Application audit
This help contains the following topics:
Introduction
This feature parses personal information from user packets and must be used for legitimate purposes.
Based on application recognition (APR), application audit audits and records Internet access behaviors of users by identifying behaviors and behavior contents of applications.
Basic concepts
Application behaviors
Applications and programs are characterized by different behaviors. For example, IM applications are characterized by login and message sending. FTP is characterized by file upload and file download.
Behavior contents
A behavior content is the content of a behavior. For example, the content of a login behavior is the account information. The content of an FTP file upload behavior is the file name. You can match behavior contents by using a string or a number.
Application audit process
Figure-1 Application audit process
Application audit policy
Different audit policies process matching packets differently.
Policy types
Application audit policies have the following types:
Policy matching
Multiple application audit policies can exist on a device. The device compares a packet with policies in their configuration order. When a match is found, the match process ends. If no match is found, the device applies the default action to the packet.
You can view the configuration order of policies on the Audit Policy page. The configuration order is the creation order if no polices are moved. You can change the configuration order of a policy by moving the policy. As a best practice to audit packets more accurately, observe the depth-first principle when creating policies. Always create a policy with a smaller audit scope before a policy with a larger audit scope.
Match criteria
Multiple match criteria can be configured in an application audit policy. A policy is matched if all match criteria in the policy are matched.
The following match criteria are available:
One match criterion can contain multiple match values. For example, you can configure multiple address object groups for a source IP address match criterion. A match criterion is matched if any of its match values is matched.
Audit rule
Audit rules can be configured for an audit policy to perform more granular control on user behaviors and to generate audit logs.
The following rule match modes are available:
The device processes packets as follows based on the match result:
Email protection can be configured in a rule. The device detects incoming emails, counts emails based on recipients, and protects recipients from attacks. Specifically, you can configure the following functions:
vSystem support information
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Licensing requirements
Application auditing is based on application recognition (APR). To use application auditing, you must purchase and install the required license. After the license expires, the application auditing feature is available through the existing APR signature library, but you cannot update the APR signature library. For more information about licensing, see the license management help.
Configure application audit
Figure-2 shows the configuration procedure for application audit.
Figure-2 Application audit configuration procedure
Before configuring application audit, configure security policies to allow traffic to flow through the device. For information about configuring security policies, see "Security Policy Help."
Complete the following tasks before you configure this feature:
  • Assign IP addresses to interfaces on the Network > Interface Configuration > Interfaces page.
  • Configure routes on the Network > Routing page. Make sure the routes are available.
  • Create security zones on the Network > Security Zones page.
  • Add interfaces to security zones. You can add interfaces to a security zone on the Security Zones page or select a security zone for an interface on the Interfaces page.
  • Configure security policies to permit the target traffic on the Policies > Security Policies page.
Purchase and install the APR license.
Upgrade the APR signature library to the most recent version on the official website.
Configure a keyword group
  1. Select Policies > Application Audit > Audit Policies.
  2. Click Keyword Group.
  3. Click Create to create a keyword group.
    Table-1 Keyword group configuration items
    Item
    Name
    Enter a name for the keyword group.
    Enter a description for the keyword group, which helps the administrator identify the keyword group.
    Keyword
    Enter keywords to be audited. Keywords are separated by carriage returns.
  4. Click OK. The new keyword group appears in the Keyword Group page.
Configure an application audit policy
  1. Select Policies > Application Audit.
  2. Click Create in the Application Audit page.
  3. Create an application audit policy.
    Table-2 Application audit policy configuration items
    Item
    Name
    Enter a name for the application audit policy.
    Select the application audit policy type: Audit, Audit-free, and Deny.
    Enable
    Enable the policy to make it take effect.
    Source security zone
    Specify a source security zone as a match criterion.
    Destination security zone
    Specify a destination security zone as a match criterion.
    Source IP address
    Specify a source IP address object group as a match criterion.
    Destination IP address
    Specify a destination IP address object group as a match criterion.
    Service
    Specify a service object group as a match criterion.
    User
    Specify a user as a match criterion.
    Application
    Specify an application or application group as a match criterion.
    Time range
    Specify a time range during which the policy is in effect.
    Audit rule
    Configure an audit rule to perform refined auditing on the behaviors and behavior contents of applications. This item can be configured only for an Audit-type policy.
    Rule ID
    Enter a rule ID.
    Application
    Select the applications to be audited.
    Behavior
    Select the behaviors to be audited.
    Behavior content
    Select the behavior contents to be audited.
    Match type
    Specify the behavior content type:
    • Keyword.
    • Number.
    Keyword
    Operator used when behavior contents are matched:
    • For keyword-type behavior contents: Include, Exclude, Equal, Unequal.
    • For number-type behavior contents: Equal, Unequal, Greater, Less, Greater-equal, Less-equal.
    Email protection
    Select Enable to configure the Limit email sending and Prevent email bombing functions.
    Limit email sending
    Select Enable to prevent users from sending emails to users of a different domain.
    Configure this function to protect recipients from being overwhelmed by large numbers of emails from the same sender during a short period of time.
    • Detection time—The specified maximum number of emails can be received from the same user during this time.
    • Email count—The maximum number of emails that can be received from the same user during the detection time.
    Action
    Select an action to take on packets matching audit rules: Permit or Deny.
    Logging
    Select Enabled or Disabled to enable or disable generation of logs.
  4. Click OK. The new application audit policy appears in the Audit Policy page.
