This help contains the following topics:
NAT logs record NAT44 session information, including translation information and access information.
To display NAT logs on the Web interface, enable log collection for the NAT | NAT log service on the System > Log Settings > Storage Space Settings page.
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Only one log operation (import, export, or clear) is allowed at a time.
Only one user can perform a log operation at a time. When you import, export, or clear logs, make sure no one else is performing a log operation.
Click the Monitor tab.
In the navigation pane, select
Click Import.
In the dialog box that opens, click OK.
Select a log file, and enter the password for the log file. The password was set when the file was exported.
Click on a column header, specify the search criteria to display the logs to be exported, and then click Apply.
Click Export.
On the page that opens, configure the log export settings.
Table-1 Log export configuration items
Item | Description |
Set password | Enter a password for encrypting the log files. This password is required when you view or import the exported log files. |
Logs per file | Specify the maximum number of log entries in each file.
Click Export to export the log files to your local PC.
