Install CAStools
  1. Select a file directory. The default directory is vms/isos/castools.iso.
  1. Click Access Console. Execute the mount /dev/cdrom /mnt command to mount a virtual optical drive, and then execute the /mnt/linux/CAS_tools_install.sh command to complete CAStools installation.
The commands are applicable only to Oracle Linux systems. For other operating systems, use the corresponding commands.
