Standalone SQL Server installation procedure
  1. Mount an SQL Server 2016 image to the optical driver of a VM.
Figure-1 Mounting an image file
  1. Select New SQL Server stand-alone installation or add features to an existing installation.
Figure-2 Selecting an installation option
  1. Enter your product key, and then click Next.
Figure-3 Entering a product key
  1. Click Next.
Figure-4 Installation rules
  1. Wait for the rule check to run.
  1. Select features:
Figure-5 Selecting features
  1. Click Next.
  1. Modify the instance ID as needed, and then click Next.
Figure-6 Instance ID
  1. Click Next.
Figure-7 Server configuration
  1. Configure database engine settings:
  1. On the Server Configuration tab, select mixed authentication mode, and specify the current account as a SQL Server administrator.
Figure-8 Server Configuration tab
  1. On the Data Directories tab, place log-related directories on the log disk, and place data-related disks on the data disk.
Figure-9 Data Directories tab
  1. On the TempDB tab, place the log directory on the log disk, configure other parameters, and then click Next.
Figure-10 TempDB tab
  1. Click Next.
Figure-11 Reporting services configuration
  1. Click Install.
Figure-12 Installing SQL Server 2016
Figure-13 Installation finished
