DHCP
This help contains the following topics:
Introduction
The Dynamic Host Configuration Protocol (DHCP) provides a framework to assign network configuration information to network devices.
DHCP uses the client-server model. A DHCP network typically contains a DHCP server and multiple DHCP clients. If DHCP clients and the DHCP server are on different subnets, the DHCP clients can obtain configuration parameters from the DHCP server through a DHCP relay agent.
DHCP server
Use a DHCP server to assign IP addresses for the following networks:
A DHCP server stores the following information in an address pool: IP addresses, lease duration, network information, domain name suffix, DNS server addresses, WINS server addresses, NetBIOS node types, and DHCP option information. The DHCP server selects an IP address and configuration parameters from the address pool and allocates them to a requesting DHCP client.
Before assigning the IP address to the client, the DHCP server performs IP address conflict detection.
DHCP address pool
The following address assignment mechanisms are available:
You can specify the lease duration for statically and dynamically allocated addresses.
The DHCP server observes the following principles to select an address pool for a client:
  1. If there is an address pool where an IP address is statically bound to the MAC address or ID of the client, the DHCP server selects this address pool and assigns the statically bound IP address and other configuration parameters to the client.
  2. If the above condition is not met, the DHCP server selects an address pool depending on the client location.
    • Client on the same subnet as the server—The DHCP server compares the IP address of the receiving interface with subnets of all address pools, and selects the address pool with the longest-matching subnet.
    • Client on a different subnet than the server—The DHCP server compares the IP address in the giaddr field of the DHCP request with subnets of all address pools, and selects the address pool with the longest-matching primary subnet.
IP address allocation sequence
The DHCP server selects an IP address for a client in the following sequence:
  1. IP address statically bound to the client's MAC address or ID.
  2. IP address that was ever assigned to the client.
  3. IP address designated by the Option 50 field in the DHCP-DISCOVER message sent by the client.
    Option 50 is the Requested IP Address option. The client uses this option to specify the wanted IP address in a DHCP-DISCOVER message. The content of Option 50 is user defined.
  4. First assignable IP address found based on the dynamic allocation rule.
  5. IP address that was a conflict or passed its lease duration. If no IP address is assignable, the server does not respond.
DHCP options
DHCP uses the options field to carry information for dynamic address allocation and provide additional configuration information for clients.
Use the DHCP options feature for the following purposes:
Table-1 lists common DHCP options.
Table-1 Common DHCP options
Option number
Option name
Recommended option padding type
3
Router Option
IP address
6
Domain Name Server Option
IP address
15
Domain Name
ASCII string
43
Vendor Specific Information
Hexadecimal string
44
NetBIOS over TCP/IP Name Server Option
IP address
46
NetBIOS over TCP/IP Node Type Option
Hexadecimal string
66
TFTP server name
ASCII string
67
Bootfile name
ASCII string
Before assigning an IP address, the DHCP server pings that IP address.
vSystem support information
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Configure DHCP
Configure the DHCP server
To implement the DHCP server function, perform the following tasks:
Configure address allocation settings
  1. Navigate to the Network > DHCP > DHCP Service page.
  2. Enable the DHCP service.
  3. To enable the DHCP server mode on an interface, click the edit icon in the DHCP service column for the interface, and then select DHCP server.
  4. Navigate to the Network > DHCP > DHCP Address Pools page.
  5. Choose one of the following options as needed:
    • To edit the address allocation settings of an existing address pool, select the address pool on the box above the Address Allocation tab.
    • To create an address pool and configure its address allocation settings, click Create address pool, enter an address pool name, and then click OK.
  6. Click the Address Allocation tab, and then configure the following address allocation settings as needed:
    Table-2 Address allocation configuration items
    Item
    Subnet for Dynamic Allocation
    Specify a subnet for dynamic address allocation.
    Address Range for Dynamic Allocation
    Specify an address range for dynamic address allocation. The specified address range must belong to the specified subnet.
    Excluded Address Range
    Exclude an address range from dynamic address allocation.
    Static Binding List
    Bind a client ID or hardware address to an IP address.
    To create a static IP binding, perform the following task:
    1. Click Create, and then configure the following parameters:
      • IP address—Specify the IP address of the static binding.
      • Mask—Specify the mask length of the IP address.
      • Type—Specify a client type. Options include Ethernet, Token ring, and Client ID.
      • Hardware address—Specify the client hardware address of the static binding, a string of 4 to 39 characters. The string contains only hexadecimal numbers and hyphens (-), in the format of H-H-H…. The last H can represent two or four hexadecimal numbers while the other Hs must be all four hexadecimal numbers.
      • Client ID—Specify the client ID of the static binding, a string of 4 to 254 characters. The string can contain only hexadecimal numbers and hyphen (-), in the format of H-H-H…. The last H can represent two or four hexadecimal number while the other Hs must be all four hexadecimal numbers.
    2. Click OK. The static binding list will display the static binding after it is created successfully.
  7. Click OK.
Configure address pool options
  1. Navigate to the Network > DHCP > DHCP Address Pools page.
  2. Click the Address Pool Options tab, and then configure the following address pool option settings as needed:
    Table-3 Address pool option configuration items
    Item
    Lease duration
    Specify a limited or unlimited lease duration for dynamic address allocation.
    Domain name suffix
    Specify a domain name suffix for DHCP clients.
    With a domain name suffix assigned, you only need to input part of a domain name on a DHCP client, and the client automatically adds the domain name suffix for name resolution.
    Gateways
    Specify gateways for DHCP clients.
    When a DHCP client attempts to access a server or host on a remote network, it must send packets destined for the remote network to a gateway.
    You can specify a maximum of 64 gateways for a DHCP address pool.
    DNS servers
    Specify Domain Name System (DNS) servers for DHCP clients.
    To access hosts on the Internet through domain names, a DHCP client must contact a DNS server to resolve names.
    WINS servers
    Specify WINS servers for DHCP clients.
    A Microsoft DHCP client using NetBIOS protocol must contact a WINS server for name resolution.
    NetBIOS node type
    Specify the NetBIOS node type for DHCP clients.
    When DHCP clients use NetBIOS for communication, they must create host name-to-IP mappings. The method to obtain host name-to-IP mappings varies by NetBIOS node type as follows:
    • Broadcast—A broadcast node client sends the destination name in a broadcast message. The destination returns its IP address to the client after receiving the message.
    • Peer-to-Peer—A peer-to-peer node client sends the destination name in a unicast message to the WINS server. The WINS server returns the destination IP address.
    • Mixed—A mixed node client broadcasts the destination name. If it does not receive any response, it unicasts the destination name to the WINS server to get the destination IP address.
    • Hybrid—A hybrid node client unicasts the destination name to the WINS server. If it does not receive any response, it broadcasts the destination name to get the destination IP address.
    DHCP options
    Customize DHCP options.
    To create a DHCP option, perform the following task:
      • DHCP options—Specify an option ID.
      • Type—Specify the type of the option content. Options include Hexadecimal string, ASCII string, and IP address.
      • Option content—Specify the content of the DHCP option.
    2. Click OK. The DHCP option list will display the DHCP option after it is created successfully.
  3. Click OK.
  4. To view information about allocated IP addresses, click the Assigned Addresses tab. Available information include IP address, hardware address or client ID, and lease expiration time.
