Manage quotas
To ensure the fair use of storage space, use quotas to control the storage resources that a tenant can use. You can configure a quota in terms of storage space or number of files.
  1. On the top navigation bar, click Storage, and then select Object Storage > Tenants from the navigation pane.
  1. Select a tenant, and then click Quota.
