Delete a bucket
Deleting a bucket will delete all data in the bucket. To avoid data loss, back up the data in a bucket before deleting the bucket.
  1. On the top navigation bar, click Storage, and then select Object Storage > Buckets from the navigation pane.
  1. Select a bucket to be deleted, and then click Delete.
  1. In the dialog box that opens, click OK.
