To create a tenant, you must first create an object gateway.
A tenant can be managed by multiple administrators.
An operator can manage only one tenant as an administrator.
When the cluster does not have load and a large number of users and tenants are created, a warning message will be generated. This message has no impact on the cluster, and you can ignore it.
For management users of a tenant to have permissions to view object storage information, you must use operators in system administrator groups as management users.
To specify a management user for the default tenant, make sure at least one management user exists.
To delete a tenant that has data, you must first delete all data from the tenant.
On the top navigation bar, click Storage, and then select Object Storage > Tenants from the navigation pane.
Click Create, enter a tenant name, select management users, configure remarks, and then click OK.
Select a tenant, and then click Edit.
Edit the management users and remarks as needed.
Click OK.
Select a tenant, and then click Delete.
Tenant Name: Enter a tenant name.
