Manage FTP shares
Create an FTP share
  1. On the top navigation bar, click Storage, and then select File Storage > NAS from the navigation pane.
  1. Click the FTP Shares tab.
  1. Click Create.
  1. Click Browse.
Edit FTP share permissions
Add users to an FTP share
  1. Click Permission in the Actions column for an FTP share or click the name of an FTP share.
  1. Click Create.
  1. Enter the name of a local user and then click Search or click Search directly, select one or multiple users, and then click OK.
  1. Set the parameters as described in "Parameters."
  1. Click OK.
Edit an FTP share user
  1. Click Edit in the Actions column for a user.
  1. Edit the parameters as described in "Parameters."
  1. Click OK.
Delete users from an FTP share
  1. Click Delete in the Actions column for a user.
  1. In the dialog box that opens, click OK.
  1. To delete multiple users in bulk, select the users, and then click Delete on the top of the page.
Enable or disable anonymous access to FTP shares
  1. Select Reject or Permit for the Anonymous Access parameter on the top of the page.
Delete an FTP share
  1. Click Delete in the Actions column for an FTP share.
Create an FTP share
Directory: Specify a shared directory, which cannot be the root directory.
Edit FTP share permissions-Add users to an FTP share
