Set the provisioning mode of a VM disk
Mount eager zeroed storage volumes as disks to VMs that use shared storage to improve VM performance.
To set the provisioning mode of a storage volume:
  1. On the top navigation bar, click Hosts.
  1. Select a host, and then click the Storage tab.
  1. Select a storage pool.
  1. Create a storage volume, and set its provisioning mode to eager zeroed.
Figure-1 Setting the provisioning mode
  1. Mount the storage volumes to VMs.
