Virtual server trends
This help contains the following topics:
Introduction
This page displays the virtual server statistics over time.
You can first select one or multiple trends in the Select widgets list, and then specify the virtual server scope and statistics duration in the Statistics conditions section to view the selected trends.
To view virtual server trend statistics, you must first enable Load balancing | Virtual server trend statistics, Load balancing | Virtual server trend statistics(Web cache), Load balancing | Virtual server trend statistics(HTTP information), and Load balancing | Virtual server trend statistics(Server status) on the System > Log Settings > Storage Space Settings page.
Select widgets
Click Select widgets and select one or multiple of the following trends.
Traffic trend
Select Traffic trend to view the traffic trend of the specified virtual servers over time.
Click the Set icon in the upper right corner of the widget to specify a traffic direction. Options are:
New connections trend
Select New connections trend to view the average number of connections established with the specified virtual servers per second.
Concurrent connections trend
Select Concurrent connections trend to view the number of active connections for the specified virtual servers.
Stability trend
Select Stability trend to view the stability trend of the specified virtual server.
This widget displays the stability trend of only one virtual server.
Traffic compression ratio
Select Traffic compression ratio to view the ratio of compressed response traffic to the total response traffic on the specified virtual servers.
HTTP status code
Select HTTP status code to view the status codes in the redirection messages returned by the specified virtual servers.
Set statistics conditions
  1. Click Statistics conditions to set the following conditions as shown in Table-1.
    Table-1 Virtual server statistics conditions
    Item
    Auto refresh
    Enable or disable auto refresh for the trend statistics page.
    After you enable this function, the device will automatically refresh the trend statistics page at the specified refresh intervals.
    Refresh interval
    Specify the interval to automatically refresh the trend statistics page.
    Virtual server scope
    Specify the virtual server scope for collecting trend statistics. Options are:
    • Top 3 virtual servers: Displays trend statistics for only the top 3 virtual servers.
    • Specify virtual servers: Displays trend statistics for the specified virtual servers.
    Duration
    Specify the duration for collecting trend statistics. Options are:
    • Last 10 minutes
    • Last hour
    • Last day
    • Last week
    • Last 30 days
    • Customize: You must set a specific duration.
  2. Click Start to enable the device to collect virtual server statistics based on the specified statistics conditions and display the trends.
vSystem support information
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
