Install CAStools for the VM
For the compatibility between CAStools and operating systems, see H3C UIS Server Virtualization Software and Hardware Compatibility.
Install CAStools for a Windows or Linux operating system
  1. Log in to UIS, select the target VM, and then click Edit.
  1. Click the CD-ROM tab, and then click Connect.
  1. Select Install CAStools from the Type list, and then click OK.
Figure-1 Installing CAStools
  1. Install the CAStools according to the operating system type. After completing installation, restart the VM.
The root password is what you specified during operating system installation.
[root@localhost~]# mount /dev/cdrom /media
mount: /dev/sr0 is write-protected, mounting read-only
[root@localhost~]# cd /media
[root@localhost media]# ls
CAS_tools_setup.exe CAS_tools_upgrade,js linux query.bat readme.txt
[root@localhost media]# cd linux
[root@localhost linux]# sh ./CAS_tools_install.sh
Preparing…               ###########################[100%]
Updating / installing…
   1:qemu-ga-6.0.2.0-1   ###########################[100%]
Non-SUSE
Created symlink from /etc/systemd/system/multi-user.target.wants/qemu-ga.service to /usr/lib/systemd/system/qemu-ga.service.
Install CAStools for a FreeBSD operating system
  1. Log in to the operating system as a root user.
  1. Based on the FreeBSD ISO image file, execute the following commands to install pkg and python:
root@:~ # mkdir /dist
root@:~ # mount –t cd9660 /dev/cd0 /dist
root@:~ # setenv REPOS_DIR /dist/packages/repos
root@:~ # pkg bootstrap
The package management tool is not yet installed on your system.
Do you want to fetch and install it now? [y/n]:y
Bootstrapping pkg from file:///dist/packages/FreeBSD:11:amd64, please wait…
Installing pkg-1.8.7_1…
Extracting pkg-1.8.7_1:100%
root@:~ # pkg install python
Updating FreeBSD_install_cdrom repository catalogue…
Fetching meta.tzx:100%   260 B  0.3KB/s  00:01
Fetching packagesite.txz:100%  244 KiB 249.9Kb/s  00:01
Processing entries:100%
FreeBSD_install_cdrom repository update completed.1075 packages processed.
Updating database digests format:100%
Checking intergrity…done(0 conflicting)
The following 7 package(s) will be affected (of 0 checked):
New packages to be INSTALLED:
        python:2.7_2,2
        python27:2.7.12
        libffi:3.2.1
        indexinfo:0.2.4
        readline:6.3.8
        gettext-runtime:0.19.8.1
        python2:2_3
Number of packages to be installed:7
The process will require 69 MiB more space.
Proceed with this action?[y/n]:y
  1. Log in to UIS, select the VM, and then click Edit.
Figure-2 Installing CAStools
  1. Open the VM's console, and then execute the following commands:
root@:~ # mount -t cd9660 /dev/cd0 /media/
root@:~ # cd /media/linux/
root@:~ # ./CAS_tools_install.sh
Installing qemu-ga-6.0.2.0-amd64...
Extracting qemu-ga-6.0.2.0-amd64: 100%
Message from qemu-ga-6.0.2.0-amd64:
Qemu-ga has been installed successfully, Use 'service qemu-ga start' to start!
Verify the installation
  1. Enter the summary information page of the VM.
  1. Verify that the CAStools state is running.
