Bandwidth management
This help contains the following topics:
Introduction
Bandwidth management provides fine-grained control over traffic that flows through the device by using the following information:
Bandwidth management is used in the following scenarios:
Bandwidth management allows you to deploy different traffic policies on the network egress for different traffic types. Bandwidth management improves bandwidth efficiency and guarantees bandwidth for key services when congestion occurs. The emergence of bandwidth management technology effectively prevents bandwidth waste and network performance degradation. It ensures that key services run smoothly while improving network performance and user experience within the enterprise.
Figure-1 Bandwidth allocation
Bandwidth management process
Bandwidth management is implemented through traffic policies. You can configure traffic profiles and traffic policies in a traffic policy. A traffic profile specifies the guaranteed bandwidth and maximum bandwidth. A traffic policy specifies match criteria to match packets and the traffic profile to apply to matching packets.
Figure-2 Bandwidth management process
The bandwidth management process is as follows:
  1. If a packet matches a traffic policy, the interface processes the packet according to the traffic profile (if any) specified for the traffic policy.
    If no traffic profile is specified for the traffic policy, the packet is forwarded without bandwidth management.
  2. The traffic profile processes the packet according to its settings.
  3. The packet is limited by the interface bandwidth of the output interface.
Traffic match criteria
Multiple traffic policies can be configured. In a traffic policy, you can define the match criteria to match packets and specify the traffic profile to apply to matching packets. The device matches traffic policies in their order of appearance on the device. When a traffic policy is matched, the matching process ends and the device applies the traffic profile for the traffic policy to the traffic. If no traffic policy is matched, the device forwards the traffic.
You can configure the following match criteria in a traffic policy:
One match criterion can contain multiple match values. For example, you can configure multiple IP addresses for a source IP address match criterion. A match criterion is matched if any of its match values is matched.
Traffic policies support policy nesting, which allows a traffic policy to have a parent traffic policy. A maximum of four nesting levels are supported. The following rules apply when the device matches a traffic policy with a parent traffic policy:
Traffic profile
A traffic profile defines bandwidth resources that can be used by a traffic type. The interface bandwidth can be allocated among multiple traffic profiles. You can configure the following parameters in a traffic profile:
Table-1 Parameters in a traffic profile
Item
Rate limit mode
You can limit the traffic rate in one of the following ways:
  • Limit the upstream bandwidth and downstream bandwidth separately.
  • Limit the upstream bandwidth and downstream bandwidth as a whole.
Reference mode
A traffic profile can be referenced by multiple traffic policies in one of the following ways:
  • Exclusive—Each rule that uses the profile can reach the bandwidth limits and connection limits specified in the profile.
  • Shared—All rules that use the profile share the bandwidth limits and connection limits specified in the profile.
Total guaranteed bandwidth
Guarantees the total minimum bandwidth for key services when congestion occurs.
Total maximum bandwidth
Controls the total maximum bandwidth for non-key services to prevent them from consuming a large amount of bandwidth.
Bandwidth allocation among IP addresses
Allocates the total maximum bandwidth dynamically and evenly among online IP addresses.
Per-IP or per-user guaranteed bandwidth
Guarantees the minimum bandwidth per IP address or per user to provide for bandwidth management at finer granularity.
Per-IP or per-user maximum bandwidth
Controls the maximum bandwidth allowed per IP address or per user to provide for bandwidth management at finer granularity.
Connection limits
Limits the total connection count, total connection rate, per-user/per-IP connection count, and per-user/per-IP connection rate.
Per-IP traffic quota
Limits the monthly traffic quota per IP address.
After you configure this function, you can view traffic statistics on the Per-IP traffic statistics tab.
Monthly traffic quota
Per-IP monthly traffic quota.
Forwarding priority
When an interface is congested with packets of multiple traffic profiles, packets with higher priority are sent first. Packets with the same priority have the same chance of being forwarded.
DSCP marking
Modifies the DSCP value in packets. Network devices can classify traffic by using DSCP values and provide different treatment for packets according to the modified DSCP values.
TCP MSS
Specifies the TCP maximum segment size.
Bandwidth check
Enables the device to detect the amount of bandwidth consumed by traffic in real time by source IP address.
Static thresholds
Specifies the maximum bandwidth threshold and minimum bandwidth threshold.
When the device detects that the traffic rate exceeds the maximum bandwidth threshold or falls below the minimum bandwidth threshold, it outputs logs to the log host by using the fast log output feature.
Dynamic threshold learning
Enables the device to dynamically learn the bandwidth threshold.
Enable this option if you do not know the traffic rates in the network. The device will derive the maximum and minimum bandwidth thresholds from multiplying the learned bandwidth threshold by the maximum and minimum tolerance values. The derived maximum and minimum bandwidth thresholds have higher priority than the static thresholds.
To view the learning results, access the Policies > Bandwidth Management > Bandwidth Threshold Learning page.
Learning duration
Specifies the learning duration in minutes.
After dynamic threshold learning is enabled, the device learns the traffic rates during the specified duration and calculates an average value as the learned bandwidth threshold. As a best practice to ensure the device can learn the traffic of a whole day, set the learning duration to be longer than 1440 minutes (24 hours). If the learning duration is modified while the device is learning, the device will learn the traffic again based on the new learning duration.
Bandwidth tolerance
Specifies the bandwidth tolerance values.
The device derives the maximum and minimum bandwidth thresholds from multiplying the learned bandwidth threshold by the maximum and minimum bandwidth tolerance values.
If you do not care about the minimum bandwidth threshold, you can specify only the maximum bandwidth tolerance value. If you do not care about the maximum bandwidth threshold, you can specify only the minimum bandwidth tolerance value.
Traffic policy matching acceleration
This feature makes the traffic policy configuration changes take effect immediately and accelerates traffic policy matching for packets. When a large number of traffic policies exist, enable traffic policy matching acceleration. If the acceleration fails, the changed match criteria do not take effect. The system still uses the original match criteria to match packets.
To enable traffic policy matching acceleration, choose one of the following methods:
Bandwidth management for all IPv6 Layer 4 traffic
By default, bandwidth management is performed on traffic flows of TCP, UDP, ICMP, and ICMPv6. This function enables the device to perform bandwidth management on traffic flows of all IPv6 Layer 4 traffic in addition to the IPv4 Layer 4 traffic.
On the Traffic Policies page, click Advanced settings, and click All OSI-layer protocol IPv6 flow control to enable or disable this function.
Source NAT and destination NAT bandwidth management
By default, the device uses the IP address, port number, and VPN instance before NAT is performed to match a traffic policy.
To control bandwidth for IP addresses after NAT is performed, click Advanced settings on the Traffic Policies page, and then click After-NAT source IP matching and After-NAT destination IP matching.
vSystem support information
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Restrictions and guidelines: Configuring parent and child traffic policies
Restrictions and guidelines: Configuring a traffic profile
Bandwidth management is performed on a per-card basis. On a device installed with multiple security service cards, you must consider the number of security service cards when configuring bandwidth parameters in a traffic profile. For example, if the device is installed with three security service cards and you want to limit the uplink maximum bandwidth to 30000 kbps, you must configure the uplink maximum bandwidth to 10000 kbps.
If a TCP MSS is also configured for an interface, the smaller TCP MSS takes effect.
If a packet matches both a proxy policy and a traffic policy, the TCP MSS configured on the interface is used.
Restrictions and guidelines: Configuring interface bandwidth
An interface with small default expected bandwidth might experience traffic loss if the following conditions exist:
To avoid traffic loss, implicitly set the expected bandwidth to a large value for such an interface. For example, you can set the expected bandwidth of a tunnel interface to a value greater than 64 kbps (the default) if there is a large amount of traffic on the interface.
Restrictions and guidelines: Managing traffic policies
The traffic policy created by copying a traffic policy is placed next to the copied traffic policy.
Configure bandwidth management
Figure-3 shows the configuration procedure for bandwidth management.
Figure-3 Bandwidth management configuration procedure
Before configuring bandwidth management, configure security policies to allow traffic to flow through the device. For information about configuring security policies, see "Security Policy Help."
Configure a traffic profile
A traffic profile manages and allocates bandwidth resources in a network. By creating a traffic profile, you can configure the bandwidth limits, bandwidth detection, and reference mode, enabling efficient bandwidth management and allocation.
To configure a traffic profile:
  1. Select Policies > Bandwidth Management > Traffic Profile.
  2. Click Create on the Traffic Profile tab.
  3. Configure a traffic profile.
    Table-2 Traffic profile configuration items
    Item
    Name
    Enter a name for the traffic profile.
    Rate limit mode
    Select Limit uplink and downlink separately or Limit uplink and downlink.
    Reference mode
    Select Exclusive or Shared.
    Total uplink maximum bandwidth
    Set the total uplink maximum bandwidth.
    Total uplink guaranteed bandwidth
    Set the total uplink guaranteed bandwidth.
    Total downlink maximum bandwidth
    Set the total downlink maximum bandwidth.
    Total downlink guaranteed bandwidth
    Set the total downlink guaranteed bandwidth.
    Forwarding priority
    Set the forwarding priority. A greater priority value means a higher priority.
    Select this option to allocate the total maximum bandwidth dynamically and evenly among online IP addresses.
    Per-IP uplink maximum bandwidth
    Set the per-IP uplink maximum bandwidth.
    Per-IP downlink maximum bandwidth
    Set the per-IP downlink maximum bandwidth.
    Per-user uplink maximum bandwidth
    Set the per-user uplink maximum bandwidth.
    Per-user downlink maximum bandwidth
    Set the per-user downlink maximum bandwidth.
    Enable bandwidth check
    Enable the device to detect the amount of bandwidth consumed by traffic in real time by source IP address.
    Static threshold-Maximum
    Set the maximum static threshold.
    Static threshold-Minimum
    Set the minimum static threshold.
    Enable dynamic threshold learning
    Enable the device to dynamically learn bandwidth thresholds.
    Learning duration
    Set the learning duration.
    Learning tolerance-Maximum
    Set the maximum bandwidth tolerance value.
    The device derives the maximum bandwidth threshold from multiplying the learned bandwidth threshold by the maximum bandwidth tolerance value.
    Learning tolerance- Minimum
    Set the minimum bandwidth tolerance value.
    The device derives the minimum bandwidth threshold from multiplying the learned bandwidth threshold by the minimum bandwidth tolerance value.
    Total connection count
    Set the total connection count.
    Per-IP/Per-user connection count
    Set the per-IP/per-user connection count.
    Total connection rate
    Set the total connection rate.
    Per-IP/Per-user connection rate
    Set the per-IP/per-user connection rate.
    Set the per-IP monthly traffic quota.
    Mark DSCP priority
    Set the DSCP priority to be marked for packets.
    TCP MSS
    Set the TCP MSS.
  4. Click OK. The new traffic profile appears on the Traffic Profile page.
Configure a traffic policy
You can configure traffic profiles and traffic rules in traffic policy view. A traffic profile specifies the guaranteed bandwidth and maximum bandwidth. A traffic rule specifies match criteria to match packets and the traffic profile to apply to matching packets.
To configure a traffic policy:
  1. Select Policies > Bandwidth Management > Traffic Policies.
  2. Click Create on the Traffic Policy page.
  3. Create a traffic policy.
    Table-3 Traffic policy configuration items
    Item
    Name
    Enter a name for the traffic policy.
    Parent policy
    Specify a parent policy.
    Source security zone
    Specify a source security zone as a match criterion.
    Destination security zone
    Specify a destination security zone as a match criterion.
    Source IP address
    Specify a source IP address object group as a match criterion.
    Destination IP address
    Specify a destination IP address object group as a match criterion.
    User
    Specify an identity user or user group as a match criterion.
    Application
    Specify an application or application group as a match criterion.
    Service
    Specify a service object group as a match criterion.
    Time range
    Specify a time range during which the policy is in effect.
    DSCP priority
    Specify a DSCP priority as a match criterion.
    IPv6 flow label
    Specify an IPv6 flow label as a match criterion.
    IPv6 extension header
    Specify an IPv6 extension header as a match criterion.
    Terminal
    Specify a terminal or terminal group as a match criterion.
    VRF
    Specify a VPN instance as a match criterion.
    Action
    Specify an action for the policy:
    • Rate limit—Limits the rate of matching packets by referencing a traffic profile.
    • Not rate limit—Does not limit the rate of matching packets.
    • Block—Blocks matching packets.
    Traffic profile
    Specify a traffic profile.
  4. Click OK. The new traffic policy appears on the Traffic Policy page.
  5. For the traffic policy configuration to take effect immediately, click Accelerate.
Configure interface bandwidth
  1. Select Policies > Bandwidth Management > Interface Bandwidth.
  2. Click Create on the Interface Bandwidth page.
  3. Create an interface bandwidth entry.
    Table-4 Interface bandwidth configuration items
    Item
    Interface name
    Select an interface.
    Expected bandwidth
    Specify the expected bandwidth value.
  4. Click OK. The new interface bandwidth entry appears on the Interface Bandwidth List page.
