Configure WORM settings
The WORM clock is designed to prevent files becoming expired as a result of system time change.
  1. On the top navigation bar, click Storage, and then select File Storage > Directories from the navigation pane.
  1. Click the WORM tab.
  1. Configure the parameters as described in "Parameters."
  1. Click OK.
View WORM settings
  1. Click WORM Clock. For more information about the parameters, see "Parameters."
Create a WORM root directory
To retain files in a directory in an unmodifiable form, specify that directory as a write once read many (WORM) directory. Set the autocommit timer to control the amount of time that a file must remain unchanged before it is committed to the WORM state. Specify the minimum and maximum retention periods to control the maximum and minimum amount of time that the files will be retained in WORM state.
To create a WORM root directory:
  1. Click Create.
  1. Click Browse, and select an empty directory.
  1. Set the parameters as described in "Parameters."
Edit the WORM attribute of a WORM root directory
  1. Click Edit in the Actions column for a WORM root directory.
  1. Click OK.
Delete the WORM attribute of a WORM root directory
  1. Click Delete in the Actions column for a WORM root directory.
  1. In the dialog box that opens, click OK.
Export WORM records
  1. Click Export.
  1. Select a date, and then click OK.
Extend retention period for a WORM root directory
Perform this task to extend the retention period for locked files under a WORM root directory and lock expired files in the directory again.
  1. Click Extend Retention Period in the Actions column for a WORM root directory.
  1. Specify a time point from the Extend Retention Period To field, and then click OK.
