IOT Security manage Logs
This help contains the following topics:
Introduction
IOT security management is a technology that provides intelligent inspection and security management of IOT devices. It mainly provides the following functions: standard format check, device access control, sensitive signal control, and standard flow control.
IOT security manage logs record information about potential security risks detected on IOT devices, allowing administrators to adjust policies in time to prevent information leakage and network attacks.
For the logs to be displayed correctly, you must enable logging for standard format check, device access control, sensitive signal control, and standard flow control on the corresponding pages. When specific packet actions are performed, the device sends the generated logs to the Web interface for displaying.
vSystem support information
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
License requirements
Sensitive signal control identifies applications based on the APR library. After the license expires, the existing APR library is still available, but the library cannot be updated. For more information about licensing, see the license management help.
Configuration guidelines
Import logs
  1. Click the Monitor tab.
  2. In the navigation pane, select Security Logs > IOT Security manage Logs.
  3. Click Import.
  4. In the dialog box that opens, click OK.
  5. Select a log file, and enter the password for the log file.
Export logs
  3. Click the Filter icon in the log list.
  4. On the page that opens, specify the search criteria to display the logs to be exported, and then click Apply.
  5. Click Export.
  6. On the page that opens, configure the log export settings.
    Table-1 Log export configuration items
    Item
    Set password
    Enter a password for encrypting the log files. This password is required when you view or import the exported log files.
    Logs per file
    Specify the maximum number of logs allowed in a single log file.
    • If the number of logs to be exported is smaller than or equal to the specified number, the device exports the logs to one file.
    • If the number of logs to be exported is greater than the specified number, the device exports the logs to multiple files.
  7. Click Export to export the log files to your PC.
