This help contains the following topics:
IS-IS is a link-state interior gateway protocol (IGP) used within an AS. It uses the SPF algorithm for route calculation.
A network entity title (NET) identifies the network layer information of an IS. It does not include transport layer information. A NET is a special NSAP address with the SEL being 0. The length of a NET is in the range of 8 to 20 bytes, same as a NSAP address.
A NET includes the following parts:
Area ID—The length of an area ID is 1 to 13 bytes.
System ID—A system ID uniquely identifies a host or router in the area and it length is fixed at 6 bytes.
SEL—The SEL value is 0 and the length is fixed at one byte.
For example, for a NET ab.cdef.1234.5678.9abc.00, the area ID is ab.cdef, the system ID is 1234.5678.9abc, and the SEL is 00.
Typically, a router only needs one NET, but it can have a maximum of three NETs for smooth area merging and partitioning. When you configure multiple NETs, make sure they have the same system ID.
IS-IS has a 2-level hierarchy to support large-scale networks. A large-scale routing domain is divided into multiple areas. Typically, a Level-1 router is deployed within an area. A Level-2 router is deployed between areas. A Level-1-2 router is deployed between Level-1 and Level-2 routers.
Level-1 router
A Level-1 router establishes neighbor relationships with Level-1 and Level-1-2 routers in the same area. It maintains an LSDB comprising intra-area routing information. A Level-1 router forwards packets destined for external areas to the nearest Level-1-2 router.
Level-1 routers in different areas cannot establish neighbor relationships.
Level-2 router
A Level-2 router establishes neighbor relationships with Level-2 and Level-1-2 routers in the same area or in different areas. It maintains a Level-2 LSDB containing inter-area routing information. All the Level-2 and Level-1-2 routers must be contiguous to form the backbone of the IS-IS routing domain.
Level-2 routers can establish neighbor relationships even if they are in different areas.
Level-1-2 router
A router with both Level-1 and Level-2 router functions is a Level-1-2 router. It can establish Level-1 neighbor relationships with Level-1 and Level-1-2 routers in the same area. It can establish Level-2 neighbor relationships with Level-2 and Level-1-2 routers in different areas. A Level-1 router can reach other areas only through a Level-1-2 router. The Level-1-2 router maintains two LSDBs, a Level-1 LSDB for intra-area routing and a Level-2 LSDB for inter-area routing.
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
In the navigation pane, select Routing > IS-IS.
Click Create.
Configure the IS-IS instance parameters.
Table-1 IS-IS instance parameters
Click OK.
The IS-IS instance will be displayed on the IS-IS instance page.
Click the Network tab.
Click the Interface List tab.
Configure the following interface parameters as needed.
Table-2 IS-IS interface parameters
Click Apply.
