This help contains the following topics:
The administrator can test the load balancing result by specifying the protocol, source IPv4/IPv6 address, source port number, destination IPv4/IPv6 address, and destination port number.
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Select Monitor > Diagnosis Center > Load Balancing Test.
Configure test parameters.
Table-1 Test parameter configuration items
Item | Description |
Slot number | Specify the slot number to be tested. |
IP type | IP address type:
VPN instance | Specify the VPN instance to be tested. |
Destination IPv4 address | Specify the destination IPv4 address to be tested. Typically, specify the IPv4 address of the virtual server. This parameter is available only when you select the IPv4 address type. |
Source IPv4 address | Specify the source IPv4 address to be tested. This parameter is available only when you select the IPv4 address type. |
Destination IPv6 address | Specify the destination IPv6 address to be tested. Typically, specify the IPv6 address of the virtual server. This parameter is available only when you select the IPv6 address type. |
Source IPv6 address | Specify the source IPv6 address to be tested. This parameter is available only when you select the IPv6 address type. |
Protocol layer | Specify the layer of the information that can be identified by load balancing.
Layer 4 protocol | Select a way to identify a protocol:
This parameter is displayed only when you select Layer 4 for Protocol layer. |
Protocol name | Specify the protocol to be tested:
Protocol number | Enter the number of the protocol to be tested. |
Layer 7 protocol | Specify a way to identify an HTTP packet:
This parameter is displayed only when you select Layer 7 for Protocol layer. |
Import HTTP packet | Import the HTTP packet to be tested. The file containing the HTTP packet content must be suffixed with .txt, and cannot be larger than 5000 bytes. |
HTTP request method | Specify an HTTP request method:
URL | Specify a URL for the HTTP packet, case sensitive. A URL can contain letters, digits, hyphens (-), underscores (_), and periods (.). The URL cannot contain consecutive periods and question marks (?). |
HTTP packet header | Specify a space-separated list of up to 10 HTTP packet headers. A header cannot contain question marks (?). |
HTTP packet content | Specify the content of the HTTP packet body. The HTTP packet content cannot contain question marks (?). |
Destination port number | Enter the destination port number to be tested. Support for this parameter depends on the protocol. |
Source port number | Enter the source port number to be tested. Support for this parameter depends on the protocol. |
Click Start testing. For more information about the test result, see Table-2.
Field | Description |
Slot number | Slot number of the device. The displayed value for this field depends on your configuration. |
Matched virtual server name | Name of the matching virtual server. The displayed value for this field depends on your configuration. |
No virtual server is matched | N/A |
Matched class name | Name of the matching class. The displayed value for this field depends on your configuration. |
Default action is matched | N/A |
Matched server farm name | Name of the matching default server farm. The displayed value for this field depends on your configuration. |
Matched link group name | Name of the matching default link group. The displayed value for this field depends on your configuration. |
Forwarding mode | Forwarding mode:
Selected real server name | Name of the matching real server. The displayed value for this field depends on your configuration. |
Selected link name | Name of the matching link. The displayed value for this field depends on your configuration. |
Scheduling algorithm used to select a real server | Scheduling algorithm used to select the real server:
Scheduling algorithm used to select a link | Scheduling algorithm used to select the link:
Packet drop reason | Packet drop reason:
