Set disk parameters
You can set the disk scheduling mode and queue depth. If you modify a disk parameter, modify it on all disks in a log, Grid, or data disk group and modify the following disk settings on the hosts resident with the disks.
After you modify the disk settings, log out and relog in.
iscsiadm -m node –u
iscsiadm -m node -l
