Clear backup data
  1. On the top navigation bar, click Services, and then select Disaster Recovery Management > Recovery Plans > Recovery Plan Name from the navigation pane.
  1. Click Clear Backup Data.
  1. In the dialog box that opens, read the prompt and then click OK.
  1. Click the Recovery Tasks tab to view the state of the recovery task.
  1. Click the execution time link for the recovery task to view task details.
  1. Verify that the protected VMs have been deleted from the recovery site, and the mapped storage resources have been removed.
