. Source address translation supports NO-PAT and PAT modes. Destination address translation supports many-to-one NAT and many-to-many NAT modes.
If only one NAT device is deployed in the internal network, internal users cannot access the external network when the NAT device fails. To avoid this situation, configure a two-node hot backup system to provide redundant NAT services. The two devices in the system synchronize session entries, session relation entries, NAT port block entries, and NAT configurations through the hot backup channel. When one device fails, the other device takes over. For more information about configuring a hot backup system, see "Hot backup".
Typically, the master device in the VRRP group processes NAT services in the hot backup system. On an active/standby hot backup system, some translation rules for static, source, or destination address translation issue the translated public IP addresses or the public IP addresses of internal servers to the address management module. Then, both the active and standby devices advertise the mappings between the public IP addresses and MAC addresses of their own physical interfaces to all nodes in the same LAN or local link. As a result, the upstream Layer 3 device directly connected to the hot backup system might incorrectly send downlink packets to a VRRP backup device, causing service anomalies. This issue might also occur on a dual-active hot backup system.
To avoid such an issue, bind address translation methods to the VRRP group in use. This ensures that only the VRRP master device responds to the ARP requests or NS requests for the translated public IP addresses or the public IP addresses of internal servers. The MAC addresses in the responses are the virtual MAC address of the VRRP group.
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Policy NAT has higher priority than interface NAT for the traffic that matches both of them.
By default, the NAT rules in policy-based NAT are sorted in descending order of their configuration order. You can rearrange NAT rules to change their priorities. A rule has a higher priority than rules listed after it.
If you select Automatically generate security policy when creating or copying a NAT rule, the device generates a security policy based on the original packet information you configured. If you modify the original packet information, you must click Refresh to reflect the modification in the generated security policy.
A NAT address group cannot be used by both PAT and NO-PAT modes.
If a packet matches both a policy-based NAT rule and an interface NAT rule, the packet is translated as follows:
For source and destination address translation method:
If the translation methods of the policy-based NAT rule and the interface NAT rule are the same, the device translates the packet by using the policy-based NAT rule.
If the translation methods of the policy-based NAT rule and the interface NAT rule are different, the device translates the packet by using the two rules.
If the translation method of the policy-based NAT rule is bidirectional, the device translates the packet by using the policy-based NAT rule, and the interface NAT rule does not take effect.
When you add address ranges to a NAT address group, make sure address ranges do not overlap.
The address object group used by a NAT rule cannot contain a host name.
Referencing an address object group that contains an object group or wildcard mask might affect configuration performance and traffic matching performance. As a best practice to ensure network stability and smoothness, do not use an object group or wildcard mask to add objects.
NAT can be performed in the inbound or outbound direction.
Inbound NAT—Performs address translation for packets received in a security zone, as shown in Figure-1.
Outbound NAT—Performs address translation for packets sent out of a security zone, as shown in Figure-2.
Figure-1 NAT on an inbound security zone
Figure-2 NAT on an outbound security zone
Policy-based NAT supports packet match criteria including security zone, address object group, and service object group. Policy-based NAT supports source address translation, destination address translation, and source and destination address translation. Figure-3 shows the configuration flowchart.
Figure-3 Policy-based NAT configuration flowchart
(Optional.) Create a security zone. (Details not shown.)
(Optional.) Create an address object group. (Details not shown.)
(Optional.) Create a service object group. (Details not shown.)
(Optional.) Create a NAT address group.
Click the Objects tab.
In the navigation pane, select Object Groups > NAT Address Groups.
Click Create.
Click OK.
Create a policy-based NAT44 rule.
Click the Policies tab.
In the navigation pane, select Policy-based NAT.
Click Create, and then select an option as required.
Table-2 Translation mode description
Translation mode | Description |
Create SNAT Rule | Translates the source address information of packets. |
Create DNAT Rule | Translates the destination address information of packets. |
Create SNAT+DNAT Rule | Translates both the source and destination address information of packets. |
Click the NAT44 tab.
Table-3 Configuration items for policy-based NAT44 rules
Item | Description | ||
When IP addresses match the following criteria | Source zone | Select source security zones for packet match. | |
Destination zone | Select destination security zones for packet match. | ||
Source IP | Select a source IP address, IP subnet, or address object group for packet match. | ||
Destination IP | Select a destination IP address, IP subnet, or address object group for packet match. If the translation mode is destination address translation or source and destination address translation, this field must be specified. | ||
Service | Select a service object group for packet match. | ||
Translate IP addresses to | Translation | Select a source address translation method:
Address | Select a NAT address type for source address translation:
Source IP after NAT | Select a NAT address for source address translation. | ||
IPv4 Source VRRP group | After you configure this feature, the master device in the IPv4 source VRRP group uses the virtual IP address and virtual MAC address to reply packets. On a stateful failover network, you must configure this feature. Support for this feature varies by device. | ||
Allow reverse NAT | Enable reverse address translation. Reverse address translation uses existing NO-PAT entries to translate the destination address for connections actively initiated from the external network to the internal network. This option is available only when the translation mode is set to Dynamic IP. | ||
Port translation | If you enable port translation, the device uses the PAT method to translate the source IP addresses and source ports of packets. If you disable port translation, the device uses the NO-PAT method to translate only the source IP addresses of packets. | ||
User original port preferentially | Preferentially use the original port for PAT. When the original port has been allocated, another port is used. This option is available only when the translation mode is set to Dynamic IP or Easy IP. | ||
Translate IP addresses to | Translation method | Select a destination address translation method:
Destination IP after NAT | Set the destination IP address after translation. | ||
Port after NAT | Set the destination port after translation. | ||
IPv4 Destination VRRP group | After you configure this feature, the master device in the IPv4 destination VRRP group uses the virtual IP address and virtual MAC address to reply packets. On a stateful failover network, you must configure this feature. Support for this feature varies by device. | ||
General settings | Name | Name of the NAT44 rule, which supports Chinese characters. | |
Rule status | Whether to enable the NAT44 rule. | ||
Auto generate security policy | After you enable this feature, the device generates a security policy based on the original packet information configured above. | ||
Advanced settings | Description | Remarks for the NAT44 rule. | |
VRF before NAT | VPN instance to which packets belong before address translation. | ||
VRF after NAT | VPN instance to which packets belong after address translation. | ||
Counting | Enable the counting of times that the NAT44 rule is matched. |
Click Apply.
Create a policy-based NAT66 rule.
Table-4 Translation mode description
Click the NAT66 tab.
Table-5 Configuration items for policy-based NAT66 rules
Translate IP addresses to | Translate | Select a source address translation method:
IPv6 Source VRRP group | After you configure this feature, the master device in the IPv6 source VRRP group uses the virtual IP address and virtual MAC address to reply packets. On a stateful failover network, you must configure this feature. Support for this feature varies by device. | ||
IPv6 prefix | Configure the IPv6 address prefix for the prefix translation method. This option is available only when the prefix translation method is NPTV6. | ||
Prefix length | Configure the IPv6 prefix length. This option is available only when the prefix translation method is NPTV6. | ||
IPv6 prefix | Configure the IPv6 address prefix for the prefix translation method. This option is available only when the translation method is NPTV6. | ||
Prefix length | Configure the IPv6 prefix length. This option is available only when the translation method is NPTV6. | ||
General settings | Name | Name of the NAT66 rule, which supports Chinese characters. | |
Rule status | Whether to enable the NAT66 rule. | ||
Advanced settings | Description | Remarks for the NAT66 rule. | |
Counting | Enable the counting of times that the NAT66 rule is matched. |
Click Apply.
Create a policy-based NAT64 rule.
Click Create, and then select Create SNAT+DNAT Rule.
Click the NAT64 tab.
Table-6 Configuration items for policy-based NAT64 rules
Translation method | V4toV6 | Translates the source IP address and destination IP address of packets when an IPv4 host first initiates a connection to the IPv6 network. | |
V6toV4 | Translates the source IP address and destination IP address of packets when an IPv6 host first initiates a connection to the IPv4 network. | ||
Destination IP | Select a destination IP address, IP subnet, or address object group for packet match. | ||
Source address translation | Translation method | Select a source address translation method:
Source IP after NAT | Select a NAT address for source address translation. This option is available only when the translation method is Dynamic IP or Static IP. | ||
Prefix translation | Select a prefix translation type:
This option is available only when the translation method is Prefix translation. | ||
IPv6 prefix | Configure the IPv6 address prefix for the prefix translation method. This option is available only when the prefix translation type is General prefix or NAT64 prefix. | ||
Prefix length | Configure the IPv6 prefix length. This option is available only when the prefix translation type is General prefix or NAT64 prefix. | ||
Destination address translation | Translation method | Select a destination address translation method:
IPv6 prefix | Configure the IPv6 address prefix for the prefix translation method. This option is available only when the prefix translation type is General prefix or IVI prefix. | ||
Prefix length | Configure the IPv6 prefix length. This option is available only when the prefix translation type is General prefix. | ||
IPv6 Destination VRRP group | After you configure this feature, the master device in the IPv6 destination VRRP group uses the virtual IP address and virtual MAC address to reply packets. On a stateful failover network, you must configure this feature. Support for this feature varies by device. | ||
Port after NAT | Set the destination port after translation. This option is available only when the translation method is NAT server mapping. | ||
General settings | Name | Name of the NAT64 rule, which supports Chinese characters. | |
Rule status | Whether to enable the NAT64 rule. | ||
Advanced settings | Description | Remarks for the NAT64 rule. | |
Counting | Enable the counting of times that the NAT64 rule is matched. |
Click Apply.
Click Export to CSV.
Table-7 Configuration items for exporting configuration to a CSV file
Type | Export all | Export all policy-based NAT rules. |
Export specified rules | Export specified policy-based NAT rules. | |
Start name | Export policy-based NAT rules starting from the rule with the specified name. If you do not specify the start name, the system exports the specified number of policy-based NAT rules starting from the first one. This field is only available when you select Export specified rules. | |
Export count | Export the specified number of policy-based rules. If you do not specify the export count, the system exports all subsequent policy-based NAT rules starting from the rule with the specified name. This field is only available when you select Export specified rules. |
Click Export.
