How many virtual desktops can I deploy on a physical server?
It depends on the server hardware configuration, virtual desktop configuration, and desktop application.
As a best practice, make sure the desktop VMs deployed on a physical server use only two-thirds of server resources.
For example, a server has two CPUs, six CPU cores, and 128 GB memory. If you assign 1 vCPU and 2 GB memory to each desktop, you can theoretically run 50 to 60 desktops on the server. To ensure server stability, deploy a maximum of 40 desktops on the server.
