Configure authentication for CIFS share users
The selected authentication mode on the CIFS Share Authentication page is the current authentication mode for CIFS share users.
Configure local user authentication
After you enable local user authentication, only local users can access CIFS shares.
To configure local user authentication:
  1. On the top navigation bar, click Storage, and then select File Storage > Users from the navigation pane.
  1. Click the CIFS Share Authentication tab.
  1. Select Local User Authentication.
  1. Click Apply.
  1. In the dialog box that opens, click OK.
Configure AD authentication
After you enable AD authentication, both AD users and local users can access CIFS shares.
To configure AD authentication:
  1. Select AD Authentication.
  1. Set the parameters as described in "Parameters."
  1. Click Apply.
Configure LDAP authentication
After you enable LDAP authentication, both LDAP users and local users can access CIFS shares.
To configure LDAP authentication:
  1. Select LDAP Authentication.
  1. Click Apply.
Configure anonymous access
After you enable anonymous access, all users can access CIFS shares.
To configure anonymous access:
  1. Select Anonymous Access.
  1. Click Apply.
