Manage Swift users
Perform this task to enable or disable the swift user access service.
  1. On the top navigation bar, click Storage, and then select Object Storage > Users from the navigation pane.
  1. Select a user, and then click More/Swift User.
  1. Enable or disable the swift user access service.
  1. Click OK.
Swift User Access: Enable or disable the swift user access service. If you enable this service, you can use a swift username and password to access object storage resources.
